Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Feb 18, 2018 at 2:12 PM
    #1281
    Minimedic
    Minimedic Well-Known Member
    Tacoma DCLB OR MGM
    Is a s8 high output light bar a possibility for the future??
  2. Feb 18, 2018 at 4:54 PM
    #1282
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    We are constantly looking for ways to make our products Brighter, Bolder, Better and have recently updated the LED in the S8 to a higher output than before. Unfortunately due to it's slim profile we can't put the OnX6 Hi-Power LEDs without causing potential heat issues. We will continue to upgrade our products as the latest and greatest becomes available and is tested :D
    -Bailey, Baja Designs
    www.bajadesigns.com
    G.T. and RPS1030 like this.
  3. Feb 20, 2018 at 2:26 PM
    #1283
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    2015 TRD Offroad
    All I'm asking for is a frickin' tacoma with a frickin' laser on its windshield, alright? :D
  4. Feb 20, 2018 at 2:27 PM
    #1284
    Gunshot-6A
    Conner
    Everett, WA
    2015 TRD Offroad
    Chase bar goodness!
  5. Feb 23, 2018 at 8:24 PM
    #1285
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
    Looking to by some s2 flush mounts for my rear bumper. Planning to run them to my switch pro. Do I get the flush mount back up kit or just 2 individual s2 flush mounts. Also do I need a harnes to connect each of them if I get the individuals? Thanks.
  6. Feb 23, 2018 at 8:30 PM
    #1286
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    I got the "backup kit" with wiring included (link), to fit in the optional cutouts for a Mobtown bumper, so I'm also interested to see how these get mounted up and wired in. Ideally, I'd like to have a switch that's independent but in series to the backup circuit, so I can also use them as work lights.
  7. Feb 24, 2018 at 5:24 AM
    #1287
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam
    This looks like an awesome system and I will be very interested in purchasing one. I would prefer the S8 form factor so that it could be installed between the bumper and grill. I do not have a 30" light bar installed between the grill and bumper because it cuts off all of the air flow to the transmission fluid cooler. Summertime towing in Florida can cause the transmission temps to rise very quickly so the 10" installed there would still give some air flow there. Hopefully, you can come out with the S8 version also.
    Edit @Baja Designs
  8. Feb 24, 2018 at 1:18 PM
    #1288
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    @bajadesigns I’m looking to get flush mount S2 pros (pair) for my new bumper. For rear back up lights do you recommend the work/scene or the wide cornering? Thanks.
  9. Feb 26, 2018 at 12:08 PM
    #1289
    Baja Designs
    San Marcos, CA
    Looking good! :thumbsup:
  10. Feb 26, 2018 at 12:13 PM
    #1290
    Baja Designs
    San Marcos, CA
    Thanks for posting up! Since you are using the Switch Pros power panel you won't have to use the wiring found in our Flush Mount Backup Kits. You can either cut-out what you don't need or buy the individual lights and wire yourself. If you buy the individual lights here is my recommendation on the wiring:
    - Backup Harness, Extension (QTY:2)
    https://www.bajadesigns.com/products/S2-Squadron-Rear-Backup-Extension-12.asp
    - 55" Splitter, 2-Pin
    https://www.bajadesigns.com/products/squadron-s2-wire-harness-splitter-55-universal.asp
    All you have to do is run the Positive (+) and Negative (-) directly to your Switch Pros! No relays, fuses, or wiring mess under the hood.
    www.bajadesigns.com
  11. Feb 26, 2018 at 12:16 PM
    #1291
    Baja Designs
    San Marcos, CA
    Thanks for your input! We appreciate the feedback. As of now we don't plan on releasing an S8 version but don't be surprised if the Laser Chips make it in more housings down the road. As the technology improves and pricing gets a little bit cheaper we will be expanding more into other laser products.
    Stay tuned!
    G.T. and skyking3[QUOTED] like this.
  12. Feb 26, 2018 at 12:18 PM
    #1292
    Baja Designs
    San Marcos, CA
    We'd recommend Wide Cornering for the rear bumper. It will offer more usable light over Work/Scene in that position. If the lights were mounted up high and aiming down on an area we'd recommend Work/Scene instead.
    www.bajadesigns.com
    Italia234 and AzogSS[QUOTED] like this.
  13. Feb 26, 2018 at 1:29 PM
    #1293
    Italia234
    Nick
    Tucson
    TRD offroad
    Awesome thank you that is the route I will take!!
  14. Feb 26, 2018 at 2:01 PM
    #1294
    AzogSS
    Andy
    Soda City, SC
    Thanks!!! I'll be ordering soon.
  15. Feb 26, 2018 at 2:06 PM
    #1295
    Shermyota30
    Shermyota30 Well-Known Member
    Bay Area
    17 sport 2wd doublecab
    Just purchased squadron sport with wide cornering. I understand it’s the most street friendly. But for comparison purposes which set would get flashed by other vehicles more often on the streets? Pro’s with wide cornering lense or sports with driving combo lense?
  16. Feb 26, 2018 at 11:34 PM
    #1296
    Italia234
    Nick
    Tucson
    TRD offroad
    I’m running the pros for my fogs and have them dimmed with the switch pro for street driving to 50% it really doesn’t matter which lens you run the pros are blindingly bright over the sports at full power.
    Shermyota30[QUOTED] likes this.
  17. Feb 27, 2018 at 9:48 AM
    #1297
    Baja Designs
    San Marcos, CA
    The Squadron Pros in any pattern will be blinding to oncoming traffic. You would need to dim them to 50% output or lower for a street-friendly setup.
    - Bailey, Baja Designs
    www.bajadesigns.com
  18. Feb 28, 2018 at 3:25 AM
    #1298
    Baja Designs
    San Marcos, CA
    Bananaclip and Italia234 like this.
  19. Mar 1, 2018 at 1:46 AM
    #1299
    Shermyota30
    Bay Area
    So I just got my squadron sport wc in clear. Shipping was fast I ordered them Monday and got them Wednesday I took my time with the install and only took me about an hour. I prefer removing the grill for easy access to fogs. I also didn’t need to drill additional hole for second screw or some people used tie wraps. I tested them out on terrible roads here and they held firm without bouncing or moving. First impressions are Wow! These little things put out some serious light. They are so good I prefer driving with them over my led low beams. Super satisfied with this purchase.
    Edit: here’s some pics and I did add that additional self drilling screw for a more secure fit on the bracket.
  20. Mar 1, 2018 at 6:15 AM
    #1300
    Baja Designs
    San Marcos, CA
    Thanks for posting up your experience with Baja Designs (BD) products. We'd love to see the truck if you've got some photos :)
    www.bajadesigns.com
