Baja Kits +2 ?
Discussion in 'Long Travel Suspension' started by Gunshot-6A, Oct 18, 2018.
Baja Kits +2?
  1. Do it!
    21 vote(s)
    40.4%
  2. Save your money and go FULL LT!
    19 vote(s)
    36.5%
  3. Undecided / Your mom
    12 vote(s)
    23.1%
  1. Oct 18, 2018 at 10:21 AM
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Need some outside opinions y'all. I'm looking at scooping up some new LCAs while I'm dealing with seized cam bolts, and it got me thinking: What's the thoughts on the+2 Kit from Baja Kits through Filthy motorsports?
    I like it because as far as the kit literature shows, it looks like I can re-use my OEM King kit, which would save me the coin and hassle of having to pick up new C/Os and sell my old ones at a loss despite being 3 months old.
    I guess the potential downside I see is that if you want to go LT, go FULL LT, and this seems like a little bit of a "make it work" kit. Maybe that's just in my uninformed eyes, since as I see it, Baja Kits / Brenthel Ind. wouldn't try to sell a poorly put together kit.
  2. Oct 18, 2018 at 5:40 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I haven't put to many miles on my kit since I had it installed, but I don't have any complaints. The only part of the kit that I didn't like was the brake lines because they are universal lines with adapters. I ordered lines of the same length on here instead of using the lines that were provided.
    Since the OEM Kings can be used with the kit, you could run them while you save up for the specific setup that will give you a bit more travel.
    LTDSC and Gunshot-6A[OP] like this.
  3. Oct 19, 2018 at 7:49 AM
    Gunshot-6A
    Conner
    Everett, WA
    True. Thanks for the chat yesterday about the kit. Really appreciate being able to sound it out. :thumbsup:
    buyobuyo[QUOTED] likes this.
  4. Oct 19, 2018 at 7:51 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    id go 3.5 if i was going through the trouble again :spending:
    Coot83 and Gunshot-6A[OP] like this.
  5. Oct 19, 2018 at 8:28 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    I think dirt kings 3.5 kit will allow stock replacement coilovers
  6. Oct 19, 2018 at 8:34 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I'm sorry but that's so half assed. If you want LT go get the right shocks!!!
    Or stay stock
    Gunshot-6A[OP] likes this.
  7. Oct 19, 2018 at 8:37 AM
    Gunshot-6A
    Conner
    Everett, WA
    Hence my question. Although it would help if you could stop gap it on the way to full LT.
  8. Oct 19, 2018 at 8:39 AM
    TrapComa
    Mason
    Cedar Park, TX
    Obviously LT coilovers will perform better, but I don't think that kings and LT arms is half assed
  9. Oct 19, 2018 at 8:40 AM
    TrapComa
    Mason
    Cedar Park, TX
    I would definitely say get the 3.5 over the 2". You'll need fiberglass but its worth it
  10. Oct 19, 2018 at 8:42 AM
    TireFire
    Olympic Peninsula
    Sometimes you can't have everything.
    I'm not familiar with this particular kit but sounds like your shocks will act as limit straps if they even fit
  11. Oct 19, 2018 at 8:51 AM
    TrapComa
    Mason
    Cedar Park, TX
    Shocks like that have limiting protection in them. They're the limit strap on a stock setup as well.
  12. Oct 19, 2018 at 8:54 AM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I've loved my Baja Kits +2 kit and I've put quite a few miles on it. Try hitting up @BPaulin_ before ordering through Filthy, since he actually works there :thumbsup:
  13. Oct 19, 2018 at 9:01 AM
    BPaulin_
    BPaulin_ Well-Known Member
    Bruno
    Orange County, CA
    2010 Tacoma TRD Off Road
    Baja Kits +2 LT Kit
    shoot me an email. I can help you out and answer all your questions. or give me a call. 7144173530. I work at BK.
  14. Oct 19, 2018 at 9:03 AM
    Gunshot-6A
    Conner
    Everett, WA
    Sounds good. I'll give you a ring this afternoon.
    BPaulin_[QUOTED] likes this.
  15. Oct 19, 2018 at 9:16 AM
    TireFire
    Olympic Peninsula
    No, the ball joints are.
    And please show me what limiting protection you're talking about
  16. Oct 19, 2018 at 9:24 AM
    Gunshot-6A
    Conner
    Everett, WA
    Kings have an internal bump stop, but to compare it to a proper limit strap would be unfair.
  17. Oct 19, 2018 at 9:26 AM
    BPaulin_
    Bruno
    Orange County, CA
    Baja Kits +2 LT Kit
    shocks have internal spacers to limit the droop of the shock. you can have a 16" shock with an internal spacer to make it a 14" or 12" shock.
    If your OEM coilovers are ext travel you'll be fine. if they aren't all you have to do is open them up, remove the .5-1.0" spacer and that will make them ext. travel.
    I tested the oem Kings with the +2 kit on my truck. I ran it like that for about 15k miles. zero issues, the truck handled well and I added limit straps to avoid putting too much stress on uniballs, bushings and misaligns.
  18. Oct 19, 2018 at 9:28 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    If you’re ok with opening a whole new can of worms, like fiberglass, rear LT, Frame bracing, and driving characteristics that are not ideal for daily road use, then I’d go 3.5+ LT.
    But if you want to stay spring over (in any form) for the rear, not deal with fiberglass, or save some $, I’d go with the Baja Kits.
    I heavily considered them before I got my kit.
    I went 3.5”, but I also am 2wd and going fast is my only goal. I daily it, and am ok with the nuances, but I do recognize the compromises from a stock truck.
    I voted for the Baja Kits...
    Califor2A and BPaulin_ like this.
  19. Oct 19, 2018 at 9:48 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    What driving characteristics does a +3.5 kit exhibit that a +2 does not?
    Falldownhard likes this.
  20. Oct 19, 2018 at 9:53 AM
    Gunshot-6A
    Conner
    Everett, WA
    Part of the reason I wanted to stick with +2 was I like to mob in the desert, but I've also got the whole "overland" style going on. Not sure how conducive Tepui tents, etc are to the LT life. Wouldn't mind some extra capability, but not looking to build a full LT prerunner. Like I was talking with @buyobuyo , I'd find a rear end totalled taco or tundra and go full retard LT on that. I might do wider front fenders, only because one of mine is tweaked from a prior accident (Semi backed into me). The GFC truck has been my inspiration lately.
