Baja Designs | Squadron SAE | Shipping Now!!!
Discussion in 'Lighting' started by Baja Designs, Jun 8, 2019.
  1. Jun 14, 2019 at 9:19 PM
    #41
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
    Any thoughts on how these would compare to the Rigid SAE yellow fogs?
  2. Jun 14, 2019 at 10:04 PM
    #42
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Jun 15, 2019 at 9:00 AM
    #43
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    The OA dimensions are tricky to find,
    Also I might just be bad at reading.
    These should fit inside of a plate bumper’s fog light cutouts, correct? Just like a different BD light fits? Same body and all that?
    Lunchmeat79 likes this.
  4. Jun 15, 2019 at 9:10 AM
    #44
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Same BD body, different optic. So yes it should fit.
  5. Jun 15, 2019 at 2:01 PM
    #45
    GhostedRaptor62
    GhostedRaptor62 Well-Known Member
    Greenville, SC
    Dose anyone know if you can swap the lens from the sae to a driving combo? I dont have a Tacoma, own a f150 i know i know but ford forum vs Tacoma the Tacoma has more knowledge. Im wondering is it just unique optics/lens? I plan on running them as the sae fogs until i get a winch bumper, if it has the larger hole ill run the bajas, if not ill order the ridgid sae fogs and convert the bajas to the driving combo and mount them on my a pillar. Although i still will wait for @crashnburn80 review of them, he has done one of the, if not the best write ups ive read in a long time. Baja should send him a set of the white and amber to test.
  6. Jun 15, 2019 at 3:26 PM
    #46
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    https://www.tacomaworld.com/threads/baja-designs-plug-and-play-led-fog-pocket-kits.423635/
    Somewhere in this thread it says that just swapping the lens will not work. It’s an entirely different light. So much so, that Baja Designs decided to not even offer a retrofit to turn existing lights into SAE accepted lights. Your only option, if you want the Baja Design, is the buy the SAE fogs.
  7. Jun 15, 2019 at 3:47 PM
    #47
    GhostedRaptor62
    Greenville, SC
    I was thinking i read that somewhere that it was more than just the lens, have they said anything about swapping white to amber or vice cersa? My factory HIDs are pretty good but halogen fogs are lacking. Not sure if i want the white or amber fogs yet. Thats the reason ive been looking and waiting on the BD lights, hopefully they will let us change the lens out.
  8. Jun 15, 2019 at 4:02 PM
    #48
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Thank you for an excellent SAE solution for fog lights, question though, in the picture is shown on the first page it doesn’t look like there is much, if any actual cut off line in the night output shots. Do these not have a moderately sharp cutoff line against a frontal wall or side walls? It appears to just be a lot of scattered (but very useable) light.
    crashnburn80 likes this.
  9. Jun 15, 2019 at 4:32 PM
    #49
    El Taco Blanco
    Stock (for now)
    They are making amber and white. I do know that you can swap from clear to amber lenses on the other lights, so I would think you could do the same with the SAE’s, if you ever change your mind on the color. But, I’m not 100% sure. If you tag Baja Designs with a question, he will probably be happy to answer.
  10. Jun 16, 2019 at 12:55 AM
    #50
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The lights will be included in the thread at the time of release, just like every other SAE fog.
    AssQuake likes this.
  11. Jun 20, 2019 at 12:32 PM
    #51
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    You will not be able to change colors. We don't plan on offering any sort of SAE lens kit.
  12. Jun 20, 2019 at 12:59 PM
    #52
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    This actually makes a ton of sense. I was wondering how you could make swappable lenses since I'm guessing they are marked SAE somewhere on them. Otherwise people could buy the marked lenses and put them on non-SAE lights.
    Coot83 likes this.
  13. Jun 27, 2019 at 11:54 PM
    #53
    Thorian
    Thorian Well-Known Member
    Marco
    Los Angeles, CA
    2017 4x4 White Tacoma
    Kings 2.5 Front and Rear, Baja Kit UCAs, Dakar Medium Leaf Pack, SSO Slimline Bumper
    Still no ambers kit
  14. Jun 28, 2019 at 4:21 PM
    #54
    Corey00d
    Corey00d Member
    2019 TDR Offroad
    Slickestwilly, Rome604 and Thorian like this.
  15. Jun 28, 2019 at 5:17 PM
    #55
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    @Baja Designs Quick question: for those running aftermarket steel bumpers, do I need to purchase the entire kit (light + vehicle specific mounting kit), or will just ordering the lights suffice?
    For reference, I’m looking at putting these fogs into a DEMELLO bumper.
  16. Jun 28, 2019 at 5:51 PM
    #56
    Baja Designs
    San Marcos, CA
    Ordering the lights only will be just fine. Call us and we can sell you fog adapters so you can plug into the factory wiring
    jrcuevasv likes this.
  17. Jun 28, 2019 at 5:51 PM
    #57
    Baja Designs
    San Marcos, CA
    The Squadron SAE is the first street LED offering from Baja Designs. This light retains the same form factor as the rest of our Squadron Series, but the pattern and circuitry are optimized to give our SAE Squadron a road-approved punch! We’ve put this light through rigorous tests to ensure that it would be an upgrade from common LED and Halogen factory fog lights. If you want to upgrade your daily driver with a road-legal product, the Squadron SAE line is for you.
    NOTE FOR CUSTOMERS WITH EXISTING PRE-ORDERS:
    If you have an existing order for White Squadron SAE lights and would like to adjust for the new Amber Squadron SAE option, please contact jdf@bajadesigns.com. ​
    Specifications:
    Lumens: 2,480
    Volts: 13.8V
    Amps: 1.6 amp
    Watts: 22 watts
    Dimensions: 3.07" x 2.77" x 3.07"
    Weight: 12 ounces
    LED Life Expectancy: 49,930 Hours
    Front Lens: Hard Coated Polycarbonate Housing: Hard Anodized & Powder Coated Cast Aluminum Bezel: Billet Machined Aluminum Hardware & Bracket Material: Stainless Steel Exceeds MIL-STD810G (Mil-Spec Testing) Built-In Overvoltage Protection
    IP69K (Waterproof, Submersible to 9ft)
    IK10 Compliant (Mechanical Impact Testing)​
    Baja Designs Features:
    Satisfactions Guarantee – 30 Day Money Back Guarantee
    Limited Lifetime Warranty – Complete Purchase Protection
    ClearView® – All The Light, Right Where You Need It.
    MoistureBlockTM – Waterproof, Rain Proof, Submersible
    CopperDrive® – Only LED Driven At 100%
    5000K Daylight – Less Driver Fatigue, Natural Color​
    Rome604 and Slickestwilly like this.
  18. Jun 28, 2019 at 6:44 PM
    #58
    Rome604
    Dave
    Alexandria, VA
    When you say "now available" does that mean the preorders are being shipped and people can purchase on the website?
  19. Jun 28, 2019 at 6:58 PM
    #59
    Slickestwilly
    Slickestwilly Well-Known Member
    Will
    NH
    25 Pro
    Well I was gonna wait for @crashnburn80 to review the ambers before deciding on a set of fogs but sometimes the impulse buy just happens.
    PSA don’t drink and Tacomaworld...
  20. Jun 28, 2019 at 7:08 PM
    #60
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Maybe I’m missing it but what’s the part # for SAE Amber plug and play kit for 16+ Tacoma
    Thanks
