Baja Designs - Plug and Play - LED Fog Pocket Kits
Discussion in 'Lighting' started by Baja Designs, Mar 24, 2016.
  1. Mar 21, 2018 at 8:23 AM
    #461
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Bailey - Indeed a useful video, but a perfect example of the lack of CAREFUL documentation; that video does not mention or show anything to do with how the 'padding' for the tabs might be installed/used/required.
  2. Mar 21, 2018 at 8:25 AM
    #462
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
  3. Mar 21, 2018 at 9:04 AM
    #463
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    The video was before the foam was included. I have forwarded your previous post to our product development team who handles instructions.
    -Bailey, Baja Designs
    www.bajadesignscom
    Rob Daman likes this.
  4. Mar 21, 2018 at 9:07 AM
    #464
    Mike O
    Could you say here exactly how the foam is to be used? Per instructions you are to cut it into 4 pieces. Assuming one for each tab. But looking at the tabs and how they fit in the slots, I'm at a loss as to what the foam is supposed to do and therefore exactly how it should be placed on the tab.
    Thanks!
  5. Mar 21, 2018 at 9:10 AM
    #465
    Baja Designs
    San Marcos, CA
    The foam is designed to be cut into 4 pieces and applied onto the "ears" or tabs on the stainless bracket. From there you have to compress the foam while sliding the "ears" or tabs into the mounting location. When this is done it prevents vibration. This image might be a little clearer showing where to apply the foam:
  6. Mar 21, 2018 at 9:19 AM
    #466
    Mike O
    Thank you. I suppose it should have been clear to compressed the foam and slip into the tab. I suppose its time to remove and re-install as the stability would be helpful. And BTW, those instructions are fine; similar, but not what I received.
  7. Mar 25, 2018 at 4:21 AM
    #467
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    I like these lights but considering these are street friendly...I think not! These are not bright, these are stupid bright lol. Even with it tilted all the way down with the wide Cornering lense, these things spread light like no other. Don’t get me wrong, these lights would be great for off-road use and for off-road use only. Now to look for some pods...
    mcharfauros likes this.
  8. Mar 29, 2018 at 11:50 AM
    #468
    Baja Designs
    San Marcos, CA
    ready6delta and mcharfauros like this.
  9. Apr 2, 2018 at 10:02 PM
    #469
    Mooseman537
    Mooseman537 Well-Known Member
    Jim
    Pennsylvania
    2017 MGM Tacoma OR
    I recently purchased and received my Squadron r sports with fog pocket kit and installed the lights today. Is it possible I was sent two sets of brackets for the drive side? I was unable to install the passenger side light as described in the instructions. Instead I had to flip the passenger light to have the heat sinks on the bottom for the mounts to work. I tried many different combinations but the brackets would not work. it seems they should be reversed for the passenger side. Has any had this issue? Am I nuts? I can post I pictures if need be to better explain. @Baja Designs please help!
  10. Apr 3, 2018 at 6:29 AM
    #470
    Baja Designs
    San Marcos, CA
    It sounds like we accidentally sent you an incorrect set. Please send our customer service team an email (info@bajadesigns.com). Include as many details as possible and we'll get you a new set.
    www.bajadesigns.com
  11. Apr 3, 2018 at 3:34 PM
    #471
    Mooseman537
    Jim
    Pennsylvania
    2017 MGM Tacoma OR
    Awesome thank you. I love the lights great product! Email was sent
  12. Apr 4, 2018 at 5:46 PM
    #472
    Natpag
    Natpag Well-Known Member
    2017 White Tacoma TRD off-road
    Is there any set up yet that is plug and play for an ARB summit bumper on the 3rd gen? I'm itching so badly to have some yellow fogs from BD!
  13. Apr 4, 2018 at 5:56 PM
    #473
    Baja Designs
    San Marcos, CA
    We don't have anything designed to be Plug and Play but some of our products could work. Do you have photos of how the fog lights are mounted in the housing?
    I'm not 100% sure if this is correct (quick google search):
    If so, with a little modifications, the following kit could work:
    https://www.bajadesigns.com/product...a-Tundra-07-13-Tacoma-05-11-Fog-Light-Kit.asp
    It's hard to say without seeing the product in person or having detailed measurements but the mounting styles are very similar.
  14. Apr 6, 2018 at 6:02 PM
    #474
    Mason04
    Mason04 Well-Known Member
    Texas
    18 TRD OR 4x4, 17 4runner TRD OR 4x4, 75 FJ40, 94 4x4
    I’m really enjoying my new amber fog lights. Thanks @Baja Designs!
  15. Apr 7, 2018 at 10:03 AM
    #475
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    Installed mine this morning. I tried the foam, but just couldn't make it work (too thick) so I made a few wraps of electrical tape to make the tabs fit snug.
    Really easy install the hardest part is probably getting to the tabs to get the truck's black shroud around the fogs off. The bezel isn't a snug fit to the shroud but I don't think the stock fogs fit snug either.
    ready6delta likes this.
  16. Apr 9, 2018 at 6:50 AM
    #476
    Baja Designs
    San Marcos, CA
  17. Apr 9, 2018 at 6:51 AM
    #477
    Baja Designs
    San Marcos, CA
    Nice job on the install. Thanks for sharing :thumbsup:
    Hextall[QUOTED] likes this.
  18. Apr 10, 2018 at 2:15 PM
    #478
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Installed Squadron Sport with Yellow Combo;
    Foam worked as described, I've also added a hole to the bumper and a ziptie on the bottom outside as well.
    Re-wired the BD harness to use CH4x4 switches, Relays, and add-a-fuse from the high beam circuit.
    ready6delta and Baja Designs[OP] like this.
  19. May 1, 2018 at 7:54 AM
    #479
    Baja Designs
    San Marcos, CA
    These are in stock and ready to ship! Orders yours now with your forum discount.
    Code: BDForums
    www.bajadesigns.com
  20. May 1, 2018 at 8:15 AM
    #480
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Maybe we are looking at different products, but the first post on this thread says that these are Not DOT approved and are illegal to use on the road.
