Bak Running Boards
Discussion in 'Product Reviews' started by rothcomm, Feb 7, 2011.
  1. Feb 7, 2011 at 5:36 PM
    rothcomm
    rothcomm [OP] Hawaii Taco
    Michael
    Honolulu
    11 Tacoma SR5 Prerunner
    Trifecta tonneau cover, Class 3 Tow package, Window deflectors, Wet Okole seat covers.
    I order the Bak Running Boards for my 2011 Tacooma double cab and they came in on Sat. They are about 4' too short of the supports. I was assured by 4 Wheel parts that they would fit. They advised me today that Bak is aware of the problem and is making new boards to fit. I have no idea how long it will take. Take notice that the 2011 double cab is different than the earlier models where the boats mount.
  2. Feb 7, 2011 at 5:43 PM
    Range 44
    Range 44 Well-Known Member
    Georgia
    2008 FJ TTE
    So previous year running boards wont fit a 2011?
  3. Feb 7, 2011 at 5:45 PM
    Range 44
    Georgia
    2008 FJ TTE
    Or is it just the Bak product?
  4. Feb 8, 2011 at 10:00 AM
    rothcomm
    Michael
    Honolulu
    It appears to be all 2011 Taco's have moved the aft mounting holes 3.5 inches aft. More when I can confirm. If you are ordering Boards use the measurement of 70.5 as the minimum distance between front and back supports. The ones sent me are 67".
  5. Feb 8, 2011 at 10:05 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    I'd be going grrrr.
    I have been taking my time deciding what to put on my 2011 regular cab. I think some manufactures know the hole location changed and others hoped it didn't
  6. Feb 8, 2011 at 10:12 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    can you just drill new holes into your frame?
  7. Feb 9, 2011 at 1:17 PM
    rothcomm
    Michael
    Honolulu
    The holes have a threaded nut welded on the back side and are covered by a plastic insert you remove. They are for the factory supplied running boards. You can not access the 'backside" where the nut is.
  8. Feb 9, 2011 at 1:32 PM
    rothcomm
    Michael
    Honolulu
    I just spoke with the Bak rep. They told me they will refund my purchase and shipping. We are in Honolulu. They only have 67" and 90" tracks. The 2011 Tacoma will need a 70.5" rack to reach the three support brackets.
