Baja Designs LP9 - The Most Advanced 8" LED Light on the Market Today!
Discussion in 'Lighting' started by Baja Designs, Aug 29, 2017.
  1. Sep 16, 2018 at 10:27 AM
    #61
    catastrofe
    catastrofe Well-Known Member
    Bob
    Montrose, CO
    2022 F350 Tremor
    Stay with us now :D...the question was related to the BD harness, linked in post where he asked the question.
  2. Sep 16, 2018 at 10:39 AM
    #62
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    sure lol.
    BD harness not needed when using a switchpro.
  3. Sep 17, 2018 at 1:00 PM
    #63
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Since you are using the Switch Pros setup you will NOT need the Baja Designs wiring harness. We include the opposite side connector, pins, and seals which allow you to wire the light yourself. You can run the wiring directly from the light to the switch pros. We recommend 12 gauge wiring for the LP9.
    Using the Baja Designs harness and Switch Pros together isn't necessary and will complicate the install.
    Baja Designs
    www.bajadesigns.com
    TACOVRD[QUOTED] likes this.
  4. Sep 17, 2018 at 1:01 PM
    #64
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Perfect.
    texvet61 likes this.
  5. Oct 2, 2018 at 9:00 PM
    #65
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Man I love this light every time I click it on. I did have to upgrade my battery and stator to keep up with it but dang it throws some light.
    Street lights.. don’t need no stinking street lights!
    ToyotaDriver and TACOVRD like this.
  6. Oct 2, 2018 at 9:23 PM
    #66
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    :drool:
  7. Oct 3, 2018 at 8:29 AM
    #67
    Baja Designs
    San Marcos, CA
    What output is the upgraded stator? Not too surprised you had to upgrade considering the power draw of the LP9
    Baja Designs
    www.bajadesigns.com
  8. Mar 27, 2019 at 11:32 AM
    #68
    Baja Designs
    San Marcos, CA
    @t4arghhh (IG) aerial shot of dual amber LP9 Pros and amber Squadron Sports.
    Perfect combination of near-field, mid-field and distance.
    www.bajadesigns.com
    55498742_2461216477274692_38742659679324_a98161f242e8198d96ef174cb2f244fc589b7070.jpg
  9. May 2, 2021 at 4:44 PM
    #69
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    what is the difference between the LP9 Pro Amber and LP9 Racer Amber? If any...I ask because I ordered what was sold as LP9 Racer and I got LP9 Pro spot.
  10. May 3, 2021 at 10:35 AM
    #70
    Baja Designs
    San Marcos, CA
    Uh oh, that is not correct. There may have been a shipping error. I'm happy to look into it if you can send me your order number/information in a PM.
    The Racer Edition is essentially a more tightly concentrated spot pattern. Using a different combination of LEDs, the light produces a narrower beam that penetrates farther downrange.
  11. May 5, 2021 at 7:16 PM
    #71
    texvet61
    Ocala, FL
    09 Tacoma TRD Sport
    :facepalm:never mind... turns out it was my inattention to the detail of Amazon slight of hand, still my mistake for not paying attention, oh well no harm, I'm sure the LP9 Pros are an awesome light with long throw, especially coupled with LP4Pro & S2Pro combo, I'll have plenty of light at all distance
    s, especially if I change the lenses on the L4's, guess if I was doing 120 across the desert I'd have to send em back for the Racers.
    :burnrubber::rofl:
  12. Oct 11, 2021 at 2:16 PM
    #72
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    Hi @Baja Designs . Do you know if the LP9 or LP6 lights would interfere with the 3rd gen TSS sensors up front if mounted on a steel bumper at either side of the sensor?
  13. Oct 11, 2021 at 2:35 PM
    #73
    Baja Designs
    San Marcos, CA
    I'm sorry, we haven't had one of those in the shop to do a full inspection and provide an affirmative answer on this.
    Fletcher37[QUOTED] likes this.
  14. Oct 11, 2021 at 3:13 PM
    #74
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I can't confirm on a Tacoma for sure, but I know for a fact that folks with Tundras do it all of the time mounted atop a C4 bumper and the sensors work just fine.
  15. Apr 2, 2023 at 12:06 AM
    #75
    Mix 99.3
    Mix 99.3 Well-Known Member
    How do their low beams compare?
  16. Apr 3, 2023 at 11:28 AM
    #76
    Baja Designs
    San Marcos, CA
    It would be a very similar light pattern just less intense with the low beam.
    Best,
    Brandon
    Mix 99.3[QUOTED] likes this.
  17. Apr 3, 2023 at 11:47 AM
    #77
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    I have a pair of the LP9 Racer editions and the low beams are still pretty damn bright and illuminate just as far. A few years ago I was somewhere outside of Moab in the middle of the night and didn't want to run into any wildlife so I turned on the lights and was able to see rock formations a few miles out in the distance. Only difference between the low and hi-beam was the intensity as mentioned above.
    Keep in mind that the side shooters turn on with either of the beam patterns so you still get really good coverage directly in front of your vehicle.
