Baja Designs LP9 - The Most Advanced 8" LED Light on the Market Today!
Discussion in 'Lighting' started by Baja Designs, Aug 29, 2017.
  1. Aug 29, 2017 at 11:09 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Announcing the LP9 from Baja Designs!
    https://www.bajadesigns.com/products/LP9-LED-Auxiliary-Lights.asp
    A design that was inspired by Baja Designs’ legendary 8" La Paz HID; The LP9 features modern styling and performance, with some of the most advanced LED technologies available today.
    The LP9 utilizes 9 forward projecting LEDS to produce 11,025 Lumens at 105 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 1,140 lumens at 10.5 watts per side. The IPT provides an incredible 200° spread of usable light.
    The housing was designed to provide exceptional heat dispersion by using Direct Ducted Cooling, which allows air to travel from the front of the housing to the rear. With a day-time running light, low, and high power mode, the LP9 will fulfill all your lighting needs.
    Available in a standard model that is perfect for a wide range of off-road use, as well as a Racer Edition configuration that is designed for the demands of high speed driving. The Racer Edition has similar power draw, but produces a much tighter pattern, providing higher visibility at greater distances. Both models feature uService technology, which allows customers to change the lens pattern and color depending on driving conditions, or simply when they want to refresh the lens.
    LP9 VIDEO:
    https://www.youtube.com/watch?v=2NSPgpvC3yc
    -Bailey, Baja Designs
    www.bajadesigns.com
  2. Aug 29, 2017 at 11:11 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    WOW!! Those are intense!
    EDIT: soundtrack is lit af​
  3. Aug 29, 2017 at 1:07 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Holy Sh..! These are gorgeous! I have 2 Squadron Pros behind my Homer Grill....guess these will be a slight upgrade!!
    When will these be available?
    Jackpatt9 and TACOVRD like this.
  4. Aug 31, 2017 at 9:47 AM
    Baja Designs
    San Marcos, CA
  5. Sep 5, 2017 at 2:36 PM
    Baja Designs
    San Marcos, CA
    Taco Addiction likes this.
  6. Oct 2, 2017 at 4:46 PM
    Bumble
    Bumble Well-Known Member
    Pocono Mountains, PA
    2013 MGM SR5, 92 Hilux Dual Cab Diesel
    ARB, Baja Designs, ETC
    I want to see a side by side comparison to the ARB Intensity's. 7 and 9 inch.
  7. Oct 2, 2017 at 9:46 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    its over 2000 Lumens brighter and its cheaper :D (9" vs 9")
  8. Oct 3, 2017 at 11:20 AM
    Baja Designs
    San Marcos, CA
    We don't have side by side images but here is a quick comparison between the two:
    ARB Intensity 9.5", Spot
    - 9,300 Raw Lumens
    - 90Watts
    - 32LEDs
    - MSRP: $764.00
    vs.
    LP9, 8" Spot
    https://www.bajadesigns.com/Products/LP9-LED-Spot.asp
    - 13,305 Actual Lumens (11025 Forward Projection, 2280 IPT)
    - 126 Watts (105W Forward Projection, 21W IPT)
    - 15LEDs (9 Forward Projection, 6 IPT)
    - MSRP: $599.95
    IPT = Intergrated Peripheral Technology
    tcjacado likes this.
  9. Oct 11, 2017 at 11:44 AM
    Bumble
    Hopefully someone will do a side-by-side comparison at some point. Unless someone buys these Intensity's from me lol.
  10. Oct 14, 2017 at 8:14 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Subd for someone hopefully posting some experience with these bad boys.
    Bumble likes this.
  11. Jan 25, 2018 at 11:23 AM
    Baja Designs
    San Marcos, CA
    sixtytooze, TACOVRD and SilverSurfer like this.
  12. Jan 25, 2018 at 2:21 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Subbed
  13. Jan 25, 2018 at 8:15 PM
    paranoid56
    San Diego
    14 double cab taco
    here is a pic from their instagram account. I have one sitting here fora customer if you need any info. Its a beefy light.
    He asked if i could plug it in and see how it looks. I know it lit up my neighbors house 2 blocks away like it was daylight. Didnt get a pic due to them coming out and starring at me lol. but heres a pick thats mostly meaningless lol. pointing to the sky.
    Baja Designs[OP], Bumble and TACOVRD like this.
  14. Feb 10, 2018 at 4:11 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    this price just for one, or pair?
  15. Feb 10, 2018 at 4:56 PM
    Baja Designs
    San Marcos, CA
    Pricing is for each unit. With your forum discount you save nearly $60 per light :)
    Coupon Code: BDForums
    www.bajadesigns.com
  16. Feb 20, 2018 at 12:52 PM
    Baja Designs
    San Marcos, CA
    The LP9 just got a little bit BOLDER!
    Introducing a new, more aggressive, cast housing for the LP9. One of the noticeable changes is the larger openings for the Direct Ducted Cooling at the top and bottom of the housing. This will increase airflow to the light and in return keep the light cooler allowing everything to run at peak performance longer. This housing also features a sleek black powder coat finish. Take a look at the website for more pictures and information!
    Post up if you have any questions! Don't forget to save nearly $60 per LP9 with your forum discount. Coupon Code: BDForums
    www.bajadesigns.com
  17. Feb 20, 2018 at 1:26 PM
    paranoid56
    San Diego
    14 double cab taco
    is there a cost difference between the two?
  18. Feb 20, 2018 at 1:51 PM
    Baja Designs
    San Marcos, CA
    Pricing will remain the same. :thumbsup:
  19. Feb 20, 2018 at 1:54 PM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Very powerful lights. Who knew off road lighting was so gangsta (music jab).
  20. Feb 20, 2018 at 3:08 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    So I was hoping to put a couple of these behind a mesh Satoshi style grill - knowing what you know about heat production with these, do you think this is a feasible option if they will fit?
