Baja Designs S1 | Over 2k Lumens from a single LED light
Discussion in 'Lighting' started by Baja Designs, Sep 14, 2019.
  1. Sep 11, 2020 at 9:51 AM
    #161
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Still a decent photo showing the range and brightness.
  2. Sep 13, 2020 at 10:40 AM
    #162
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    That is AWESOME!!
  3. Sep 13, 2020 at 7:36 PM
    #163
    taco2uesday
    taco2uesday Well-Known Member
    1999 Tacoma SR5 TRD 5 Speed
    Map Lights, Grey Wire Mod,
    Sorry for the delay. Theses were just half assed I probably could of done a little better. I used the DJI mavic pro, but fuck DJI, their products are buggy as hell and they don't stand behind their product even when it doesn't work out of the box.
    As far as night shots go you're going to need to do full manual. I wouldn't go to high on the ISO because its gonna look horrible. As far as focus goes, DJI is once again dog shit. Even if you go to manual focus it will focus a mile past infinity which makes zero sense. If you can get it to focus at all make sure you go to manual so it'll hold it.
    Good luck.
    Rome604[QUOTED] likes this.
  4. Sep 13, 2020 at 7:39 PM
    #164
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    I'm glad I'm not the only one who feels that way about DJI. I hate them as a company. I'll never give them another dollar.
    taco2uesday[QUOTED] likes this.
  5. Sep 13, 2020 at 7:43 PM
    #165
    taco2uesday
    Seriously, fuck that company. Ill go out of my way to talk shit about them.
    Sorry Baja for going off topic in your thread but I couldn't hold back when it comes to that horrible company. Ill buy more lights soon ;)
  6. Sep 19, 2020 at 12:50 AM
    #166
    GMAN62465
    Gary
    Can I get this to work with my Rago brackets... Without major shaking??
    CttAznRanger likes this.
  7. Sep 20, 2020 at 12:13 AM
    #167
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Can’t wait for mine to come in. Coming from cheap auxbeam side shooters I’m excited to see what the more expensive options can do!
    GMAN62465 and Tacospike like this.
  8. Sep 20, 2020 at 4:19 PM
    #168
    roguegs
    Angelo
    V8 T4R
    QQ - for those who are running these off switch panels - where did you have to cut the wiring harness in order to put onto the switch panel (i.e. sPod, Auxbeam, etc)
    GMAN62465 likes this.
  9. Sep 20, 2020 at 5:03 PM
    #169
    Rome604
    Dave
    Alexandria, VA
    SPod --- wire --- lights
    Your sPod controls the lights....so you only need to hook up the 12v hot and ground from the sPod directly to the lights. I'd recommend you ask someone to help you with it.
  10. Sep 29, 2020 at 3:34 PM
    #170
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    So I’m going to be adding an S1 to each side of my roof rack for scene lighting. Am I better off buying two singles if I want to power them separately rather than buying a pair? I’m assuming the harness is different between a single and pair.
  11. Sep 29, 2020 at 3:36 PM
    #171
    Rome604
    Dave
    Alexandria, VA
    Buy a pair. The singles don't come with a harness at all. Plus the pair is like $10 cheaper or something.
    Hyland33[QUOTED] likes this.
  12. Sep 29, 2020 at 3:42 PM
    #172
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Bingo
  13. Sep 29, 2020 at 3:47 PM
    #173
    Hyland33
    Andrew
    Leicester, MA
    Good to know. I figured they might have come with a harness for just a single light. But if they don't i'll go with the pair and put my own together
    memario1214 likes this.
  14. Oct 3, 2020 at 4:21 PM
    #174
    Hyland33
    Andrew
    Leicester, MA
    Anyone have any pictures of the harness? How long is it? Does it use a relay or just a switch because of the low draw?
  15. Oct 3, 2020 at 6:53 PM
    #175
    memario1214
    Colton
    Missoula, MT
    I can get you some pics tomorrow. Tag me in this thread or PM me tomorrow evening in case I forget.
    I can tell you that it's approx 13ft and it is just a switch and an inline fuse. No relay.
  16. Oct 4, 2020 at 2:35 PM
    #176
    memario1214
    Colton
    Missoula, MT
  17. Oct 4, 2020 at 3:09 PM
    #177
    Hyland33
    Andrew
    Leicester, MA
    Awesome! Thanks a bunch. I’m wiring them to my aux fuse block and each light will be on a separate switch so I’ll probably only be using the plugs from the harness.
  18. Oct 4, 2020 at 3:15 PM
    #178
    memario1214
    Colton
    Missoula, MT
    Unless your use case is simple ditch or front bumper light setup these harness aren't much good IMO. You'll have plugs with bared leads in the box as well. I would just use them if I were you. However, the purchase of a pair is still cheaper so you want to go that route!
  19. Oct 4, 2020 at 3:22 PM
    #179
    Hyland33
    Andrew
    Leicester, MA
    I’m using them for scene lights. One will be mounted to each side of my roof rack. My fuse block is in the back seat and the switches are by the shifter. So power will come from the back seat to the shifter area, and then back out the grommet in the back of the cab and up to the roof.
  20. Oct 4, 2020 at 3:24 PM
    #180
    memario1214
    Colton
    Missoula, MT
    Just gonna run one single lead out to them, or will you be occasionally turning them on independent of one another?
