Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Nov 13, 2019 at 6:27 AM
    #2861
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I had mine there until they got moved to the roof rack. Only thing I noticed was that you need solid mounting brackets. I have CaliRaised A Pillar mounts and I noticed the lights would vibrate slightly. Normally thats not a big deal but since the XL80 project light such a far distance, it means your spot is bouncing up and down. I was thinking of upgrading to the SDHQ mounts since they 'appear' to be a stronger design.
    I wouldn't suggest having two different lens patterns for your ditch lights. In my experience that would look super weird when you actually have them on. Anything that's a SPOT lens looks 'powered off' when it's next to the XL80 driving combo. This is because the XL80 cranks out so much light that it doesn't matter where you stand, you're getting lit up. The spot lens is only intense when you are looking directly into the beam.
    I can highly recommend the XL80s if it's in your budget. They are not "too" big for the A pillar location. If you want to try something new.....I'd suggest waiting for the LP4s to be released. They look bad ass and will have side projecting LEDs. If BD follows their current lighting structure then the LP4s will be labeled as Pros and should have more output then the Squadron Pros. And they look badass which is always a plus if you're spending this kind of money.
    memario1214 and Gunshot-6A like this.
  2. Nov 13, 2019 at 1:30 PM
    #2862
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I've got Squadron Pros Spots on CBI ditch mounts, I appreciate that they are smaller and low key until they are switched on.. Spots worked better for me to minimize hood glare than combo lenses in that spot.. Keep in mind I use them as driving lights facing forward and not necessarily ditch lights off to the side.
  3. Nov 13, 2019 at 9:24 PM
    #2863
    virvak2
    virvak2 Well-Known Member
    Kyle
    Castle Rock
    '13 TRD Off-Road
    I have some cheap lights on ditch light brackets now, and also use them as driving lights. Hence why I am looking at the XL80s to throw alot more light. Do the spots lights up anything on the side of the trail or are they pretty much dead on ahead.
  4. Nov 14, 2019 at 8:11 AM
    #2864
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Spots are pretty much straight ahead, I've got Combo Sports in the fog pockets for fill up front.
    Stock highbeams/+Yellow Sport Combo/+Pro Spot;
    The trees in the back are more than 1km away.
    Beretta4x4 likes this.
  5. Nov 14, 2019 at 8:25 AM
    #2865
    michael ray
    michael ray Member
    mike
    Katy,TX
    2017 TRD Pro
    Im not that much of a potato, and again the BD harness only has 2 wires to the switch from the relay. Ill try to get pics after work...
  6. Nov 14, 2019 at 8:52 AM
    #2866
    Rome604
    Dave
    Alexandria, VA
    There must not be a LED 'on' light included in the BD switch. So it literally just opens/closes the circuit. Those two BD wires would connect to the Green and Red 1 on your Caliraised switch. Then you'll need to connect the black on the Caliraised switch to ground (if you want the internal switch lights to work).
    I'm glad you're not a potato. Post up the pictures to verify the online advice you're requesting is accurate.
    Gunshot-6A and Beretta4x4 like this.
  7. Nov 14, 2019 at 2:24 PM
    #2867
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @Nunya Bizness is heavily involved with potatoes, I'm sure he could be our expert testimony for the TW jury.
    Rome604[QUOTED] likes this.
  8. Nov 14, 2019 at 2:32 PM
    #2868
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    ftfy
    Rome604 and Gunshot-6A[QUOTED] like this.
  9. Nov 14, 2019 at 2:39 PM
    #2869
    Gunshot-6A
    Conner
    Everett, WA
    Rome604 likes this.
  10. Nov 14, 2019 at 2:51 PM
    #2870
    Gunshot-6A
    Conner
    Everett, WA
    @Rome604 how do I get your BD referral code so you get points? Your words a while back convinced me to go get some WC S1s for ditch purposes.
    Rome604 likes this.
  11. Nov 14, 2019 at 2:53 PM
    #2871
    Rome604
    Dave
    Alexandria, VA
    That's a good idea! @Baja Designs can you hook me up with a referral code?
    Gunshot-6A[QUOTED] likes this.
  12. Nov 14, 2019 at 2:57 PM
    #2872
    Gunshot-6A
    Conner
    Everett, WA
    I thought you had an account or whatever already? I remember you talking about points for an XL80 or something.
    Only gonna use it if you declare me your best friend :D
  13. Nov 14, 2019 at 2:59 PM
    #2873
    Rome604
    Dave
    Alexandria, VA
    Oh that's my Southern Style Offroad referral code. It's in my signature.
  14. Nov 14, 2019 at 4:19 PM
    #2874
    tacoooking
    tacoooking Well-Known Member
    Dana Point, CA
    2016 TRD Off-Road
    Anyone know how to wire a 10" S8 bar into the factory fog harness? Is there a way to do it plug n play?
  15. Nov 14, 2019 at 4:23 PM
    #2875
    Rome604
    Dave
    Alexandria, VA
  16. Nov 14, 2019 at 4:28 PM
    #2876
    tacoooking
    Dana Point, CA
    2016 TRD Off-Road
  17. Nov 14, 2019 at 4:41 PM
    #2877
    Rome604
    Dave
    Alexandria, VA
    If you buy a female weatherpack connector, it will.
    The only function you'll lose is the amber back lighting. That's on a third wire and you would need to connect it to your DRL or a switch (or nothing if you don't care).
    You don't need a 20 pack...just one.
    https://www.ebay.com/ulk/itm/322124172864
  18. Nov 14, 2019 at 4:44 PM
    #2878
    tacoooking
    Dana Point, CA
    2016 TRD Off-Road
    and then it will be 100% plug n play?
  19. Nov 14, 2019 at 4:46 PM
    #2879
    Rome604
    Dave
    Alexandria, VA
  20. Nov 14, 2019 at 4:48 PM
    #2880
    Rome604
    Dave
    Alexandria, VA
    What's your definition of plug and play? You won't be cutting any wires the first way I described, but you'll still need to have the knowledge of which wires go where. It won't be like plugging a light into an electrical socket and turning it on.
