BAKFLIP cover / accessing factory rail
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomaj, Apr 19, 2014.
  1. Apr 19, 2014 at 2:16 AM
    Tacomaj
    Tacomaj [OP] Active Member
    Texas
    anyone that has a bak flip understand what I'm talking about.
    has anyone tried to notch the bakflip rail so that the factory rail could be accessed? or even if you could, would things like tie offs, and bike mounts not work because they live in the same real-estate as the cover?
    thanks
  2. Apr 19, 2014 at 4:58 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    How would you do that? I don't know? I have an Undercover tri fold and finally gave up trying to figure it out. I would like to use all the attachments that came with the truck but I'm in the same soup as you are.
  3. Apr 19, 2014 at 6:12 AM
    Tacomaj
    Texas
    im not even sure if its possible. i need to climb under and have a look myself.
    i was thinking that the vertical part of the angle that bolts the bakflip frame to the inside of the bed wall could be notched in places, allowing access to only certain spots. essentially the tie down brackets that are normally adjustable would be fixed to one spot. which, if it work should be better than nothing.
    but that all depend on if the bakflip mounting rail is continuous the length of the bed, and is solid enough to be able to give up 2 or 3 inches in a couple of spots.
    i just figured that if it is possible, someone here has already done it.
  4. Apr 19, 2014 at 6:20 AM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    I was wonder this myself, I wanted to run a bed rack with my tonneau cover. I know sounds weird but it would still give you concealable semi dry lockable space, with a rack system on top.
  5. Apr 19, 2014 at 9:44 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    The front cleats still works for tie downs but for side tie downs, you can add D-rings to the Bakflip bolts. As for transporting bikes, you can look into building those PVC bike racks or if fork mounted, you probably can just bolt those fork bike mounts to the bed.
    or mount these directly into bed:
