Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Sep 1, 2020 at 4:50 AM
    #3541
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's surprising. No issues on any of my hardware, ever. If it bothers you Jnull, just contact BD and they'll make it right with new hardware.
  2. Sep 1, 2020 at 6:21 AM
    #3542
    Jnull
    Jnull Well-Known Member
    4 cummins trucks!
    It’s a fact of the matter thing. No I’m sure it isn’t but I believe they’re aware their products are used in environments other then warm dry ones.
    I obviously didn’t buy it for the hardware but for the money it cost rusting after only a few days shouldn’t be a concern.
  3. Sep 1, 2020 at 8:53 AM
    #3543
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Hi Jnull,
    I apologize that your hardware is rusting. This should NOT be happening because it's stated from our supplier that it is stainless steel. But obviously that's not the case for you. I spoke to my technical support and sales department and there's been no open reports of our 3/8 hardware rusting. I'm trying to think of all possibilities but would there be any chance the bolts were sitting somewhere where metal fragments would've landed on them (metal spraying from a grinding wheel)? Regardless, I'm more than happy to send out a new hardware set today.
    Jnull[QUOTED] and EatSleepTacos like this.
  4. Sep 1, 2020 at 8:56 AM
    #3544
    Baja Designs
    San Marcos, CA
    PM sent.
  5. Sep 1, 2020 at 9:59 AM
    #3545
    Jnull
    4 cummins trucks!
    No they were in a ziplock back in the spare bedroom inside my house till I installed the light bar.
  6. Sep 1, 2020 at 10:13 AM
    #3546
    Baja Designs
    San Marcos, CA
    Thanks for the confirmation, PM inbound.
    Jnull[QUOTED] likes this.
  7. Sep 4, 2020 at 4:30 PM
    #3547
    Baja Designs
    San Marcos, CA
  8. Sep 7, 2020 at 11:33 AM
    #3548
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    Just to confirm before I connectorize my homemade harness, for the S2 pro is this the correct polarity for the male weatherpack mating connector?
    A - Ground
    B - Hot (12 V) switched
    Could not easily find this information on website.
  9. Sep 7, 2020 at 1:25 PM
    #3549
    Jnull
    4 cummins trucks!
    White is hot black is ground
  10. Sep 7, 2020 at 1:33 PM
    #3550
    mrCanoehead
    Ottawa
    Sorry if it wasn't clear. I have a loose 2-pin male weatherpack connector, terminals are labeled "A" and "B". Please confirm that the hot wire goes into "B".
  11. Sep 7, 2020 at 1:37 PM
    #3551
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Ground = A
    Hot = B
    BD uses some different colored wires so there's a quick guide
  12. Sep 7, 2020 at 2:47 PM
    #3552
    mrCanoehead
    Ottawa
    Thanks. I built and ran the harness already, just need to connectorize the end that plugs into the light. My friend has the proper crimp tool at his work, I am going there tomorrow morning.
  13. Sep 7, 2020 at 3:25 PM
    #3553
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Yes
    Ground = A
    Hot = B
    The real beauty comes in with three wire applications since ground is A, hot is B and control is C. This puts the main 12V hot in the middle of the bundle and with more protection than the other two. I'd have to guess that this isn't a lucky accident since every other part of the light is equally well planned out.
  14. Sep 7, 2020 at 3:28 PM
    #3554
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    If you do any bit of electrical work it’s worth the money to get some crimpers and de-pinning tools. Weatherpack connectors are my favorite, so easy to work with.
  15. Sep 7, 2020 at 3:41 PM
    #3555
    mrCanoehead
    Ottawa
    Ha! I'm an electrical engineer. I saw a weatherpack kit for $350 on Amazon here in Canada, didn't want to spend that kind of money but who knows what I'll buy on Black Friday!
  16. Sep 7, 2020 at 5:00 PM
    #3556
    Jnull
    4 cummins trucks!
    All you need is the crimp and de-pinning tool, like $30 bucks. I made all my wire harnesses which was quite a bit with those and basic electrical tools without wishing I had anything more.
  17. Sep 13, 2020 at 7:35 PM
    #3557
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Does anybody have output shots of the different beam patterns for the XL Sports being mounted on the hood hinges? I'm debating on what beam pattern to get for that spot.
  18. Sep 15, 2020 at 1:54 PM
    #3558
    mrCanoehead
    Ottawa
    Bought a cheap weatherpack crimper from Jeff Bezos because my friend with the proper tool had to fly out unexpectedly. Light is bright as the sun! Thanks to all for the help to confirm the polarity because I was too cheap to buy the de-pinning tool!
    Thanks also to Paul of Baja Designs, who was amazing about sending me the connector I needed - practically overnight to Canada!
    Baja Designs[OP] likes this.
  19. Sep 15, 2020 at 5:17 PM
    #3559
    IPT
    IPT Well-Known Member
    Lou
    Looking for longer throw down the dark night roads but don't want to do a bar or something big. I already have the Squadron pros Driving combo and like the near/mid field and periphery light it give. I want more light "out there" while keeping in the Squadron series (for their small size). Am I better off with another set of the Squadron Pro using the spot pattern, or the Squadron Racer?
    As an aside. How is it that the Racer is less powered yet gets out farther? Is is just reflectors or is something else different about it?
  20. Sep 15, 2020 at 5:54 PM
    #3560
    Jnull
    4 cummins trucks!
    You want racers or lasers.
