Baja Designs ◦ RTL-M Rear Taillight w/ License Plate Mount + More
Discussion in 'Lighting' started by Baja Designs, Oct 11, 2017.
  1. Oct 11, 2017 at 12:34 PM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    RTL-M, Rear Tail Light
    https://www.bajadesigns.com/products/Rear-Tail-Lights.asp
    M stands for Mini and at 6-inches this light bar will be exceptionally useful on vehicles where space is limited. The RTL-M includes 5 Red LEDs which function as your tail and brake lights, 2 Center Mounted White LEDs with Flood optics, and 1 LED the projects light down for license plate illumination. We are very excited to bring this Mini RTL to market for Jeeps, Toyotas, Full Size trucks, and other great applications. We will be offering the RTL-M in 2 Models and 2 Mounting Accessories available including a License Plate Mount and Spare Tire Mount.
    RTL-M w/ License Plate Light - $249.95
    https://www.bajadesigns.com/Products/RTL-m-6-inch-rear-Light-Bar.asp
    RTL-M w/o License Plate Light - $219.95
    https://www.bajadesigns.com/Products/RTL-M-6-inch-Light-Bar-No-Plate-Light.asp
    Mounting Kits:
    RTL-M, License Plate Mount Kit - $19.95
    https://www.bajadesigns.com/Products/RTL-M-License-Plate-Mount-Kit.asp
    RTL-M, Spare Tire Mount Kit - $79.95
    https://www.bajadesigns.com/Products/RTL-M-Spare-Tire-Mount-Kit.asp
    Don't forget we offer a Forum Discount! Enter "BDForums" at checkout to save 10% + $5 shipping to the Lower 48!
    www.bajadesigns.com
    -Bailey, Baja Designs
    bailey@bajadesigns.com
  2. Oct 12, 2017 at 10:40 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Sick. I plan on doing the 30" RTL on the back of my custom roof rack. Should be plenty visible LOL
    ChadsPride likes this.
  3. Oct 13, 2017 at 11:43 AM
    Baja Designs
    San Marcos, CA
    MESO[QUOTED] likes this.
  4. Oct 30, 2017 at 9:22 PM
    MESO
    State of Jefferson
    @Baja Designs
    Question: Do the amber turn signals on the RTL-S have a built in flasher(i.e when supplied with constant power they flash by themselves)
    Or
    would they work tying into my existing turn signals and flash at the same frequency when supplied with a pulsed input ?
    Thanks
  5. Oct 31, 2017 at 8:09 AM
    Baja Designs
    San Marcos, CA
    The RTL-S does NOT have a built in flasher for the Amber. If you tap into your existing turn signal wiring then the Amber will flash at the same frequency.
  6. Oct 31, 2017 at 8:13 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    D
    Do you still sell those in 6"
  7. Oct 31, 2017 at 8:14 AM
    Baja Designs
    San Marcos, CA
  8. Oct 31, 2017 at 8:24 AM
    paranoid56
    San Diego
    14 double cab taco
  9. Oct 31, 2017 at 8:50 AM
    Baja Designs
    San Marcos, CA
  10. Oct 31, 2017 at 10:55 AM
    MESO
    State of Jefferson
    Thank you:)
    Trying to decide If I want to run them as chase lights constant, or individual turn signals.
    Or both..
  11. Jan 21, 2018 at 4:37 PM
    Baja Designs
    San Marcos, CA
    JGS2164 likes this.
  12. Aug 23, 2018 at 1:01 PM
    Baja Designs
    San Marcos, CA
    JGS2164 likes this.
  13. Jan 20, 2019 at 4:13 PM
    amag413
    amag413 Well-Known Member
    Aaron
    Philly
    2014 Black Tacoma TRD Sport | Double Cab SB
    JD Fab 2.25 kit, Homemade flatbed, Four Wheel Camper
    Would the rtl-m be able to be used as the 3rd brake light on a truck cap? Im wondering if anyone has done this and could share how they mounted it. I need working lights in the back for launching boats at night and don't really want to cut holes for recessed lights in the bumper. Using the rtl-m would result in a much cleaner look imho and put the light source much higher. Would this provide enough light or would you suggest the recessed s2 light route? Also, I would try to use the caps existing light cover/lense and mount the rtl-m behind it to maintain the seal. Would this result in a less visible light because it is recessed? would it still work as intended? I would love to see you guys (baja designs) make a mounting bracket/ system specifically for truck cap 3rd brake lights. I think this would be a perfect use for your light!
    SportsmanJake likes this.
  14. Jan 21, 2019 at 11:02 AM
    Baja Designs
    San Marcos, CA
    Mounting the RTL-M behind your third brake light lens will change the performance of the light. It would be best if you had the light unobstructed and as high on the vehicle as possible.
    Do you have a photo of your cap? I'll take a peek and see if we have anything compatible
    Baja Designs
    www.bajadesigns.com
  15. Jan 22, 2019 at 1:52 PM
    amag413
    Aaron
    Philly
    Here is what the light looks like from the outside. It sits flush with the fiberglass and there is a large hole where the light is. The second picture shows what is inside, I believe that there are two threaded holes on either side of the lens and the fiberglass cap is sandwiched between the lens and the light, with two screws, to create the seal. It would also be cool to use the license plate light as an interior dome light if it could be controlled separately. Thanks for your response!IMG_0337.jpgimages.jpg
  16. Jan 23, 2019 at 8:35 AM
    Baja Designs
    San Marcos, CA
    It looks like the clearances would be too tight to fit the RTL-M inside the housing. You'd have to completely modify the inside of the shell and light housing.
    Have you considered mounting an RTL-M under the crossbars? It wouldn't light up the bed but would be a great location for brake light visibility
  17. Jan 24, 2019 at 5:45 AM
    amag413
    Aaron
    Philly
    I did not really consider that route because I already have a working 3rd brake light and have no need for another one. I will most likely mount some light pods up there instead. fyi, the light on my cap is is not average it is a leer xq with recessed light. Most leer models, like the 100r, have a large indent for the light with just a small hole for the wire to feed into. Your light may work on these models. If you guys can come up with an interface to the recessed light, I know I would buy one! Thanks for your time!
  18. Oct 4, 2020 at 7:38 AM
    #NEVERGIVEUP
    #NEVERGIVEUP Well-Known Member
    California
    2017 Quicksand DCSB TRD OR
    TBD
    Did you ever do this on your roof rack? I’m thinking about the same, but wasn’t sure how to mount this on my front runner roof rack. Any suggestions or pictures please? Thanks
