Baja Designs: General Discussion Thread
Discussion in 'Baja Designs' started by Baja Designs, Apr 23, 2015.
  1. Nov 27, 2018 at 4:54 PM
    #1701
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    lstrople and Rob Daman[QUOTED] like this.
  2. Nov 27, 2018 at 8:05 PM
    #1702
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Here you go, hopefully this helps.
  3. Nov 28, 2018 at 5:16 AM
    #1703
    jaredc2306
    jaredc2306 Well-Known Member
    Jared
    San Antonio, Tx
    2016 ACLB TRD OR Quicksand
    Thank you! That helps a lot. Now just waiting for them to deliver...
    Rome604[QUOTED] likes this.
  4. Nov 28, 2018 at 5:03 PM
    #1704
    lstrople
    lstrople Well-Known Member
    Logan
    2016 tacoma trd 4x4
    I'm in love with the light output of the headlights. But They have the projector high beam and the baja designs pro's on at the same time.
    I did talk to baja designs at SEMA this year and they agreed that the squadron pros are better for my retrofit headlights because the racer squadron is more designed for beam distance and not width.
    The way the rx350's and the squadron pros work together is about perfect in terms of distance and width for both windy roads and ling empty highways.
  5. Nov 28, 2018 at 5:10 PM
    #1705
    Rome604
    Dave
    Alexandria, VA
    Cool, have you had any problems with heat from the pros in the housing? They look great.
    lstrople[QUOTED] likes this.
  6. Nov 29, 2018 at 5:49 AM
    #1706
    GreeGunc
    Jacob
    North GA
    Thank ya, did you use the bd factory bracket onto the 3rd gen bracket?
    Also how did you strengthen the factory bracket?
  7. Nov 29, 2018 at 6:08 AM
    #1707
    ktmrdr
    ktmrdr Well-Known Member
    Here is a pic of my Squadron sports. 2 in the middle are spots, then spot/flood combo, and on the ends are wide cornering. They are awesome!
    Rome604 likes this.
  8. Nov 29, 2018 at 6:15 AM
    #1708
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I can finally join the thread! Picked up new fogs, and on Sunday my 20" ONX6 bar is gonna go in. The thing is pure beef and I can't wait to see it powered on.
    Rome604 likes this.
  9. Nov 29, 2018 at 6:22 AM
    #1709
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Your headlight fluid is low.
  10. Nov 29, 2018 at 6:24 AM
    #1710
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Or too high if you think about it.
  11. Nov 29, 2018 at 8:29 AM
    #1711
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Nice! Thanks for sharing. Looks great on the Taco
    ktmrdr[QUOTED] likes this.
  12. Nov 29, 2018 at 8:30 AM
    #1712
    Baja Designs
    San Marcos, CA
    :cheers: Lookin' good! Can't wait to see the Truck with the OnX6
  13. Nov 29, 2018 at 9:27 AM
    #1713
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Squadron Sports with the Paranoid Fab brackets made for an easy installation in the ARB bumper, happy with how it turned out. CEF197AA-BB82-4A50-9B52-C42FB240640E.jpg D245791F-1338-49DF-B54C-DF088E0DEC62.jpg
  14. Nov 29, 2018 at 10:04 AM
    #1714
    Baja Designs
    San Marcos, CA
    :yes:
  15. Nov 29, 2018 at 10:07 AM
    #1715
    xA101x
    xA101x Well-Known Member
    AJ
    Idaho
    2017 TRD PRO MT
  16. Nov 29, 2018 at 9:19 PM
    #1716
    lstrople
    Logan
    2016 tacoma trd 4x4
    No issues with heat as the lights put out les head then the factory halogen high beams.
    the baja designs are less wattage (then 55 watt halogen high beams) so less heat!
  17. Nov 29, 2018 at 9:22 PM
    #1717
    lstrople
    Logan
    2016 tacoma trd 4x4
    I literally just used the factory high beam reflector and mounted the baja lights in them. Used the baja included brackets and put a small piece of metal on the backside as to sammich the tacomas high beam reflector for strength. Holds up great and the best part is that they adjust with the stock headlight high beam and low beam adjustments.
  18. Nov 30, 2018 at 3:12 AM
    #1718
    GreeGunc
    Jacob
    North GA
    Ah, sounds easy enough. Thanks for the help
  19. Dec 6, 2018 at 11:19 AM
    #1719
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    Did anyone see any blinks?
  20. Dec 6, 2018 at 11:39 AM
    #1720
    Rome604
    Dave
    Alexandria, VA
    Watch closely....:eek:
