Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Jan 16, 2020 at 12:10 PM
    #3141
    Nick'sblue4x4
    Nick'sblue4x4 Well-Known Member
    Nick
    08 speedway blue TRD sport
    Supercharged, completely upgraded sound system, DVD players, camper shell, police scanner
    I want to put them on a triumph Tiger 800, another question would be if there is a specific switch needed to turn on the different modes for the lp4? I might just get the squadrons!
  2. Jan 20, 2020 at 12:38 PM
    #3142
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    No specific switch needed. The harness we sell features a simple on/off switch. The lead for amber backlit left bare so that use can use our included components to tie into running/parking lights, or alternative solutions you may use (wire into switch, etc.)
    Gunshot-6A likes this.
  3. Jan 20, 2020 at 12:41 PM
    #3143
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    @Baja Designs you got Jeff's email / contact info
    He took my CC information and what not for that spacer kit for demello bumper the 7 of Jan but I never received anything.
  4. Jan 20, 2020 at 12:44 PM
    #3144
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I'd be willing to bet it's Jeff@bajadesigns.com They are super originial in the email set up.
  5. Jan 20, 2020 at 12:45 PM
    #3145
    Superman910
    Eric
    Northern Virginia
    well Jeff let me down....
  6. Jan 20, 2020 at 12:45 PM
    #3146
    Rome604
    Dave
    Alexandria, VA
  7. Jan 20, 2020 at 12:46 PM
    #3147
    Superman910
    Eric
    Northern Virginia
    Gunshot-6A and Rome604[QUOTED] like this.
  8. Jan 20, 2020 at 12:48 PM
    #3148
    Rome604
    Dave
    Alexandria, VA
    I only have his contact because he's been dealing with the SAE fog mess.
  9. Jan 20, 2020 at 12:55 PM
    #3149
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    or Joffrey?
    Rome604 likes this.
  10. Jan 20, 2020 at 1:01 PM
    #3150
    Superman910
    Eric
    Northern Virginia
    He might be feeling like that based on
  11. Jan 22, 2020 at 7:28 AM
    #3151
    Rome604
    Dave
    Alexandria, VA
    So I took my flir camera to check my truck wiring and found something interesting. (It was a cold day)
    This is my roof rack after being on for a few minutes. You can tell that the two pairs of lights on either end are the 80 watt XL80s and then it's the 40 watt XL Pros and in the very middle it's the 60 watt XL Lasers. Each puts out a corresponding temperature.
    None of them get super hot, it's just interesting to actually see the 80 watt lights putting out more heat than the 40 watt lights. Exactly as you'd expect to see.
  12. Jan 27, 2020 at 10:39 AM
    #3152
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    @Baja Designs , Curious if some squadron sports could be run as strobes (via a controller and relays). Any concern with the quick on/off/on/off flashing on the lights leds and/or circuitry?
  13. Jan 27, 2020 at 10:42 AM
    #3153
    Gunshot-6A
    Conner
    Everett, WA
    Anecdote of one: I use my squadrons (and RTL) as strobes / flashers via my switchpro a fair amount and don't see any sort of negative to it so far. Had them a few years now.
    EatSleepTacos likes this.
  14. Jan 27, 2020 at 10:45 AM
    #3154
    YF_Ryan
    Kent, WA
    Thanks for the reply! Do you know if a standard automotive relay cycles quick enough to strobe based on the signal from a controller, or if you have a specific strobe relay? I don't know my relays. Or if there even is such a thing. Haven't done too much googling yet. Just thought about while looking into purchasing some BD ambers for my bumper.
    Gunshot-6A[QUOTED] likes this.
  15. Jan 27, 2020 at 10:53 AM
    #3155
    Gunshot-6A
    Conner
    Everett, WA
    Switchpro / SPOD have a strobe function built into their controller. IDK about a mechanical relay.
    Demo of switchpro (pre squadrons, but its the same for them now). All BD except the front bar.
    https://www.instagram.com/p/BmHKilOhgVS/?utm_source=ig_web_copy_link
    YF_Ryan[QUOTED] likes this.
  16. Jan 27, 2020 at 10:57 AM
    #3156
    YF_Ryan
    Kent, WA
    Very nice. I was thinking all white BDs originally, but being double duty with strobe function the Amber is sounding better and better.
  17. Jan 27, 2020 at 11:03 AM
    #3157
    Gunshot-6A
    Conner
    Everett, WA
    Helping with offroad races and general roadside duty, the white side lights and the white/amber chase bar come in clutch. Unless you are right up on me, I look like one of those DOT trucks.
  18. Jan 27, 2020 at 11:12 AM
    #3158
    Rome604
    Dave
    Alexandria, VA
    A standard relay will burn out if it is used as a strobe. It'll have an audible "chatter" and will eventually fail.
    YF_Ryan likes this.
  19. Jan 27, 2020 at 11:22 AM
    #3159
    Baja Designs
    San Marcos, CA
    No concerns here. Many Switch.Pros and sPOD users routinely enjoy this feature. Those would be the two units I recommend, having used both and knowing the quality. There are cheap flasher modules available, or even cheap switch units, but I cannot recommend any based on personal use.
    Gunshot-6A and YF_Ryan[QUOTED] like this.
  20. Jan 27, 2020 at 11:22 AM
    #3160
    YF_Ryan
    Kent, WA
    Thanks for the input. This is the kind of information I was looking for. I definitely wouldn't be using them much. I'm in a Search and Rescue unit and in the past year I've probably used my current strobes for less than 24 hours total. Just thinking if I'm wiring in some driving lights, why not add another relay to make them strobe. Looks like a solid state relay is about 4-5 times as expensive, but still only $20-25.
