Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Sep 27, 2019 at 11:41 AM
    #2761
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Least you could do is clean your windshield. You animal :p
  2. Sep 27, 2019 at 11:44 AM
    #2762
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I kinda giggled when they illuminated the road sign up on the bridge. That sign is a long way away. Everyone on the bridge must of been like WTF?
    memario1214 and Gunshot-6A like this.
  3. Oct 1, 2019 at 12:50 PM
    #2763
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    That's what i tell people about my S8. "It's bright enough to make you laugh when you turn it on"
    memario1214 and Rome604[QUOTED] like this.
  4. Oct 2, 2019 at 2:22 PM
    #2764
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Looking to light up the job site?
    71180146_2850572841672385_18394240048431_7e54fa324d1681ab0382a478b8d0eea3a917577b.jpg
    This kubotausa excavator ready to rock and roll through the night! w.mcneice_site_services decked it out with x5 of our XL80 Work/Scenes. You could easily burn the midnight oil with this setup
    70234282_2850572861672383_43029549773928_8dd9e79d512748e445cbf86288e230817dc90679.jpg
    70915601_2850572898339046_73820937571910_1f1560d47f7219f126fc653f0f2a78b4fe586d1f.jpg
    71470225_2850572918339044_17631163044425_4ffe080036bbb2ae9073f33822e1e72ec540a1e2.jpg
    Order NOW
    Gunshot-6A likes this.
  5. Oct 8, 2019 at 8:58 AM
    #2765
    DrastikTRD
    DrastikTRD Well-Known Member
    @Baja Designs , So I am wanting to order and use the S2 Pro driving/combo lights as ditch lights mounted next to the hood and windshield. This is going on a 3rd gen Tacoma. My question is the included wiring harness would need to be extended to reach into the cabin driver side cubby switch area correct? This is where I would like the switch to turn off and on the S2 Pros.
    do you guys sell the extended harness for this mounting option?
    I have searched and watched videos on guys doing this but no one is really clear on how exactly this is extended to done. They just say extend the wires by splicing and re-connecting.
  6. Oct 8, 2019 at 9:21 AM
    #2766
    Rome604
    Dave
    Alexandria, VA
    It's probably long enough. You just need to get the switch connectors through the firewall. It's a lot easier to cut the wires, send it through and reconnect them.
  7. Oct 8, 2019 at 9:27 AM
    #2767
    DrastikTRD
    thanks Rome604...that makes sense regarding the switch connector wires.
    What worries me is the length of each wire coming from each of the S2 lights. If I mounted them on ditch light brackets and then run the wires along the firewall and into the cabin. This is where some splicing and re-connecting may have to occur.
    Rome604 likes this.
  8. Oct 8, 2019 at 9:32 AM
    #2768
    Rome604
    Dave
    Alexandria, VA
    I've got S2s on my ditch light brackets right now. The wires come from the S2s down under the hood into the engine compartment. There they use the weatherpack connectors to connect to the wiring harness that goes to the battery and through the firewall to the switch. It's pretty much plug and play with the exception of figuring out where to mount the switch and get those wires through the firewall.
  9. Oct 8, 2019 at 9:47 AM
    #2769
    DrastikTRD
    Awesome...thanks Rome604.
    So the included harness with the S2 Pro package is long enough i assume.
    I wonder why some youtube videos showed it being short and then them having to extend the wires. Strange.
  10. Oct 8, 2019 at 9:58 AM
    #2770
    Rome604
    Dave
    Alexandria, VA
    So I had an Baja Designs epiphany last night. @Baja Designs you can correct me if I'm wrong here.
    I've taken apart a lot of BD lights and I like to reverse engineer stuff. Though I'll admit, I could have easily gotten this wrong. Baja Designs pretty much has 3 different LEDs in their lights. A 6W, a 12W and a 20W. They then have two size reflectors (small and large). So it pretty much breaks down like this.
    S1
    1X 20W and Large reflector
    S2 Sport
    2x 6W and small reflectors
    S2 Pro
    2X 12W and small reflectors
    Squadron Sport
    4X 6W and small reflectors
    Squadron Pro
    4X 12W and small reflectors
    XL Sports
    4X 6W and Large reflectors
    XL Pro
    4X 12W and Large reflectors
    XL80s
    4X 20W and Large reflectors
    S8 per 10"
    2X-12W and 6X-6W and small reflectors
    OnX6+
    4X-20W and 2X-12W and Large reflectors
    As you can see from the list, even the more budget friendly lights out perform most of the other LED companies. Most other LED companies will list a 5W CREE LED as used in their build. Even these 5W LEDs aren't running at 100% either. If you've never seen the 20W BD LED...it is massive.
    Just thought this was cool and worth sharing.
    Steelhead Taco likes this.
  11. Oct 8, 2019 at 10:01 AM
    #2771
    Rome604
    Dave
    Alexandria, VA
    Probably depends on the switch placement in the cab. If you put it in the center console you'll need to extend the wires. Luckily it is very easy to crimp or solder in some extensions.
    There's three wires going to the switch. Get three equivalent gauge wires the length of the extension. Cut the switch off. Crimp or solder the extension onto the harness. Feed the extension through the firewall. Crimp or solder the extension back onto the switch.
  12. Oct 8, 2019 at 11:37 AM
    #2772
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I feel like we need to have an intervention for you soon about your obsession with BD.
  13. Oct 8, 2019 at 11:49 AM
    #2773
    Rome604
    Dave
    Alexandria, VA
    :help:
  14. Oct 8, 2019 at 11:55 AM
    #2774
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    WHAT IS THAT EVEN FOR DAVE
  15. Oct 8, 2019 at 11:56 AM
    #2775
    Rome604
    Dave
    Alexandria, VA
    I'M SCARED OF THE DARK!!!!
  16. Oct 8, 2019 at 12:02 PM
    #2776
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I hope I don't get to that level... I really don't...
    But its kinda tempting...
    EatSleepTacos[QUOTED] likes this.
  17. Oct 8, 2019 at 12:03 PM
    #2777
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Agreed, lets youtube this session.
  18. Oct 8, 2019 at 1:16 PM
    #2778
    genghis71
    genghis71 Well-Known Member
    2008 AC 4x4
    6112/5160
    :spy:
  19. Oct 8, 2019 at 1:18 PM
    #2779
    Rome604
    Dave
    Alexandria, VA
    It was a tight fit! Since I used security hardware I had to get creative on the order I installed the bracket. Thanks again for the light bar!
    genghis71[QUOTED] likes this.
  20. Oct 8, 2019 at 1:20 PM
    #2780
    genghis71
    2008 AC 4x4
    6112/5160
    It looks great. Sorry to have fed your addiction tho. Guessing I'd be just as guilty in the intervention video.
