Bak Flip F1 tie down options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Mar 16, 2011.
  1. Mar 16, 2011 at 6:54 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Hello,
    All of you with bakflip covers, how do you tie down your loads since the cover uses the whole rails system? Any good ideas? maybe another set of rails or more d rings?
  2. Mar 17, 2011 at 4:07 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Have the same issue. I use the D-rings with the front cleats. I think there's a member that did D-rings mod to the side rails.
  3. Mar 17, 2011 at 6:32 AM
    magnum922
    I didnt know you could still use the front cleats. I thought the bak flip used the front rail too. Should be getting mine any day now.
  4. Mar 17, 2011 at 6:44 AM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    nope the front rail is free and the cleats still fit. i use that and also did the D-ring mod to my front and middle bed bolts which are way more secure for heavier loads. also when you put your bakflip rails over the bed side rails, there are 3 screws you use. when its all said and done, those screws stick out a bit and i just put a D-ring on each of those. so its like i have my side rails back. so that is 6 D-rings total (3 on each side) to use in place of the cleats. add those with the 4 bed bolt D-rings and the 2 factory D-rings by the tailgate and the 4 original cleats moved to the front rail = you have 16 points anchor some ties to secure a load.
  5. Apr 18, 2011 at 10:47 PM
    vsick
    vsick Well-Known Member
    T,
    Any pics of the D rings and those screws you speak of? I just installed my bakflip HD over the weekend. I also just ordered 5 D rings for the bed, maybe I should have ordered a couple more to mount to the rails? anyway I am likin the bakflip, I hope it adds 1mpg
  6. Apr 19, 2011 at 6:22 PM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Didn't take the pics before the Bakflip rails when on, but you can see the D-rings here.
  7. Apr 19, 2011 at 6:41 PM
    t-frax
    Cali
    Here it is. Mine is kind of like how Bookmonke has his but mine are over the bakflip rail as opposed to under it. I did that because i felt if i put it over the bakflip rail, the rail would be more flush and level with the factory bed rail than if i were to put the drings under it.
  8. Apr 23, 2011 at 1:08 PM
    Jmaimin
    Jmaimin Member
    Julian
    Where did you get those D-rings from?
  9. May 16, 2011 at 12:25 PM
    Norcan
    Norcan What we don't have we make.
    Jerry
    Elora, ON Canada
    11 Tacoma Double Cab TRD
    Bakflip F1, BakBox, Sportwing Colour matched door mouldings, Weathertech floor liners, Toyota running boards,Toyota Hood Deflector,Pop N Lock power tailgate lock, Custom Otterbox defender mount for IPhone 4, Blu Logic Large button kit, BonGiovi DPS, fog light on with parking light low beam and high beam mod, TRD Exhaust, Muth heated signal mirrors, Liquid Metal Rhino Wheels in Black!, Redline Elite hoodlifts, EZ down tailgate,
    X2 where did you get the rings???
  10. May 17, 2011 at 3:31 AM
    bookmonke
    Mark
    Jacksonville, FL
