Baja Tow Package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulK, Jul 16, 2013.
  1. Jul 16, 2013 at 10:29 AM
    PaulK
    PaulK [OP] Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Hi all. I’m new to the group, having just bought my first Toyota. I picked up a 2013 Access Cab Baja Edition about a month ago, and have a question regarding the tow package that’s on it. Everything that I have read indicated that the Baja’s got the TRD Off-Road tow package with TSC (trailer sway control), trailer brake integration, and a 7-pin connector. That’s all I can find in the manual as well. However, my truck has a 4-pin connector, and no evidence of TSC. The Toyota website and customer support have been useless, and the dealer has already told me several things that are wrong. So, I have come to the experts at TacomaWorld.com for help. Can anyone tell me what I’ve got in terms of towing – hitch class, TSC or not, trailer brake compatibility, receiver size…?
    Thanks in advance. I look forward to many years with my new Taco.
    Paul
  2. Jul 16, 2013 at 10:34 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Welcome to TW! Not too familiar with the new towing systems, someone will chime in.
  3. Jul 16, 2013 at 1:04 PM
    PaulK
    Paul
    Pittsburgh, PA
    So while I'm waiting I checked the sticker on the hitch itself. Itsays for V6 trucks it is rated at 5000 max trailer weight, and 500 max tongueweight. The manual says 6500 max trailerweight. WTF? It also says I need TSC - which I can’t findon this truck. I was planning to rent aU-Haul car trailer to take my ’68 Firebird to my buddy’s speed shop two-and-a-halfhighway hours away. Doesn’t look likethat’s going to happen now. :(
  4. Jul 16, 2013 at 1:21 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    ...IF you have the tow package.
    The tow package is an optional package. You probably just have the tow hitch accessory which is rated at 5000.
    welcome
  5. Jul 16, 2013 at 1:22 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Are you sure it was a factory install to a dealer install? Sounds like a dealer install if it is a 4 pin.
  6. Jul 16, 2013 at 1:59 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
  7. Jul 16, 2013 at 2:00 PM
    PaulK
    Paul
    Pittsburgh, PA
    Pulled out the window sticker and the hitch is on there as factoryinstalled, but there is no tow package listed. My bad for assuming. Didn’t buythe Baja to tow with, so not a big issue – the need to trailer my car just cameup and this seemed like an easy option. Would like to have the extra fluid/oil coolers and big alternatorthough. I wonder if it would be possibleto have the full tow package installed by the dealer. The fluid coolers, alternator, battery, class IV hitch,7-pin connector, and TSC is what Toyota lists for the package. Seems pretty straight forward if the wiringis there. Every heard of this beingdone?
  8. Jul 16, 2013 at 2:08 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Sounds like you might've gotten hosed like my uncle did when he bought his 4-Runner. The dealer told him it had the factory tow package while really it was a dealer installed hitch and harness. I made sure to check for the tranny cooler, 7 pin harness, etc when I bought my taco so I knew it was the factory tow package.
  9. Jul 16, 2013 at 2:48 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    A good indicative would be if it came with a separate Trailer Brake Jumper Harness. I just got a 2009 4x4 OR with the towing package and I found that connector harness in the glove compartment along with the manual. I also noticed the tranny cooler and engine oil cooler? I had this same setup on my previous 2001 Dodge Dakota Cuad Cab 4x4 with the towing package also, so I figured is the norm for towing.
  10. Jul 16, 2013 at 2:54 PM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Everyones right about not getting the factory tow package. Just make sure you didn't pay for it!
  11. Jul 16, 2013 at 4:53 PM
    PaulK
    Paul
    Pittsburgh, PA
    Well, no tow package. A factory installed hitch on the sticker, but nothing else. Paid a fair price that was well under sticker for the truck, and it was not easy finding a Baja, so no worries about getting ripped. The dealer never said tow package - I must have read it somewhere, saw the hitch and made an incorrect assumption.
    So, now that I know what I know, does anyone know if the tow package can be dealer installed? I don't really need it now, but it would be nice to have the beefed up cooling and charging systems.
    Thanks for the help.
  12. Jul 16, 2013 at 5:04 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Trans cooler is easy. Aftermarkets are easy install and cheap. You would probably not want to pay for am alternator upgrade and probably not needed unless you add lights and want to charge batteries while towing.
  13. Jul 18, 2013 at 6:36 AM
    PaulK
    Paul
    Pittsburgh, PA
    I have put aftermarket trans coolers on hot rods before, but I would like to keep everything factory in appearence.
    Can the factory oil and trans coolers be added as bolt-ons? Can TSC be added? Can trailer brake integration be added?
    Also, assuming that I can't get to factory specs for the tow package, can I just add a better hitch to up the max tow weight to 6500? Are the leaf springs different between a tow package and non-tow package truck?
  14. Jul 30, 2013 at 12:36 PM
    Joe in the hills
    Joe in the hills Well-Known Member
    Joe
    Cleveland, SC
    Timberline Mica SR5 TRD Offroad Towing Pk
    TJM Bull Bar Bumper, 7100 Bilstiens on FE, 4 Leaf Spring Retro
    I got the towing package w/ my truck it has the extra coolers, and 7 pin connector. It never arrived at the dealers location because I picked it up at Southeastern Distribution Center when it arrived from Baja mfr facility.
    Had to get the local dealership to install the 4 leaf rear suspension, and didn't notice any difference in ride until I installed the TJM bull bar bumper and had to change out the front shocks to Bilsteins.
