Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Feb 10, 2020 at 4:42 PM
    #3181
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    The hardware is actually a different size and is currently in development. Hoping to have something in the next month or so, but I have not received a hard timeline yet.
    Gunshot-6A[QUOTED] likes this.
  2. Feb 10, 2020 at 5:42 PM
    #3182
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    What's the thread/pitch?
  3. Feb 12, 2020 at 10:55 AM
    #3183
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @Baja Designs If I were to mount a squadron pro off the side of my side of my roof rack, can I rotate the driving combo lenses 90* so they are in the correct orientation and maintain the seals?
  4. Feb 12, 2020 at 11:00 AM
    #3184
    Rome604
    Dave
    Alexandria, VA
    Yes
  5. Feb 12, 2020 at 11:02 AM
    #3185
    Gunshot-6A
    Conner
    Everett, WA
    Most excellent.
    Rome604[QUOTED] and FishnTx like this.
  6. Feb 13, 2020 at 8:51 PM
    #3186
    hailo
    hailo Well-Known Member
    Anthony
    2019 White Tacoma 4WD TRD Off Road
  7. Feb 14, 2020 at 12:06 PM
    #3187
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    Anyone running a 3rd gen with Squadron Pros in the fog light location on stock wiring? Was wondering if I have to run this to my switch pro or not.
  8. Feb 14, 2020 at 12:11 PM
    #3188
    Rome604
    Dave
    Alexandria, VA
    I do not have Squadron Pros in my fog location, however, you should be good. The Pros are 40W or 2.9amps a piece. Your stock fogs are 50W (I think). Halogen has a much higher draw than LED.
    awwbugman[QUOTED] likes this.
  9. Feb 14, 2020 at 1:13 PM
    #3189
    awwbugman
    Awesome, thank you very much!
    Rome604[QUOTED] likes this.
  10. Feb 16, 2020 at 1:09 PM
    #3190
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    You’ll have more flexibility running them to your Switch Pro. Mostly being able to run them with your brights.
  11. Feb 17, 2020 at 7:36 PM
    #3191
    xrmitchell
    xrmitchell Well-Known Member
    co
    Jvc head unit, K&N, BOHM
    @Baja Designs so I’ve been looking at your dome light for rear lighting in my topper. On you website it says 400 lumens, where all the others places I’ve seen say 200. Is there a new model?
  12. Feb 18, 2020 at 2:10 PM
    #3192
    Baja Designs
    San Marcos, CA
    We updated our dome and rock lights from 200 lumens to 400 lumens about a year ago. I would verify with the dealer and make sure that their inventory is not older than 1/1/19. The date of when the light was built will be on the back of the light. :thumbsup:
  13. Feb 18, 2020 at 2:13 PM
    #3193
    Rome604
    Dave
    Alexandria, VA
    I got a rock light from Amazon warehouse that the resin back is gooey and sticky. It almost looks like someone put paint thinner or something on it. It's not your problem because it was bought "used" but I was planning on scooping some of the soft stuff out and sealing it with jb weld. Do you think that's a good idea? Or should I look at doing something different?
  14. Feb 18, 2020 at 2:26 PM
    #3194
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah, a handful of the rock lights that I purchased in bulk had a similar backing to what you explain. It seemed to be isolated to like 1 month's production... I would probably personally scoop the goop out and go back in with like a non-corrosive RTV silicone. You could go with JB Weld I guess though. It honestly doesn't have the worst thermal properties.
  15. Feb 18, 2020 at 2:49 PM
    #3195
    Rome604
    Dave
    Alexandria, VA
    Ok thanks for the idea. I'll try that unless BD comes back with something different.
  16. Feb 18, 2020 at 6:30 PM
    #3196
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    For squadron pros as ditch lights which lens is preferred? Wide cornering, or driving combo?
    I see a lot of people running the driving combo, but they are usually pointed straight ahead and level...if you have them angled and pointed somewhat down (the proper way) then the spot beam doesn’t make sense (at least in my mind), right?
    I’ll have 4 S1’s in my front bumper acting as “fog lights”, since I cannot fit anything larger than the S1’s...eventually I’ll have a pair of LP9 Pros mounted up front as well.
  17. Feb 19, 2020 at 12:11 PM
    #3197
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    Does the lifetime warranty apply to foglights purchased second hand? And are there replacement bulbs/parts if the LED's burn out or the lights crack?
    Thanks!
    Gunshot-6A likes this.
  18. Feb 19, 2020 at 12:14 PM
    #3198
    Gunshot-6A
    Conner
    Everett, WA
    Original owner only
    https://www.bajadesigns.com/help/warranty-policy.asp
    As far as replacement parts, you can the different plastic lenses, but the bulbs are soldered to the board. Thats not exactly end user maintenance.
  19. Feb 19, 2020 at 2:38 PM
    #3199
    Baja Designs
    San Marcos, CA
    That wouldn't be considered normal, PM inbound.
  20. Feb 19, 2020 at 2:43 PM
    #3200
    Baja Designs
    San Marcos, CA
    For a ditch light application, we recommend using a wide cornering lens as it features a 42 degree flattened beam pattern. Your thinking makes perfect sense. :)
