Baja Designs LP9 - The Most Advanced 8" LED Light on the Market Today!
Discussion in 'Lighting' started by Baja Designs, Aug 29, 2017.
  1. Feb 20, 2018 at 3:25 PM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    A mesh grille will be fine as long as it doesn't restrict any airflow. These lights do have built-in thermal management technology if they get too hot. The lights typically go into thermal management mode if you've been running them at idle for a long period of time with absolutely no wind. The only thing that might happen is the light will dim when overheated and go back to full brightness when temps are optimal. If you're driving and the lights have some airflow you'll be fine. :D
    -Bailey, Baja Designs
    www.bajadesigns.com
    TACOVRD[QUOTED] likes this.
  2. Feb 24, 2018 at 6:26 PM
    Natpag
    Natpag Well-Known Member
    2017 White Tacoma TRD off-road
    With so much heat, would these be a bad choice for a guy who mostly slowly rock crawls and would leave them on with my truck not moving? Other BD options? Love your product!
  3. Feb 24, 2018 at 7:43 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I would say others would be a better choice. these are great for hauling ass in the desert. for slow, i use the bd rock lights and some small light bars on my fj40 crawler. adding some S2s on it also. Unless you are talking Ultra4 then i think the squadrons and rock lights are your best bet
  4. Feb 26, 2018 at 12:38 PM
    Baja Designs
    San Marcos, CA
    No need to worry about heat!
    Our lights have a built-in Thermal Management system if they get too hot. If the lights start to overheat they will dim slightly to allow the light to run at a safer temperature. This typically only happens when the truck isn't moving and there isn't a breeze. Even a slight breeze is enough to cool these down although the truck moving will be ideal.
    We do have other great options that also feature the same thermal management technology. These aren't quite as powerful but still put out a lot of usable light. I'd recommend something in our Squadron or XL Series if you want a lower profile light.
    https://www.bajadesigns.com/Products/led-auxilary-lights.asp
    www.bajadesigns.com
  5. Feb 26, 2018 at 1:55 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    while I love the raw look of the machined housing, that new cast one just looks a lot cleaner and sleeker. Kind of wish I had known of the coming change, might have waited the month to order in order to get that new housing.
  6. Mar 25, 2018 at 7:22 AM
    Baja Designs
    San Marcos, CA
    beertimecontinuum likes this.
  7. Apr 4, 2018 at 8:48 PM
    ProjectBangarang
    ProjectBangarang Well-Known Member
    Utah
    2020 Cement TRD Off-Road
    Total Chaos Bed Stiffeners C4 Bed Bars Smittybilt RTT Uptop Overland Bravo
    Is there any chance of these fitting behind the grill of a 3rd gen? I was originally planning on BD's 30" grill mount kit, but unless I'm wrong a hidden winch occupies the same spot, so I'm looking for other solutions.
  8. Apr 5, 2018 at 7:53 AM
    Baja Designs
    San Marcos, CA
    Definitely! The LP9 housing isn't very deep (3.25") so you can fit a set behind the grille. We don't carry a behind the grille bracket set but a few companies do. I'd recommend searching around and finding what's best for your application.
    www.bajadesigns.com
  9. Apr 6, 2018 at 9:38 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Going over my SR9 and it says the high beam(pin4) and low beam(pin1) cannot be on at the same time. Why is this????
  10. Apr 9, 2018 at 6:50 AM
    Baja Designs
    San Marcos, CA
    You mean LP9, correct? When the LP9 is in High Beam mode all forward projection lighting will fire (including low beam). Running Low Beam while High Beam is already on could potentially cause a circuit board issue (although rare).
    www.bajadesigns.com
  11. Apr 14, 2018 at 8:34 AM
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Currently running 4 Baja Design lights and one rigid light bar. I really like using the 4 BD pods over the 20" rigid bar. The bar seems to not place the light where expected, the pods are very direct. I'd be willing to fabricate a new custom grill after seeing the LP9's first hand. The LP9 look like a very sweet setup.
    Right now I want to wrap up a few projects before taking on more work..
  12. Apr 14, 2018 at 6:20 PM
    MESO
    State of Jefferson
    Awesome light! My only gripe was the DRL is really dim(3 Amber LEDs; 1 behind the BD logo, and 2 higher up tucked behind the reflector cones).
    So I had to custom it up a little...
    ***WARNING*** This will probably void warranty :D
    First, I didn't like the excessive chrome. So I blacked out the side shrouds and left only the vital chrome for the reflector areas
    Then I CNC'd a heatsink to house a new DRL emitter (3-up Luxon rebels with a 1000mA buckpuck driver stuffed inside)
    Optics installed(spot) so it will shine right thought the logo on the outter lens.
    I unplugged the DRL wire inside the light and redirected it to my new DRL. That way the factory waterproof seal with wire pass through is untouched.
    And on! WAY brighter than stock.. sorry Baja:/. but the high beam is awesome!!
    Since this is going on my motorcycle I wanted to be as visible as can be
    bxh likes this.
  13. Apr 15, 2018 at 4:07 AM
    crux
    New Mexico
    OR
    That is a sweet emitter. I have a few laying around and think they are going to be turn signals/stop lights for a pending build
  14. Apr 15, 2018 at 8:45 AM
    MESO
    State of Jefferson
    Yup. I have some 1-ups (red And amber) that I'll be using in a custom brake light
  15. Apr 15, 2018 at 1:34 PM
    #35
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    @Baja Designs, time to re-tool. This would be great, especially if there was an option in a harness to wire in with the stock truck DRL.
  16. Apr 15, 2018 at 5:57 PM
    #36
    Baja Designs
    San Marcos, CA
    Yes - your warranty isn't valid anymore. We don't expect you to have any issues but please keep this in mind.
    www.bajadesigns.com
  17. Apr 15, 2018 at 5:58 PM
    #37
    MESO
    State of Jefferson
    :yes:
  18. Apr 15, 2018 at 5:58 PM
    #38
    Baja Designs
    San Marcos, CA
  19. May 1, 2018 at 7:54 AM
    #39
    Baja Designs
    San Marcos, CA
  20. May 1, 2018 at 8:32 AM
    #40
    MESO
    State of Jefferson
    This light just looks at home on bikes
    ebbs15 likes this.
