Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Apr 15, 2019 at 8:55 AM
    #2241
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Thought I saw it somewhere but can't locate it.
    If I want to cut the cord on the S2's prior to the connector, is that a warranty killer? I'd seen on BD's website that you could do so on the lights with the moisture block if it was cut after the block
    but see nothing about the lights like S2 which don't have that feature.
    I'm doing an in mirror install for ditch lights, and the room inside the housing is going to be tight. May be a little hard to fit the cord and connectors inside the housing, there is no way to fit a connector through the run it has to go through to get into the door, and the lead seems just short of long enough to disassemble the connector, feed it though, and reassemble the connector.
  2. Apr 15, 2019 at 9:12 AM
    #2242
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I can understand it happening if it has been on for awhile but like I said, mine have only been on since just after Christmas, so not too much sun yet! My buddy got a BD lightbar during the same time and I could see from looking at his it's looking purple as well. I'm gonna check his squadrons and see if they look like mine do.
    Weird they have faded so quick..but hopefully, I can get a new set that lasts a bit longer...
    Gunshot-6A[QUOTED] likes this.
  3. Apr 15, 2019 at 9:20 AM
    #2243
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I have a bunch of squadrons and S2s on my truck and haven't had an issue with their faces fading after a year plus. Just my RTL and I assume my newer S8 on the roof will have a similar fade. Doesn't hurt anything, just gets discolored by the UV.
  4. Apr 15, 2019 at 9:38 AM
    #2244
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wanna say in my squadron sports I read in the instructions/brochure that came with the lights that you can cut the connectors off. I sure hope so because I cut mine off haha
  5. Apr 15, 2019 at 9:42 AM
    #2245
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Found it. It’s in their limited lifetime warranty. 4th line down.
  6. Apr 15, 2019 at 9:45 AM
    #2246
    sagexp
    Back home, AZ
    I'm not sure what I'm seeing now. I see the video on moisture block, and it shows S2's on the table with a moisture block lead clearly on the light. Now that I'm digging into it deeper, I'm seeing photos of S2's with moisture block, but two pairs of new S2 sports sitting in front of me don't have it. I've got a couple sets of S2 Pros on the way (decided to go with the brighter light), so don't know if they have it.
    Is this something we are just getting on the "pro level" lights, or do I have an older set of S2 sports here that don't have it?
    Confused. It's not just a warranty thing, but also a performance thing. I don't want to throw on a costly set of lights to essentially bypass a performance feature of the light.
  7. Apr 15, 2019 at 11:56 AM
    #2247
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    You should be able to find spools of automotive wiring at Lowes or Home Depot. Last time I was at HD I recall seeing a few options (color and gauge).
    Squadron + S2 | 16
    XL80s, S8, OnX6 40" | 12
    Rock Lights | 18
    Depending on the length of wire you're running, you might need to upgrade the above. This is just what we recommend :)
    Baja Designs
    www.bajadesigns.com
  8. Apr 15, 2019 at 12:01 PM
    #2248
    Baja Designs
    San Marcos, CA
    My apologies about any confusion.
    You CAN cut the connector off without voiding your warranty. The moistureblock is located where the cord enters the housing of the light. Previous moistureblock designs had the block partway down the cord. This limited how much you could shorten the cord without voiding the warranty.
    Feel free to cut the connectors off and shorten the cord
    Baja Designs
    www.bajadesigns.com
    EatSleepTacos[QUOTED] likes this.
  9. Apr 15, 2019 at 12:11 PM
    #2249
    sagexp
    Back home, AZ
    Perfect, that explains it. Thanks!
  10. Apr 15, 2019 at 12:14 PM
    #2250
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    @Baja Designs Thanks for he feedback regarding the wire gauge.
    Here is another one for ya.
    Got a link to or thread in which people have shared how they mount the 40” or any size Onyx to behind the wind fairing?
    I have searched and I am coming up empty handed.
  11. Apr 15, 2019 at 12:19 PM
    #2251
    Baja Designs
    San Marcos, CA
    Which rack are you installing the 40" in? Prinsu/CBI? FrontRunner? Etc?
    Just want to make sure I post the right info :thumbsup:
  12. Apr 15, 2019 at 12:28 PM
    #2252
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Anyone in here running the LP9s on their truck for trail lights? I've been considering rigging up a set of ARB Intensity lights on the crossbar on my bumper but I've been so impressed with my Squadron Sports I'd love to stick with BD.
  13. Apr 15, 2019 at 12:30 PM
    #2253
    Built2Ride
    JB
    Southeast
    I am rolling a Prinsu, thought I had mentioned it, but I did not.
    Thanks in advance.
    JB
  14. Apr 15, 2019 at 1:04 PM
    #2254
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m not, but I’ve seen a set in person. They are HUGE and BRIGHT. I would go with those, hands down, over the arb. Even though I haven’t seen those in person.
    Gunshot-6A and Jibbs[QUOTED] like this.
  15. Apr 15, 2019 at 1:09 PM
    #2255
    Baja Designs
    San Marcos, CA
    I've definitely seen it done before but can't for the life of me find detailed photos. It appears the included OnX6 brackets will bolt right down to the crossbar. There is some adjustment in the included brackets. If the lightbar sits too low, you may need longer hardware and a spacer under the mounting brackets
    Baja Designs
    www.bajadesigns.com
  16. Apr 15, 2019 at 1:10 PM
    #2256
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    @Baja Designs any plans for a dual brightness amber rock light for use as a running light/turn? I’ve got a little project going that could really use some lol.
  17. Apr 15, 2019 at 1:13 PM
    #2257
    Baja Designs
    San Marcos, CA
    No plans at this time, sorry. I've seen them used as turn signals but not with a dim "running light" setting.
    Baja Designs
    www.bajadesigns.com
    DiamondW[QUOTED] likes this.
  18. Apr 15, 2019 at 1:14 PM
    #2258
    Built2Ride
    JB
    Southeast
    Yeah I looked as well. Could not find it.
    The brackets supplied would work, mounted to the top or bottom of the crossbar, but it would not line up with the light at cutout on the Prinsu. It would be sitting way above or below.
    It almost looks like a straight 90 degree L bracket would line it up straight off the front of the bar.
    Are you guys using DelCity Primary wire in your lights? Was thinking about just ordering wire from them.
  19. Apr 15, 2019 at 1:14 PM
    #2259
    DiamondW
    Kent
    Gonzales Co. TX
    I figured, but I can’t hurt to ask right? Thanks!
  20. Apr 15, 2019 at 1:16 PM
    #2260
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    @Baja Designs
    I saw that the squadron pro headlight and efi harness i ordered for my yz450f are backordered. Anyway i can get a leadtime on that?
