Baja design fogs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PEIyota, May 17, 2017.
  1. May 17, 2017 at 3:39 AM
    PEIyota
    PEIyota [OP] Well-Known Member
    Jeff
    Prince Edward Island, Canada
    2017 MGM TRD Off-Road DCSB
    TRD Pro Grille, OEM Bed Mat, TRD Shift Knob, Red Tow Hook (painted)
    What is the specific light called from Baja design that I see used for our 3rd gen fogs?
    I was considering getting the factory rigid industries, but it looks like they are underwhelming from what I've read.
    ChadsPride and Lord Humongous like this.
  2. May 17, 2017 at 3:49 AM
    RonH1031
    RonH1031 Active Member
    Ron
    Deming, NM
    The Squadron-R Sport or Pro I believe is what you're looking for...
    ChadsPride and PEIyota[OP] like this.
  3. May 17, 2017 at 5:02 AM
    PEIyota
    Jeff
    I'm assuming both are the same except the pro is brighter? Which one do you guys think is best for a fog light application?
    ChadsPride likes this.
  4. May 17, 2017 at 5:20 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    How much fog do you really get? I never use mine.
    uhplifted likes this.
  5. May 17, 2017 at 5:21 AM
    PEIyota
    Jeff
    Occasional fog. Lots of snow.
  6. May 17, 2017 at 5:23 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    The Pro is stupid bright, if you plan on running these on the road please get the sports for the sake of other drivers as well. A buddy of mine here in Denver has the amber sports and they are just beautiful for driving in the snow and rain (in the summer months) of Colorado
    rolled93slc and ramonortiz55 like this.
  7. May 17, 2017 at 5:27 AM
    PEIyota
    Jeff
    Perfect. I was concerned that the pros may be too bright for road driving.
    Now what are the squadron R ? I'm guessing these are not meant for road driving either?
    As far as beam pattern? Driving/combo my best bet for fogs?
  8. May 17, 2017 at 5:29 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    so you have two bezels, the square and the round. you are going to want the squadron sport-R for the round bezel and the fit kit to get it in your truck......but i'd hold off for a little b/c baja designs is working on a custom bezel to fit the 3rd gens seamlessly.
  9. May 17, 2017 at 5:31 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
  10. May 17, 2017 at 5:34 AM
    PEIyota
    Jeff
    Ahh, ok gotcha.
    Yea that gap is hedious. Glad they are getting around to fixing it.
  11. May 17, 2017 at 5:35 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    This. I would call up Baja designs though as they are very knowledgeable about their products and can also throw you a 10% off for being TW member. They always seem to give me a deal on top of the discount whenever I get stuff from them.
  12. May 17, 2017 at 5:38 AM
    PEIyota
    Jeff
    Can you get the bezels we lettering on them? I thought I saw one with "squadron" on top and something else on bottom, maybe"sport"?
    I think it'd look great, even if it said Baja design. One of the main reason I like the stock Ridgid is how clean the lettering looks on the bezel.
  13. May 17, 2017 at 5:40 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    If you want to keep them working as fog lamps then you should get the Wide Cornering beam pattern.
    They have in it white
    https://www.bajadesigns.com/products/squadron-r-sport-pair-wide-cornering-led.asp
    Or amber
    https://www.bajadesigns.com/products/squadron-r-sport-pair-wide-cornering-amber.asp
  14. May 17, 2017 at 5:42 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    mach1man001[QUOTED] likes this.
  15. May 17, 2017 at 5:42 AM
    PEIyota
    Jeff
  16. May 17, 2017 at 5:42 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I will say this though, I have rigid DOT fogs (only rigid lights I own, rest is BD) on my tube bumper as I didn't want to have any hassle for inspections. I think sports with an amber lense will likely suffice for inspections, but I don't know for sure.
  17. May 17, 2017 at 5:53 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    It depends on the model. I just got the one's I posted and the amber color is part of the lens
    The inspections are not that tough about those things around where I live
  18. May 17, 2017 at 7:45 AM
    HeavyLifter
    HeavyLifter Well-Known Member
    Jeff
    Athens, Ohio
    2013 TRD Sport
  19. May 17, 2017 at 8:31 AM
    upTOPOverland_Drew
    Drew
    Littleton, CO
  20. May 17, 2017 at 8:43 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    It is my impression that you can replacement lenses, either a different color (amber vs. clear) and or a different pattern (wide cornering vs. spot vs. combo). But I can only find the square replacement lenses on their site. I've been researching these a little bit and reading up on their subforum here, and a lot of times they suggest calling them when ordering so maybe the round replacement lenses are a call-to-order item? They plug and play into the existing light harness and you can use the stock fog light switch. The only disadvantage is they won't turn on with high beams, but not an issue for me.
    My intention is to get the clear squadron r sports and an amber replacement lens (looks like they are around $15 each). The amber will go on in the winter months. But I didn't know they were redesigning the bezel to have a better fit in the stock bumper. that's good to know.
