Baja TX tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomacaribe, Aug 21, 2013.
  1. Aug 21, 2013 at 8:54 PM
    Tacomacaribe
    Tacomacaribe [OP] Well-Known Member
    Arlington VA
    2013 Tacoma TX Baja
    My Baja door decal say 46 psi front and rear. Its seems like too much. the ride is very rough. What you guys think? Too much air? Any recommendation on air pressure?
  2. Aug 21, 2013 at 8:57 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Sure it does. 46PSI MAX. Somewhere next to that it says 32 front and 34 rear or something.
  3. Aug 21, 2013 at 8:59 PM
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    What about me? Im runnin 265/75/16 on the same rims (stock off a trd FJ) just a little bigger tire on a similar setup. 3in toytec lift, Dakar leafs.
    Or should I just do the ol classic chalk test?
  4. Aug 21, 2013 at 9:02 PM
    Tacomacaribe
    Arlington VA
    2013 Tacoma TX Baja
    Smuggiesrider. What psi you running now?
  5. Aug 21, 2013 at 9:03 PM
    fenderpicks
    fenderpicks Well-Known Member
    i would like to know as well... i also have a BAJA
  6. Aug 21, 2013 at 9:05 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    I'd keep the front in the mid 30's and rear in low 30's
  7. Aug 21, 2013 at 9:07 PM
    Tacomacaribe
    Arlington VA
    2013 Tacoma TX Baja
    Nowhere does it say 32 front 34 rear.
    It just say 46 front and rear
  8. Aug 21, 2013 at 9:09 PM
    Tacomacaribe
    Arlington VA
    2013 Tacoma TX Baja
    By the way the tires are BFG All Terrain 265/70/16 D rated.
  9. Aug 21, 2013 at 9:19 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I would run 34 front, 32 rear. I have Load E KM2's and I run 40 front, 38 rear.
  10. Aug 21, 2013 at 9:24 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  11. Aug 21, 2013 at 9:36 PM
    Tacomacaribe
    Arlington VA
    2013 Tacoma TX Baja
    Thanks guys!!
  12. Aug 21, 2013 at 9:56 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    2012 Tacoma TRD T|X Baja
    Pelfreybilt IFS Skid, Mid Skid and Plate Bumper, Rigid Industries Dually's, ARB CKMA12 On Board Air, Kenwood TM-281A Radio, Rear view mirror relocation bracket, Wheelers SuperBumps, Toytec Baja Spacer
    Dealer always fills mine to 46
  13. Aug 21, 2013 at 10:06 PM
    alegav
    alegav TeamBlue
    Alex
    San Diego, CA
    It's even 46 in the manual
  14. Aug 21, 2013 at 11:31 PM
    mr2mki
    mr2mki Well-Known Member
    I don't have a Baja, but good heavens! 46PSI? My door card says my stock tires should be 29F/32R cold. Or possibly the other way, 32F/29R, but anyway.
  15. Aug 22, 2013 at 3:38 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I know with the BFG ATs that Baja's are higher. I have 42 in mine and ride is fine. Dealer mentioned the higher pressure when I picked it up. Discount said to run 40 in my Duratracs on Prerunner. I will check my door sticker.
  16. Aug 22, 2013 at 3:47 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    first gen 26f 29r
    second gen 29f 32r
    taken off driver door sticker, both TRD Taco models..
    46lbs has got to feel like driving on concrete tires....
  17. Aug 22, 2013 at 3:51 AM
    tagaman670
    tagaman670 Hafa Adai!
    joey
    Saipan, CNMI
    White "BAJA" DCSB
    performance shift knob +5hp decal Tint Rockford Fosgate 6x9's JL Audio 8" Sub RockFord Fosgate POWER 550x amp
    I have a Baja and it says 46 too. If you run em at 35 the tpms would go off.. And when I filled them back up to 45-46 they went away
  18. Aug 22, 2013 at 4:15 AM
    Jeremy M.
    Jeremy M. Well-Known Member
    Fort Drum, NY
    13 DCSB TRD Off Road
    The difference is the BFG AT KO is a light truck tire, which require higher pressures for the load rating. Here is and article from tire rack that talks about it.
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=70
    If you want even more info take a look here:
    http://forum.ih8mud.com/80-series-tech/111671-tire-inflation-ultimate-answer.html
    The rough ride is a result of the heavy duty truck tires on verse the p-rated that come factory installed on most Tacomas.
    InfernoTRDPro likes this.
  19. Aug 22, 2013 at 7:02 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'll be damned.
  20. Aug 22, 2013 at 8:19 AM
    smuggiesrider
    Vermont
    I'm running 36psi front and back.
    Bf TA/KO 265/75/16 load E.
    again take offs from a fj.
    I haven't done the chalk test but I got 300 miles to my last tank of gas.
