Baja Designs s8 40"
Discussion in 'Lighting' started by OffroadToy, Apr 7, 2024.
  1. Apr 7, 2024 at 12:22 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Getting this rooftop light bar in amber and wondered if i change out the 2 amber lens in the middle to clear will they then be white light or are the leds amber colored?
  2. Apr 7, 2024 at 1:44 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you're correct that the led's are white, so a clear lens will make for white output.
    just be sure to use the new included o-ring gaskets during the swap. re-using the old gaskets is a known failure point that can have water egress into the light later on.
    OffroadToy[OP] likes this.
