Baja Designs S1 | Over 2k Lumens from a single LED light
Discussion in 'Lighting' started by Baja Designs, Sep 14, 2019.
  1. Oct 4, 2020 at 3:57 PM
    #181
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    I'll probably always be turning them on independent of each other depending on how camp is setup.
  2. Oct 4, 2020 at 4:02 PM
    #182
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Sounds good!
  3. Oct 4, 2020 at 4:08 PM
    #183
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I may need a set of these for my ATV...
    memario1214 likes this.
  4. Oct 17, 2020 at 9:23 AM
    #184
    Hyland33
    Andrew
    Leicester, MA
    Got my S1’s mounted last weekend and wired them up this morning now that my switches showed up.
    D33FD3DB-B919-464E-ACF3-11E40560153A.jpg 201F291B-6643-42AA-B5A1-27524DF1C9A8.jpg D53845AA-828C-4DF2-9FE6-BE8C20B1ABAC.jpg
    CttAznRanger likes this.
  5. Nov 19, 2020 at 2:37 PM
    #185
    BendRunner
    BendRunner Member
    06 4runner v8
    what gauge wire did you use for each of the s1's? they have individual wires for power running to each correct? Single ground?
  6. Nov 22, 2020 at 3:29 AM
    #186
    Hyland33
    Andrew
    Leicester, MA
    I ran a single 12 to both switches(probably overkill), then out to the lights I ran 16’s from each switch to the light it controlled. (Both power and ground were run this way)
    BendRunner[QUOTED] likes this.
  7. Nov 28, 2020 at 10:41 AM
    #187
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Know what's BS? I had my daughter driving our old PT cruiser (don't laugh, it was a hand-me-down). The fog light switch broke (Stuck ~25% on :confused:), but to replace it meant pulling the steering wheel and replacing the whole stalk ($$$). I said forget it and just pulled the fuse. Inspector said if the car is equipped with fogs, then they must function properly. Ended up dropping ~$300 to replace the whole stalk. (Looking back, I should have tried to manufacture some kind of smooth, factory looking covers to make it look like they weren't even there (Base model prob. did not have fogs). That damn Chrysler nickle and dimed me to death...
  8. Dec 22, 2020 at 10:13 AM
    #188
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Has anyone played with running one of these off of a 18650 based battery pack? Im thinking for a bicycle light or a helmet light.
  9. Dec 22, 2020 at 10:30 AM
    #189
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    There is potential that it would work. You would have to put at least 3 of those in series to get enough operating voltage. That might last you a little over an hour of usage.
    Of course this is all theoretical, so it might take more fiddling around to get it to what you need.
    mtnkid85[QUOTED] likes this.
  10. Dec 30, 2020 at 8:30 PM
    #190
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Does anyone have any night shots of the s1 with spot beam pattern? (Sorry didn’t look through the entire thread)
  11. Dec 31, 2020 at 5:41 AM
    #191
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    J/k....that's over 100,000 lumens of XL goodness.
  12. Dec 31, 2020 at 5:42 AM
    #192
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You just wanted to show off.
    Rome604[QUOTED] likes this.
  13. Dec 31, 2020 at 5:43 AM
    #193
    Rome604
    Dave
    Alexandria, VA
    Yes....is there any other use for TacomaWorld?
    EatSleepTacos[QUOTED] likes this.
  14. Dec 31, 2020 at 5:44 AM
    #194
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yes, asking what the best lift is and asking how big of tires you can run.
    CttAznRanger and Rome604[QUOTED] like this.
  15. Dec 31, 2020 at 5:45 AM
    #195
    Rome604
    Dave
    Alexandria, VA
    Well, if someone would just answer the question I'm sure it would stop being asked!!!
  16. Dec 31, 2020 at 7:29 AM
    #196
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Haha this for sure.
  17. Dec 31, 2020 at 7:30 AM
    #197
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Shoot I wish the s1 spot put out that much light! I’d be all over that
  18. Dec 31, 2020 at 8:12 AM
    #198
    CttAznRanger
    Brandon
    Boston, MA
    So would I! Unfortunately I don't have any spots, all I am running are work/scene ones.
  19. Dec 31, 2020 at 8:27 AM
    #199
    Rome604
    Dave
    Alexandria, VA
    The hot spot in the middle is actually two XL lasers. They really reach out there.
  20. Jan 18, 2021 at 11:04 AM
    #200
    Hyland33
    Andrew
    Leicester, MA
    Any updates on the rock guards?
