Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Sep 6, 2019 at 11:37 AM
    #2701
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    What is the amperage or wattage of the SAE Squads? I'm guessing they probably need a relay.
  2. Sep 6, 2019 at 1:13 PM
    #2702
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    1.6A each. A relay isn't required for the pair unless you're running a very long run of wire or a switch with a low amp rating
    genghis71 likes this.
  3. Sep 6, 2019 at 1:13 PM
    #2703
    genghis71
    genghis71 Well-Known Member
    2008 AC 4x4
    6112/5160
    It plugs right into the factory fog lighting. No additional relays/fuse needed, at least for mine. 22W/1.6A per BD website
  4. Sep 6, 2019 at 1:15 PM
    #2704
    Baja Designs
    San Marcos, CA
    Looking for something street-legal or a little bit more performance off-road?
    The Squadron SAE and Squadron Sport are great options
    jeff b[QUOTED] likes this.
  5. Sep 6, 2019 at 1:16 PM
    #2705
    Baja Designs
    San Marcos, CA
    Looks like he has a 2003 Tacoma, we don't make a plug and play kit for that year, he will have to wire them directly to the battery with a switch to activate
    genghis71[QUOTED] likes this.
  6. Sep 10, 2019 at 12:24 PM
    #2706
    Baja Designs
    San Marcos, CA
  7. Sep 12, 2019 at 1:00 PM
    #2707
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    @Baja Designs Do you have a sketch of the LP6s with dimensions including the bracket like you have for your other lights? I’m trying to figure out if I can put these on my bumper but have limited space.
  8. Sep 12, 2019 at 6:28 PM
    #2708
    andesite
    andesite creeper
    Brian
    Mosier, Oregon
    2.7L 5MT 2011 ACLB
    2.5” Radflo coilovers | Demello armor
    Baja Designs[OP] likes this.
  9. Sep 13, 2019 at 8:09 AM
    #2709
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Any recommendations for replacement switches? The original failed with the rocker portion separating. There is a standard non backlight version however that does not fit the same hole size or match the other bank of BD switches.
  10. Sep 14, 2019 at 11:12 AM
    #2710
    Baja Designs
    San Marcos, CA
    We offer a few different switches depending on the harness. Please call us or email info@bajadesigns.com
  11. Sep 14, 2019 at 11:12 AM
    #2711
    Baja Designs
    San Marcos, CA
    Designed from the ground up our new S1 fills the shoes of a large light in a small package! The S1 utilizes a highly specialized reflector and LED combination to outshine the competition. With the 2.1" length, width, and height the S1 is highly versatile for any application that is in need of light. Whether you're looking for a light to drive off of, or something to light up a campsite the S1 will exceed your expectations!
    Specifications:
    Lumens: 2,375 Utilizing 1 LED
    Wattage/Amps: 20W / 1.45A
    Dimensions: 2.1" x 2.1" x 2.1"
    Weight: 0.4 lbs
    LED Life Expectancy: 49,930 Hours
    Front Lens: Hard Coated Polycarbonate
    Housing: Hard Anodized & Powder Coated Cast Aluminum
    Bezel: Billet Machined Aluminum
    Hardware & Bracket Material: Stainless Steel
    Exceeds MIL-STD810G (Mil-Spec Testing)
    Built-In Overvoltage Protection
    IP69K (Waterproof up to 9ft & Pressure Washable)
    IK10 Compliant (Mechanical Impact Testing)
    CLICK HERE
    Gunshot-6A, EatSleepTacos and Rome604 like this.
  12. Sep 14, 2019 at 12:30 PM
    #2712
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    That's awesome.
  13. Sep 14, 2019 at 12:31 PM
    #2713
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Whats good with dem lasers meng!!!???
    Rome604[QUOTED] likes this.
  14. Sep 14, 2019 at 1:07 PM
    #2714
    Rome604
    Dave
    Alexandria, VA
    Arriving Tuesday per the tracking number. I bought a light meter to do some serious testing
    Gunshot-6A and Coot83[QUOTED] like this.
  15. Sep 14, 2019 at 8:15 PM
    #2715
    Coot83
    Scottsdale, Az
    2012 Baja TX
    :yes:
  16. Sep 15, 2019 at 3:54 PM
    #2716
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The more I'm looking at this, the more I'm digging it. These would be great little ditch lights.
    Gunshot-6A and Rome604 like this.
  17. Sep 15, 2019 at 4:03 PM
    #2717
    Rome604
    Dave
    Alexandria, VA
    Yes they would
    EatSleepTacos[QUOTED] likes this.
  18. Sep 15, 2019 at 5:43 PM
    #2718
    crux
    New Mexico
    OR
    I sent a photo by email with a bank of 3 red backlight switches. One is broken. Baja design sent a black switch with smaller diameter and no backlight. I don't want to fabricate a new bracket for mismatched switches
  19. Sep 15, 2019 at 8:02 PM
    #2719
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Night shot. PreRunning in Baja.
    EatSleepTacos likes this.
  20. Sep 16, 2019 at 10:01 AM
    #2720
    Baja Designs
    San Marcos, CA
    Looks fun!
