BakFlip F1 Drains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GregLee98, Mar 9, 2012.
  1. Mar 9, 2012 at 6:46 PM
    GregLee98 [OP] Well-Known Member
    Dec 7, 2011
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Just thought I would share where I installed the drains for my Bakflip F1.
    I installed them into the bed at the front corners. Drilled with a 5/8 boring bit gently and slowly through the liner at a 45 degree angle. This way I missed the metal part of the bed/cab. Pushed tubes through, left them long, pics show why. Spray painted the tubes flat black to make them less noticeable and then filled the area around the holes with rubber spray coating to seal up. Finally, zip stripped the tubed to the bed between the cab and the bed to keep them in place and out of the way.
    I may pull them out and spray paint the tubes that went through the cab, but didn't think about it until after the fact.
