Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Aug 21, 2020 at 1:25 PM
    #3521
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I spy some DD lights
    :infantry:
    Rome604[QUOTED] likes this.
  2. Aug 21, 2020 at 1:31 PM
    #3522
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Yes sir. My headlights aren't Baja Designs either. Don't worry, the DD fogs aren't counted in my 159k lumens of Baja Designs lights.
    Gunshot-6A likes this.
  3. Aug 21, 2020 at 1:36 PM
    #3523
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    im considering swapping my squadron pros for some DD pros, so I can actually use them on the street.
  4. Aug 21, 2020 at 4:01 PM
    #3524
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Why not some LP4s?
  5. Aug 21, 2020 at 4:07 PM
    #3525
    Rome604
    Dave
    Alexandria, VA
    @Baja Designs pointed out they have a 200degree spread. The glare on the hood would be pretty intense
    Baja Designs[OP] and memario1214 like this.
  6. Aug 21, 2020 at 4:14 PM
    #3526
    CttAznRanger
    Brandon
    Boston, MA
    Ah, that would do it. Good info for later. Thanks.
  7. Aug 21, 2020 at 4:15 PM
    #3527
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    We can make that happen :p
    Gunshot-6A and Rome604 like this.
  8. Aug 21, 2020 at 4:18 PM
    #3528
    memario1214
    Colton
    Missoula, MT
    Did the anodizing fail on your middle 2 XL lights on your roof rack (and maybe the far left one)? That's a warranty item, and you can get some new bezels. I'll bet I can damn near pinpoint about the time you bought them if that's what I am seeing. Pretty much everything from a certain time-frame had the coatings fail/turn red if they were exposed to extended periods of UV light.
  9. Aug 21, 2020 at 4:22 PM
    #3529
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    yeah. Tempting. But then what would I do with the squadrons?
    Left and Right roof rack scene lighting? :drevil:
    Rome604 likes this.
  10. Aug 21, 2020 at 4:24 PM
    #3530
    Rome604
    Dave
    Alexandria, VA
    I think the one on the passenger side is just glare but I’d have to look. The two middle ones are definitely fading they are my XL Lasers. I’ve just been too lazy to reach out to BD to get them swapped
    memario1214[QUOTED] likes this.
  11. Aug 22, 2020 at 10:00 PM
    #3531
    Jnull
    Jnull Well-Known Member
    4 cummins trucks!
    Finally got my 40” onx6 hi power on and wired. Been running the XL80/S1 ditch light combo for a few months which is more light then you really ever need so the 40” hi power which is basically 4 XL80s and 2 XL Racers is pretty ridiculous. Wired them to an auxiliary switch that arms the bar and the high beam switch turns it on when the aux switch is on.
    Baja Designs[OP] likes this.
  12. Aug 30, 2020 at 11:52 AM
    #3532
    Jeremycc
    Jeremycc New Member
    Jeremy
    2020 cement trd sport tacoma
    I just installed a pair of squadron sport on my 2020 tacoma trd sport and they seem to have a gap between the black plastic and the lens frame... I ordered the 447115 model they are supposed to fit on the 2020 model ?
  13. Aug 30, 2020 at 12:00 PM
    #3533
    Rome604
    Dave
    Alexandria, VA
    A small gap like that is pretty normal. I'm pretty sure it allows for adjustability up/down and left/right
  14. Aug 31, 2020 at 7:27 AM
    #3534
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Hi Jeremycc,
    That gap would be normal. We designed it like that for the slight bezel tolerances between the different Toyota models it works on.
  15. Aug 31, 2020 at 6:23 PM
    #3535
    Jnull
    4 cummins trucks!
    $1600 light bar, junk hardware. Put it on my truck 9 days ago.
  16. Aug 31, 2020 at 6:26 PM
    #3536
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Hardware on my squadron pros is rusted too. Can’t see it so I’m not concerned.
  17. Aug 31, 2020 at 6:55 PM
    #3537
    Jnull
    4 cummins trucks!
    Yea if it was hidden I wouldn’t care so much. I’ve spent way too much on this truck getting it the way I want to have rusty hardware.
  18. Aug 31, 2020 at 7:08 PM
    #3538
    Rome604
    Dave
    Alexandria, VA
    Why aren't you using security hardware?
  19. Aug 31, 2020 at 7:17 PM
    #3539
    Jnull
    4 cummins trucks!
    because I don’t live in an area where that’s a concern.
    I probably will just because but I certainly won’t be getting it from BD if this is the quality of the hardware they use.
  20. Aug 31, 2020 at 9:29 PM
    #3540
    Rome604
    Dave
    Alexandria, VA
    Seems like a pretty minor issue to me. I normally don't buy a light bar for the hardware. And if I have a $3 issue I normally just take care of it myself. If you're concerned about it you can always put some fluid film on them. I'm sure rust isn't really an issue in California deserts.
