Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Nov 21, 2019 at 4:59 AM
    #2901
    Jnull
    Jnull Well-Known Member
    4 cummins trucks!
    i figured it was something like that since they’re “backordered” across the board. Strange a company like BD would label and sell something as SAE compliant without actually being.
    do you know if the fix will hinder performance from the current version? Might be worth picking up a set in stock somewhere if that’s the case.
  2. Nov 21, 2019 at 11:42 AM
    #2902
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I’d like to see some beam shots of the S1 spots. I’m looking for something to supplement my S8 20” driving/combo and squadron sports for longer distance but don’t have a ton of room for the bigger lights. I’m thinking a couple S1s on the bumper would give me a little more distance.
  3. Nov 24, 2019 at 9:11 PM
    #2903
    Jaybridge88
    Jaybridge88 Member
    San Diego
    2019 DCLB TRD OR
    I started installing my ditch lights. The harness that came with the lights doesn’t seem to be long enough. Does BDs sell an extension that can be plugged in to lengthen one side of the harness?
  4. Nov 25, 2019 at 6:19 AM
    #2904
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Looks like they’re back on for sale.
  5. Nov 25, 2019 at 7:55 AM
    #2905
    Jnull
    4 cummins trucks!
    BDs website still says
    THIS LIGHT IS CURRENTLY BACKORDERED WITH NO ESTIMATED SHIP DATE”
    Rustytaco71[QUOTED] likes this.
  6. Nov 25, 2019 at 8:04 PM
    #2906
    Jnull
    4 cummins trucks!
    What’s everyone using for a-pillar mounted ditch lights? With everything else that’ll be going on my truck I really don’t “need” them but can’t resist taking advantage of the Black Friday discount so I’m going to get some squadron sports for ditch lights.
    I have a road armor with 4 pockets, 2 will be getting sae fogs, the other 2 will probably get squadron pros and I have a 40” onx6 hi power combo beam I’ll be welding brackets on for.
    I guess the short of it is should I go with combo or spot pattern for squadron sport ditch lights?
  7. Nov 27, 2019 at 1:34 AM
    #2907
    thedzeffect
    thedzeffect Well-Known Member
    Danny
    Bridgetown
    14' DCSB TRD OR 2WD, 18 DCSB TRD OR 4X4
    The driver.
    @Baja Designs im trying to wire up my s2 sports as chase lights but the harness I bought with the relay is really short do I have extend the wire? And is their cons? Or it should it would fine since one wire is shorter than the other I am going to have to make both the same length sorry for the dumb question
  8. Nov 27, 2019 at 1:29 PM
    #2908
    Jnull
    4 cummins trucks!
    Anyone think the XL sports are worth the added cost over the squadron sports?
  9. Nov 27, 2019 at 1:35 PM
    #2909
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    This should solve your problem
    https://www.bajadesigns.com/products/squadron-s2-wire-harness-splitter-55-universal.asp
    Depends. At the end of the day a larger reflector will provide greater realized light output. Are you space limited whatsoever?
  10. Nov 27, 2019 at 1:40 PM
    #2910
    Jnull
    4 cummins trucks!
    no they’re going on the a pillars of my 16 ram 3500, I asked about the best pattern a couple posts up. I can’t find any info wether the output is noticeably different with the two lights
  11. Nov 27, 2019 at 1:55 PM
    #2911
    memario1214
    Colton
    Missoula, MT
    Is it noticeably different? Yes.
    However, do I "personally" believe that it is worth the additional cost associated with them to get the larger reflector? That's a negative. Now, if you were asking if you should buy a set of XL80s to make use of the additional size and lumen output... That would be a HARD Yes.
  12. Nov 27, 2019 at 2:07 PM
    #2912
    Jnull
    4 cummins trucks!
    for sure XL80s would rock but with everything else i have going on up front (40” hi power combo, squadron pro combo x2, and squadron sae x2) I cant justify spending that much. I guess for a few bucks more the squadron pros would probably be a better buy then XL sports.
    but for the cost and only wanting them for a true ditch light, not down road lightning I think the squadron sports will be hard to beat. I just need to decide on combo or spot beam
    Rome604 likes this.
  13. Nov 27, 2019 at 7:08 PM
    #2913
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    If you want them as true ditch lights then don't get the spot. I'd recommend wide cornering or work scene as a second for the Squadron Sports. If you get the pure beef XL80S then driving combo.
    The Squadron Sports have a lot less output than the XL80s so you need to use the light you have closer to the vehicle. The XL80s crank out so much light that you can afford to get the best of both worlds.
    If you were going to honestly look at the XL80s then I'd encourage you to check out the new LP4s. They have side shooter LEDs and would work great as ditch lights.
  14. Nov 27, 2019 at 7:11 PM
    #2914
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Squadron pros on a dimmer.
  15. Nov 27, 2019 at 7:35 PM
    #2915
    Jnull
    4 cummins trucks!
    im definitely not getting XL80s, I also thought LP4s would be awesome ditch lights but for the same reason as the XL80s (cost) I won’t be going with those either.
    I really don’t need any extra lighting but feel compelled to take advantage of the Black Friday rebate and only have pro series lights so figured I’d pick up a set of sports. I was concerned wide cornering might put too much light onto the hood?
  16. Nov 27, 2019 at 7:37 PM
    #2916
    Rome604
    Dave
    Alexandria, VA
    The Squadron Sports are definitely the best bang for the buck in the rebate program. If that's your motivation.
    How are you going to angle them? Straight forward? Then yes. Down and out? No
  17. Nov 27, 2019 at 7:40 PM
    #2917
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I know someone just giving away some squadron sports if you’re interested
  18. Nov 27, 2019 at 7:42 PM
    #2918
    Rome604
    Dave
    Alexandria, VA
    Who's dat?
  19. Nov 27, 2019 at 7:42 PM
    #2919
    Jnull
    4 cummins trucks!
    my thoughts exactly, for $150ish I see no reason not to try them. Also getting 2 pairs of SAEs to get the most out of the rebate.
    I’ll probably angle them slightly out towards the sides and not down but perpendicular to the road. My thought is to light up the woods in front of me on narrow 2 lane highways. Lots of deer and elk
  20. Nov 27, 2019 at 7:43 PM
    #2920
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Rome604
