Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. May 4, 2020 at 11:25 AM
    #3301
    xx3xil3xx
    xx3xil3xx Well-Known Member
    ESCONDIDO/SAN DIEGO, CA
    06 runner
    PM'D YOU
  2. May 4, 2020 at 1:24 PM
    #3302
    CharleyAirborne
    CharleyAirborne Arctic Nomad
    Anchorage, AK
    2018 Blazing Blue Tacoma TRD Off Road 6MT
    Stock...for now
  3. May 4, 2020 at 1:40 PM
    #3303
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    If you're using a Switch-Pros, there will be components (ring terminals, relay, switches) of the harness that you won't use anymore. The switch panel simplifies everything and allows the user to hook up their accessories by simply finding the power and ground. Off the harness, there should be a loom with three wires. A white, green, and black. White is power for the main light (+), green is for back light (+), and black is ground (-). The 40" S8 does pull 16.23 amps. If you've already installed everything, you can leave it and hook up the wire (yellow). It will just be redundant. The yellow wire is what turns on power to the main light. That will be hooked up to your Switch-Pros.
  4. May 5, 2020 at 10:06 AM
    #3304
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @Baja Designs do you know the length of the wire in the below harness? My homemade one isn't as big a gauge as I thought and I'm tripping the breaker on my switchpros all the time. I think mine is about 6 feet, but didn't wanna come up short with this one. Way cheaper than having to buy a whole roll of trailer cable from the guys down the street.
    Baja Designs[OP] likes this.
  5. May 5, 2020 at 10:28 AM
    #3305
    Baja Designs
    San Marcos, CA
    6 feet, it's a pretty beefy size wire too. 12 gauge on the ground and main power lead. Shoot me a PM if you need something longer, I can see what I can do. :thumbsup:
    Gunshot-6A[QUOTED] likes this.
  6. May 5, 2020 at 10:30 AM
    #3306
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    do you have it on one of the 35a switches? a 40” draws almost 27amps
    you would need to use 10awg for the wiring. Might could get by with 12awg if you kept it to less than 6ft run.
  7. May 5, 2020 at 11:26 AM
    #3307
    Gunshot-6A
    Conner
    Everett, WA
    BD quotes the 40" at 240W which is 20A at 12V. I'm def at the very edge of the 20A circuit (Sw1), and was gonna move it anyways. I thought my wiring was 14ga which is fine per USCG critical wiring charts at <6ft, but its actually 16ga. Figured I'd make it more robust while I was changing things around anyways.
  8. May 5, 2020 at 11:46 AM
    #3308
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I had to go through and beef up some of my harnesses since I keep adding lights. My roof rack got split up into three 12 gauge leads and three relays. They get triggered together but I didn't want that much juice running off one wire/relay.
  9. May 12, 2020 at 5:06 PM
    #3309
    Baja Designs
    San Marcos, CA
    Taco Tuesday! :hungry:
    Gunshot-6A and Rome604 like this.
  10. May 20, 2020 at 10:45 AM
    #3310
    Baja Designs
    San Marcos, CA
    For those Tacoma owners that may have a (19-on) KTM 790, we just released a new kit!
    NEW PRODUCT ALERT: KTM 790 (19-On), Dual Auxiliary Light Kits
    Spice your KTM 790 up with a lighting kit from Baja Designs! This kit includes everything you need such as wiring, lights, bracketry, and hardware. This kit utilizes our S1 series or Squadron series, and will provide ample performance for any adventure you're on. Installation is a breeze, and the fitment is second to none!
    387001 | KTM 790 (19-On), Dual S1 Kit
    497004 | KTM 790 (19-On), Dual Squadron Pro/Racer Kit
    Rome604 likes this.
  11. May 27, 2020 at 2:18 PM
    #3311
    jackbauer01
    jackbauer01 Well-Known Member
    What is everyone's thoughts on running the squadron pro round version as ditch light..lame.? or should I get the square version?
    I dig the round look, but tough time finding anyone that runs the r version as ditch lights. Bad idea?
  12. May 27, 2020 at 2:21 PM
    #3312
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    @ovrlndkull runs the round ones I think. They don’t look that bad. The squadrons are probably smaller than you realize if you’ve never seen them in person.
  13. May 27, 2020 at 2:21 PM
    #3313
    Baja Designs
    San Marcos, CA
    It would be purely cosmetic. Hopefully someone can chime in with some pictures on their rig. But the bezels can be swapped out if you end up not liking one setup than the other. :)
    EatSleepTacos likes this.
  14. May 27, 2020 at 2:24 PM
    #3314
    jackbauer01
    Good to know. Thanks
  15. May 27, 2020 at 2:25 PM
    #3315
    jackbauer01
    Sounds like I can swap the bezel if I hate the r version.
    Yeah, never seen in person.
  16. May 27, 2020 at 3:03 PM
    #3316
    lynyrd3
    Bill
    East Central Upstate NY
    Squadron Sport Driving combo
  17. May 27, 2020 at 4:21 PM
    #3317
    jackbauer01
    Thank you very much for this.
    I dig it.
    lynyrd3[QUOTED] likes this.
  18. May 27, 2020 at 5:52 PM
    #3318
    Jnull
    Jnull Well-Known Member
    4 cummins trucks!
    XL80s for the win. This is a much bigger truck tho, the squadrons look fine on the yotas. I’m a square bezel kinda guy myself especially when they’re exposed on the back since the rest of the housing is square. Looks kinda goofy to me.
    memario1214 and jackbauer01 like this.
  19. May 27, 2020 at 5:56 PM
    #3319
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    loving my XL80’s but they bounce like a mofo on my ditch brackets. I wish someone would make a cowl mounted ditch bracket for the 3rd gens. These lights are just too heavy for the hood mounted brackets.
    Rome604 likes this.
  20. May 27, 2020 at 6:17 PM
    #3320
    Jnull
    4 cummins trucks!
    That would get old pretty quick. I’m lucky enough that SDHQ makes some pretty stout brackets for the 4th gen rams and my XL80/S1 combo is pretty rigid.
