Bagged '99 Xtra Cab
Discussion in 'Buy / Sell / Trade' started by xwikedonex, Jan 10, 2011.
  1. Jan 10, 2011 at 7:45 PM
    xwikedonex
    xwikedonex [OP] Member
    Justin
    La Habra
    Had a Bagged 99 xtra cab
    The time has come for me to get a more family friendly vehicle so I’m selling my truck. It’s a 99 xtra cab 4cyl, 152,xxx miles. Runs great, with some work and TLC it will be an awesome truck. It lays frame in the rear, needs some work to get the from all the way down, asking $4000.00 I’ll post up some recent pics of the truck tomorrow when there’s daylight.
    The good:
    - Built by Thomas Dominguez, pics of the build are available at http://www.customtacos.com/forum/showthread.php?p=1800775#post1800775- Slam Specialties RE7 bags all the way around – the truck rides great
    - (8) SMC 3/8” valves
    - Hydraulic hoses and fittings for all of the air lines
    - 18” Konig Hotswap wheels with 225/40ZR18 Falken Ziex tires, a little curb rash, tires in decent condition but inner edge is worn from negative camber
    - (2) Viar 380 compressors
    - SMC check valve on each compressor line
    - AVS 7 switch box
    - 5 gallon tank
    - I have (2) SMC water traps and (2) Dual needle gauges that aren’t installed
    - Thorley Headers
    - K&N Intake
    - Bed mounted Diamond plate tool chest included
    - License plate recessed in center of tailgate
    - Falcon 600 2 way alarm with keyless entry
    - Custom Tacos sticker on the rear window
    - Gas tank lifted
    The Bad:
    - Needs Body work and paint, the bedsides are beat up and the paint is doesn’t match in repaired areas.
    - Power steering fluid leak from the right side of the rack, I put some Lucas stop leak in in and seems to have stopped
    - Carrier Bearing needs replacement
    - Right front has a leak but only seems to drop only when the pressure is low
    - Interior is worn, stains on the carpet
    - Cross member behind bumper and radiator support bent from previous owner, but no damage to radiator or lines in the area
    - No bed floor, but there is a frame started, just no time and money to complete it
    - Front doesn’t lay frame, needs some fab work and fenders tubbed to lay out completely
    - No power windows
  2. Jan 11, 2011 at 11:11 PM
    xwikedonex
    Justin
    La Habra
    Bumpski!
  3. Jan 14, 2011 at 4:48 PM
    xwikedonex
    Justin
    La Habra
    bump again
  4. Jan 30, 2011 at 7:15 PM
    xwikedonex
    Justin
    La Habra
