Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Mar 9, 2020 at 10:14 AM
    #3241
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    You might be able to find some at a local hardware store, but we're always willing to send some out if a customer needs it.
    lynyrd3 likes this.
  2. Mar 10, 2020 at 1:47 PM
    #3242
    Baja Designs
    San Marcos, CA
    The Rockstar Garage grabbed some clean shots of this second gen Taco out in KOH 2020! Rocking a 20" S8 light bar behind the bumper, a few pairs of Squadrons, and a pair of S2s.
    :burnrubber:
    lynyrd3 likes this.
  3. Mar 20, 2020 at 12:28 PM
    #3243
    Baja Designs
    San Marcos, CA
    COVID-19 Notice:
    March 19th, 2020:
    CA State Governor Gavin Newsom has issued a "stay home order" to all California residents. Baja Designs has temporarily paused most operations until further notice from the State.
    Select departments will continue to work from home and can be reached through their normal email addresses.
    We are doing everything possible to fulfill orders at this time. The health and safety of our employees, partners, and customers is of the highest concern to us and we thank you for your patience during these unsettling times.
    We'll be back soon! ♥️
    lynyrd3, EatSleepTacos and Rome604 like this.
  4. Mar 20, 2020 at 12:32 PM
    #3244
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Stay safe. People can wait for lights.
    Gunshot-6A and lynyrd3 like this.
  5. Mar 26, 2020 at 1:37 PM
    #3245
    ShowstoppersUSA
    ShowstoppersUSA ShowStoppers Offroad
    Glendale, Ca
    Here was a fun little project we did :D
    40" Onx6+ Spot
    S2 Pro Wide Corner
    x5 Lp4 Driving Combo
    20" S8 Driving Combo
    Squadron Sport WC
    Also not pictured is
    x2 Rock Lights - scene/wheel well
    S1 Work Scene - scene
    S2 Sport Spot - chase
  6. Mar 26, 2020 at 1:43 PM
    #3246
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If hood glare is too bad I found a very simple fix is just move the light back a few inches. Made it go from totally unuseable to the best light ever. This is an S8 in all spot.
  7. Mar 26, 2020 at 1:52 PM
    #3247
    ShowstoppersUSA
    Glendale, Ca
    Definitely a good move! I did recommend him to mount it further back, similar location to where you had it mentioned. I definitely wanted to play around with his setup out in the desert to aim lights and change out a couple lens'!
  8. Mar 26, 2020 at 3:11 PM
    #3248
    Baja Designs
    San Marcos, CA
    Those LP4s fit nicely in that bumper! Thanks for sharing. :)
  9. Mar 26, 2020 at 4:47 PM
    #3249
    Baja Designs
    San Marcos, CA
  10. Mar 29, 2020 at 7:19 PM
    #3250
    xrmitchell
    xrmitchell Well-Known Member
    co
    Jvc head unit, K&N, BOHM
    @Baja Designs So I have a set of S1 lights my setting up for my Ditch Lights. I know it has been mentioned but I didn’t find a solution I was sure about. They are grounding to the ditch light brackets I believe. If I connect just the positive wire the lights will turn on. Is this an issue for them to be double grounded? I saw maybe cut the negative wire, and I saw isolate the lights from the mount using a rubber washer.... I wasn’t sure the correct solution.
  11. Mar 30, 2020 at 4:55 AM
    #3251
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My OnX6+ is like that as well. I have it positive and ground both connected through the harness, and have for awhile, no issues.
  12. Mar 30, 2020 at 9:24 AM
    #3252
    Baja Designs
    San Marcos, CA
    The way our lights are designed, the circuit board is grounded out through the housing. In a situation where customers mount their lights on a metal bumper or mount, it will turn on the light when just the power wire is hooked up. This does NOT damage the light, and would be considered a normal reaction. We always recommend grounding out the black wire so we ensure the ground is strong and we don't run into issues down the road (dirty ground, corrosion, etc.).
  13. Mar 30, 2020 at 10:06 AM
    #3253
    xrmitchell
    co
    Thank you just making sure I’m not popping fuses.
  14. Mar 31, 2020 at 2:36 PM
    #3254
    Baja Designs
    San Marcos, CA
  15. Apr 5, 2020 at 4:27 PM
    #3255
    pc3coyote
    pc3coyote www.pc3coyote.com
    Paul
    SoCal
    17 BBP Sport DCSB 4x4
    I added all the @Baja Designs lumens back in October :D
    Big shoutout to Chuck at @ShowstoppersUSA for the great prices and awesome customer service! I definitely recommend you reach out to him for part needs.
  16. Apr 6, 2020 at 9:24 AM
    #3256
    Baja Designs
    San Marcos, CA
    :woot:All the lumens!
    lynyrd3 and pc3coyote like this.
  17. Apr 6, 2020 at 9:30 AM
    #3257
    pc3coyote
    Paul
    SoCal
    Full spaceship mode at this point :rofl:
  18. Apr 7, 2020 at 4:33 PM
    #3258
    Baja Designs
    San Marcos, CA
    For those Tacoma owners, that own a Polaris RZR! Here's a new product drop. :)
    NEW PRODUCT ANNOUNCEMENT
    Polaris RZR Turbo/S 16+, XP1000 14+, XP900 15+, 30” Roof Mount Kits
    Introducing a clean and simple bolt on solution for the Polaris RZR Turbo S (18-On), Turbo (16-On), RZR XP 1000 (14-On), and RZR XP 900 (15-On). Our standard light bar brackets line up perfectly to the Turbo S OEM roof mounting locations, so this will be a big seller based on the user-friendly installation and price point. This kit comes plug and play with all the necessary hardware components, wiring harnesses and light bar. For the S8 option, we will be including a Polaris RZR specific add-on wiring adapter that will enable users to activate the amber backlit LEDs with a keyed power source. Service technicians and DIY customers alike can breathe a sigh of relief with this race ready light bar setup.
    Configurations:
    44-7181 | Polaris RZR Turbo/S 16+, XP1000 14+, XP900 15+, 30" S8 Kit, Retail: $919.95
    44-7182 | Polaris RZR Turbo/S 16+, XP1000 14+, XP900 15+, 30" OnX6+ Kit, Retail: $1,149.95
    ShowstoppersUSA and Rome604 like this.
  19. Apr 7, 2020 at 5:19 PM
    #3259
    ShowstoppersUSA
    Glendale, Ca
    Glad we could assist! It came out awesome!
  20. Apr 10, 2020 at 8:59 AM
    #3260
    Eastcoastin
    Eastcoastin Well-Known Member
    Oahu/San Diego
    TRD Sport DCSB 4x4 V6
    Pelfreybilt Baja Designs errythang, 20” Onyx6, S2 Sports, & Squadron Pros King 2.5 Resis w/700 springs/Rear 2.5/12" ALCAN Leaf Springs Total Chaos (Rear Relocation, UCA, spindle gussets, LCA skids) Archive Hangers/shackles Toyo 285/75/17 MTs VTX Rogues InSight RetroFits Leer x100 Camper Custom Car Grills thin lip mesh grill mod w/braptor light mod Tail pipe chop
    Anyone have any tips on making your own harness for a Onx6 20” bar? Wiring it to an Spod if that helps. Mostly wondering about wire gauge.
    Baja Designs[OP] likes this.
