Baja Designs Squadron Sport NOT WORKING!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deserttacoma84, Apr 4, 2020.
  1. Apr 4, 2020 at 1:07 AM
    deserttacoma84
    deserttacoma84 [OP] Well-Known Member
    Phoenix
    06 Tacoma SR5
    AirRaid Intake Fabtech 6" Coilover Lift 33" BFG All Terrains
    Just installeda pair of squadron sports using the gen 2 fog adapter harness. Supposed to be "plug and play". I did just that, turn on truck and no lights! Am i missing something here? Stock lights worked before hooking these up.
    It appears adapter only plugs in one way... thoughts?
  2. Apr 4, 2020 at 1:32 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Should be plug-and-play yes. And the harness should only go one way. The tab should click over, and be pretty straight forward. Only wildcard I have seen happen here is if one of the metal pins inside gets bent or pushed to the side. The odds of it being that way on both lights is pretty slim though...
    Truck is running, headlights are on, and the stalk is on low beam correct?
  3. Apr 4, 2020 at 2:09 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Did you connect the pins and harness in the plug and play? You need to get the polarity right, I've had this happen on other lights before and you just need to switch how you put the pins in the plastic clip. Problem is getting them back out of the clip can sometimes break it if you aren't careful, so be careful pulling them back out if that is the case.
  4. Apr 4, 2020 at 2:56 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Yup, probably just need to reverse the polarity. I also would have bought SAE rated fog lights but as long as you don't use them on road you should be gucci
    NYCTaco52 and bassbrick like this.
  5. Apr 4, 2020 at 7:21 AM
    deserttacoma84
    Phoenix
    06 Tacoma SR5
    The wires were already connected on both ends when I recieved the unopened package? I assume, try to disconnect ends and switch them around?
  6. Apr 4, 2020 at 7:56 AM
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    If you are good troubleshooting circuits a few steps to consider:
    - Try the factor fogs, if working then the truck has a good circuit
    - Use a multi-meter checking continuity on the BD adapter, if good then there should be power
    - Measure voltage with the multi-meter from the truck, if good plug in the BD adapter and measure voltage again. This should be the same voltage
    - Connect a 12VDC supply (can be the battery) to the connector on the light
    This should help you and BD determine where the problem might exist. BD is typically very good at helping with their lights when needed.
  7. Apr 4, 2020 at 8:31 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    BD uses high-quality Weather Pack connectors. The easiest/best way to release the terminals and switch them around is this, the right tool for the job. You'll likely damage the whole connector assembly if you try to release them without it.
  8. Apr 4, 2020 at 9:35 AM
    20somethingwidataco
    Will
    Washington State
    Not likely, the connector pins should be held on with small clips. I used a tiny flathead and a steady hand to release the pin and swap stuff around
    Bridge4 likes this.
  9. Apr 4, 2020 at 7:52 PM
    deserttacoma84
    Phoenix
    06 Tacoma SR5
    We got it. One of the harness adapters was backwards. The other was good to go. One blown fuse later, and its dialed in!
    Thanks dudes!
    Shaggs, blackradon, Larzzzz and 3 others like this.
  10. Aug 22, 2021 at 7:14 PM
    Emko1717
    Emko1717 New Member
    The Baja design squadron sport have a black/white wire combo at the end of the connector. The “plug n play” adapter has a black/brown wire combo. The stock wire color are green/white. The combo goes like this, stock green has to match brown on “plug n play” adapter, brown from “plug n play adapter” has to match white n the Baja connector side. Problem solved
