Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Jan 2, 2018 at 8:49 PM
    #1181
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    Just ordered the Squadron Sport Pair and brackets for the 2011 Tacoma. It’s hard to tell from the night shots as to what they will look like in person. I’ll figure out if I want to upgrade to the Pro model after I get to use them. One final question. Is the wiring harness the same for the Sport and Pro?
  2. Jan 2, 2018 at 10:23 PM
    #1182
    Fiatdave
    Fiatdave The predator in her natural environment!
    David D
    King City Oregon
    17 TRD AC-OR-no pavement princes!
    Icon stage 4 lift, CBI T3 bumpers, front and rear w/swing our tire, 2 jerry can holders and camp table, full CBI skid, Snug Top Rebel canopy. Nitto trail grapplers on ATX Baja wheels times 5. Old taco totalled new taco on tap!
    I have a CBI Off Road T3 bumper that needs a 20" single row light bar. What would you recommend? They like the Rigid unit and I got a quote for $535 for one today. What would you have that would work for my application?
    Thanks
  3. Jan 3, 2018 at 9:27 AM
    #1183
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Unfortunately we don't have too many photos of the Squadron Racer. Here is a customer shot showing his pair on hood mounts:
  4. Jan 3, 2018 at 9:29 AM
    #1184
    Baja Designs
    San Marcos, CA
    The wiring harness will be the same for the Squadron Sport and Squadron Pro. They both utilize 16 gauge wiring and the included harness will work for either model.
  5. Jan 3, 2018 at 9:41 AM
    #1185
    Baja Designs
    San Marcos, CA
    Our 20" S8 LED Light Bar is a great option!
    https://www.bajadesigns.com/products/S8-20-inch-Driving-Combo-LED-Light-Bar.asp
    The 20" S8 will put out a total of 8,000 Lumens and will provide a nice blend of nearfield, midfield, and distance lighting. Pricing is a little bit cheaper at $521.10 with the forum discount (Coupon Code: BDForums).
    Here is a shot taken by a customer:
  6. Jan 3, 2018 at 9:58 PM
    #1186
    wingspar
    Oregon
    Thanks for all the help and info. Can’t wait to get them installed and working.
  7. Jan 4, 2018 at 4:05 PM
    #1187
    breakfasttaco93
    breakfasttaco93 Well-Known Member
    Dan
    2017 Tacoma 4x4 TRD Off-Road
    Went to remove the faceplate to put on the black bezel for fog light install and my screws are a bit stripped...anyone have a tip for getting them out? thx
  8. Jan 4, 2018 at 4:11 PM
    #1188
    G.T.
    G.T.
    CONUS
    Have a different pattern hex bit? I have a bunch of dual pin types and have drilled holes in fastener faces to accommodate them. Then just replace them after removal.
  9. Jan 4, 2018 at 4:34 PM
    #1189
    Baja Designs
    San Marcos, CA
    If you find a Torx/Star bit of slightly larger size and tap it in with a hammer you can usually remove the stripped bolt. Hope this helps!
    -Bailey, Baja Designs
    www.bajadesigns.com
  10. Jan 4, 2018 at 5:57 PM
    #1190
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    Any way I can order just a weather proof connector for a Squadron Sport? Need an extra female connector.
  11. Jan 4, 2018 at 9:30 PM
    #1191
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Sdhq sells them man. They are just weatherpac connectors
    HandOfGod likes this.
  12. Jan 5, 2018 at 2:10 AM
    #1192
    Onehugenut55
    Onehugenut55 Well-Known Member
    Dave
    2017 TRD OR DCLB
    I originally tried tapping into the DRL but the relay is after the fuse so it will result in constant hot. I ended up connecting mine to the “washer” fuse left of the steering column. It’s 10A, turns on/off with truck, and isn’t attached to anything important (tapping into an airbag or ECU freaks me out). Will attach pics when I get home from work in 2 weeks.
    =JSG=[QUOTED] likes this.
  13. Jan 5, 2018 at 8:16 AM
    #1193
    Baja Designs
    San Marcos, CA
    We do carry and sell the delphi weatherpack connectors, pins, and seals for our lights. These can also be found at some of our dealers like SDHQ or Amazon if needed.
    Give us a call if you decide to order direct. 800-422-5292
    www.bajadesigns.com
  14. Jan 5, 2018 at 8:52 AM
    #1194
    JMM7171
    JMM7171 Well-Known Member
    Jamie
    CT
    2017 Taco Limited
    TRD exhaust, TRD air filter, TRD OR/Sport grille, BD Squadron Sport combos/fog, Morimoto 2Stroke Hi/low, Baja Suspension Kit with TRD PRO leaf springs and Icon aal, HPS intake w/ Intake Flow Accelerator.
    First off, when installing a light in the A-pillar position, any recommendations between the Squadron and XL size? Been going back and forth for a while on size. Leaning towards the racer editions.
    Second, when installing lights in the A-pillar position. There is the Security Hardware Kit that screws into the sides of the light unit. Nothing you can really do for the bottom mount to the bracket? So, in that position there really is not a lot you can do for security. Correct? Any suggestions? Would really hate for them to walk off on me.
  15. Jan 5, 2018 at 10:16 AM
    #1195
    Baja Designs
    San Marcos, CA
    Both the Squadron Series and XL Series lights are great for the A-Pillar location. A lot comes down to personal preference on the sizing and the look. One thing to consider is the XL Series is larger and heavier and not all hood mounts can hold the additional weight without vibration. @SDHQ OFFROAD makes some very stout mounting solutions that can certainly hold either option!
    The security hardware secures the mounting bracket to the light itself. We don't have a security nut/bolt with for the 3/8" mounting bolt. We have had a few customers source aftermarket hardware similar to winch security bolts but I'm not aware of a "go-to" option.
    www.bajadesigns.com
  16. Jan 5, 2018 at 10:48 AM
    #1196
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
    Thanks, Will try that.
  17. Jan 5, 2018 at 11:39 AM
    #1197
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I personally love the S2 Pro's for ditch light mounts. Low key because they're tiny, but pack a pretty good punch too!
    Baja Designs[OP] and JerryTaco like this.
  18. Jan 5, 2018 at 12:31 PM
    #1198
    JMM7171
    Jamie
    CT
    2017 Taco Limited
    I'm looking for a better version of high beams, but don't want to cut grill (S8) or lose light behind my grill (OnX6).
    Bailey. You think something like this once installed and locked would be good? Thanks. At least slow them down.
    http://factor55.com/product/winch-lock/
  19. Jan 5, 2018 at 2:47 PM
    #1199
    Baja Designs
    San Marcos, CA
    I haven't personally used it but from the specs it should work great! First, you need to install the stainless mounting bracket onto the hood/ditch light bracket with that security bolt. From there you install our light onto the stainless mounting bracket with our security hardware. The two combined will greatly slow or stop someone down from removing lights.
    Btw, Here is a customer shot of our Squadron Racers at night on hood mounts:
  20. Jan 8, 2018 at 11:36 AM
    #1200
    Baja Designs
    San Marcos, CA
    LED update! Squadron, XL, and S8 Series Lights
    Hey Everyone! We, The Scientists of Lighting, are always looking for ways to improve our products and have updated our Squadron Sports, XL Sport, and S8 LED Light Bars. These now feature new and improved LEDs from Cree which boosts the lights up to 25%!
    Examples:
    Then: Squadron Sport - 1,800 Lumens
    Now: Squadron Sport - 2,260 Lumens
    Then: S8 LED Light Bar - 4000 Lumens per 10"
    Now: S8 LED Light Bar - 4,520 Lumens per 10"
    Then: XL Sport - 1,800 Lumens
    Now: XL Sport - 2,260 Lumens
    Stay tuned for the latest and greatest from Baja Designs (BD)
    www.bajadesigns.com
    Don't forget your Forum Discount! Coupon Code: BDForums
    Doomsday, omaguz, ETXTacoma and 3 others like this.
