Baja Designs - Dome Light w/ Switch & Rock Light - Order Now and Save 10% !!!
Discussion in 'Lighting' started by Baja Designs, Nov 29, 2016.
  1. Nov 21, 2017 at 8:58 AM
    #41
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    BDForums is the code that can be applied at checkout for 10% OFF + $5 Shipping to the Lower 48
    www.bajadesigns.com
  2. Nov 21, 2017 at 9:01 AM
    #42
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
  3. Nov 21, 2017 at 9:01 AM
    #43
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  4. Nov 21, 2017 at 10:18 AM
    #44
    Italia234
    Nick
    Tucson
    TRD offroad
    Also what awg wire is this? I'll have to lengthen mine a little.
  5. Nov 21, 2017 at 11:14 AM
    #45
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I will check my stock when I get home, but I want to say its like 22g. I normally solder on larger wire to help with plugs and such.
  6. Nov 21, 2017 at 11:18 AM
    #46
    Baja Designs
    San Marcos, CA
    @paranoid56 is correct! The wire is 22g for our Rock and Dome Lights.
  7. Nov 21, 2017 at 2:36 PM
    #47
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Hey bailey,
    Are the red rock lights a red LED with clear lens, or a Clear LED with red lens?
    Guess I'll find out...
  8. Nov 27, 2017 at 11:15 AM
    #48
    paranoid56
    San Diego
    14 double cab taco
    the red has a clear lens.
    in this pic there is the red on top and amber on the bottom. .
    MESO[QUOTED] likes this.
  9. Nov 27, 2017 at 11:16 AM
    #49
    MESO
    State of Jefferson
    Thank you! Wanted to make sure my red and white rocks will match lined up next to each other.
  10. Feb 13, 2019 at 1:00 PM
    #50
    Baja Designs
    San Marcos, CA
    ROCK / DOME LIGHTS
    Updated as of 1/1/2019
    ORDER NOW
    JLink likes this.
  11. May 31, 2019 at 11:26 AM
    #51
    Baja Designs
    San Marcos, CA
    We are pumping out the latest and greatest Dome & Rock Lights
    Order today with your forum discount
    Code: BDForums saves 10% + gives the option for $5 shipping to the Lower 48
    apply at www.bajadesigns.com
  12. Aug 11, 2020 at 11:29 AM
    #52
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    bringing this thread back from the dead. @Baja Designs (or anyone else) would it be possible to tap into the switch inside one of the dome lights to power a rock light as well on the same circuit?
    I'm working out the lighting for my camper build and I thought it would be pretty slick if I could use the switch on a single dome light to have 2 lights - a rock and a dome, 1 on each side turn on together. I know I can just get 2 rock lights and wire that to a switch but if it's as simple as soldering an extra wire onto the switch in the dome I thought this could be a really cool/clean way to do it. I Just don't necessarily wanna buy a light to take it apart and find out. If possible a pic of the frontside of the board would be helpful too!
    Clearly I wouldn't be harassing you about the warranty if I started soldering stuff on my light. :)
  13. Aug 11, 2020 at 12:25 PM
    #53
    Baja Designs
    San Marcos, CA
    Hi plurpimpin,
    That's actually a really cool concept! Unfortunately, the way that the rock/dome light is built it would be very hard to modify. Each light has a machined aluminum housing and is sealed with epoxy after the circuit board is installed. Even if you did cut it open, you may run into issues with reliability. For example, condensation may be obtained because it's no longer sealed. This has never been done, so I wouldn't be able to provide instruction nor encourage it because of liability issues. Sorry to say we're hitting a wall with this. I would either recommend using an external switch mounted in the vehicle for a set of rock lights or using two dome lights.
  14. Aug 11, 2020 at 12:37 PM
    #54
    plurpimpin
    PDX
    Ah makes sense! Didn’t realize they were epoxy sealed. I saw the earlier pics in this thread and thought it might be as simple as taking a few screws off to open the case. Thanks for the quick reply!
    Well I guess the other question is if a single dome is bright enough for a camper shell/GFC type application or would I be happier with 2 lights?
  15. Aug 11, 2020 at 7:34 PM
    #55
    paranoid56
    San Diego
    14 double cab taco
    you may want 2 for that application
