Baja Designs Ditch Lights as fog lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Donovan1101, Jun 4, 2025.
  1. Jun 4, 2025 at 10:34 PM
    Donovan1101
    Donovan1101 [OP] Member
    Donovan
    2023 Toyota Tacoma
    Hello Im wondering if the Baja designs ditch lights are able to plug in to the fog lights on my 3rd gen Tacoma if not I’ll just pay full price on actual fogs, if so then I save a couple bucks buying the ditch lights
  2. Jun 6, 2025 at 12:00 AM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    I’m pretty sure that you will need an adapter for your lights to get them to fit in the factory fog light location. Contact Baja Designs and they will tell you what you need. Got adapters from them to go from flush mount to regular mount. Good to work with.
  3. Jun 6, 2025 at 8:56 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  4. Jun 9, 2025 at 9:50 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    It is technically possible, but you would also need to buy extensions and the pigtail adapters that come in the kit. Or it would be recommended to just use the harness that comes with the set of lights. This will require you to run the switch into the cab, but it will be the less expensive option. Feel free to shoot me an email! We would love to help you out in getting what exactly you want, rather than something you may not be looking for. The fog light kit works great, and that is what we would recommend, as it keeps the OEM feel of the vehicle.
    Best,
    Brahian Herrera | Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252 Ext 201
    BarRedAmateur likes this.
  5. Jun 9, 2025 at 11:10 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Wouldn't "ditch lights" also have a different beam pattern than a set of actual "fog" lights (more like a spot/flood light rather than the proper 'fog' beam pattern that is narrow vertically, but wide horizontally)? I wouldn't think they'd even function properly as a fog light.
  6. Jun 9, 2025 at 3:02 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    As stated above you really need to specify what you mean by ditch lights. Technically with the pig tail adapters and mounting brackets you can easily install any squadron light into the fog light position. The bezel won't match up with the bumper but it will technically fit.
    Having said that light pattern is just as important to consider. Nothing besides an sae fog pattern should be installed. Especially for street use. A combo pattern will not work as a fog light and driving wide has no cut off for street use but is an awesome offroad light but not a good fog light.
