BAKFlip G2 Tonneau cover Group buy **TACOMAS/TUNDRAS**CLOSED**
Discussion in 'Closed Group Buys' started by ramonortiz55, Nov 3, 2015.
  1. Nov 17, 2015 at 8:41 AM
    #141
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    The vendor is interested in doing a group buy for the 2016 bakflips for the 3rd gen guys. If this happens, I will add you to that list so you can get one for your second gen. Keep your eyes peeled.
    The purchase period closed bud.
    I can add you to the next list, see my comment to @TRDRACER above.
  2. Nov 17, 2015 at 8:46 AM
    #142
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    There's gotta be something we can do for the guy... he's in the military. I'm sure they were up to something and that's why he couldn't do it...
  3. Nov 17, 2015 at 8:54 AM
    #143
    ramonortiz55
    Ramon
    Texas
    stock
    That's what I am working on right now, I would love to hook him up right now... If we can't do it now, it will be in the next group buy. He PMd me his contact info so I can contact him when we're ready if that's the case.
    918Huck likes this.
  4. Nov 17, 2015 at 8:58 AM
    #144
    Cativelense
    Nuno
    CT
    Great. Fingers crossed they can "hook up" a service guy.
  5. Nov 17, 2015 at 8:35 PM
    #145
    Cativelense
    Nuno
    CT
    OK, so I finally got to installing mine while the wife was putting the little guy to sleep tonight. So here goes my "review" and sorry in advance for the "book".
    I'd like to start off by saying a huge thank you to Ramon for putting this Group Buy together. The guy definitely hooks everybody up by putting in his time and effort in doing these things, so... THANK YOU!
    Next, I'm not very mechanically/installation/automotive inclined. No problems in admitting that. So this is all fairly new to me. Never really got into this sort of thing before so learning as I go along.
    Package came in Monday afternoon via FedEx. As expected with any shipment, there were a few marks on the outside of the box, a few rips, but nothing serious and nothing out of the ordinary from what I am used to seeing not only at my job, but packages received at home as well.
    Upon opening the box, everything inside seemed OK as I suspected. The packaging job seemed really good. They used the spray foam stuff that I have seen being used at a vendor my company purchases products from, as well as our warehouse using it. So good job on the packaging!
    As far as the installation part, not being very good at this sort of stuff as I mentioned before, it took me a lot longer than I'm sure it did most of you, or will. Being the "perfectionist" I think I am and like to be, it took me quite a while to get the side rails installed and placed correctly. After much doing and undoing, I "gave up" and went with what I thought was an OK job. After that, I placed the cover on the rails, snapped it in and fiddled with it quite a bit to make sure the lips were where they were supposed to be both on the rails, and on the front and tailgates. I think I placed them well enough to cover all sides and hopefully not get any water in there. Obviously I did not use the draining tubes as I did not see where and how they could be installed, but kept them just in case. The rest was fairly easy, so that didn't take much longer.
    Sorry if the pics look crappy. It's inside my garage and lighting isn't very good in there.
    With all of that said, I think I did an OK job, but I think it'll need to be tweaked a bit to see if I can get it to be more "flush" mounted as I think it should be. So not a product issue, but more of an installer/installation issue. Again, new at this. I think all sides should sit and fit much better than what they are now. Especially on the tailgate, since it doesn't quite sit on there like I think it should. The only "downside" I see to this is that I can't use the stock rails and have the bed cleats mounted as the cover rails cover the stock rail up. That's not a bad thing since I'll be primarily using the cover in the winter, to keep snow from pilling up in the bed and then hauling it around.
    Thanks for taking the time to read this. Definitely please with the quality of the product for sure. Was using a crappy/cheap leather cover just to get by, and this is by far way way superior. I even think it's better than the cover my buddy has on his Tundra (he also has a hard cover but a bit different), and I think he paid a lot more than I did.
    918Huck likes this.
  6. Nov 18, 2015 at 3:47 AM
    #146
    Hrynkowdm
    Hrynkowdm Member
    David
    Paoli, Pa.
    2011 Grey Tacoma TRD, Quad cab
  7. Nov 18, 2015 at 3:52 AM
    #147
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    @Cativelense thanks for the write-up! I'm pumped to get mine and put it on!
    Did you notice a gap on the cab side? I have heard of guys on some hard tri-folds putting in some extra Lowe's weather-stripping to fully weatherproof that side.
  8. Nov 18, 2015 at 5:22 AM
    #148
    Cativelense
    Nuno
    CT
    I did notice that, and there is a bit of a gap. I didn't take a pic of it because I completely forgot. In the box there is a long strip that's probably meant for that, not sure if the other peeps that already installed theirs used it or not, so hopefully they'll give their input & feedback on that!
    I do have a question though, for everyone on here. Can you and how do you drive with the cover open like you would a soft cover?
  9. Nov 18, 2015 at 8:40 AM
    #149
    ramonortiz55
    Ramon
    Texas
    stock
    TRDRACER likes this.
  10. Nov 18, 2015 at 9:20 AM
    #150
    Hrynkowdm
    Hrynkowdm Member
    David
    Paoli, Pa.
    Awesome, thanks for all your time
    And help on this, much appreciated!!!
    Dave
  11. Nov 18, 2015 at 9:28 AM
    #151
    ramonortiz55
    Ramon
    Texas
    stock
    did you get my PM?
    Please make payment today if possible.
  12. Nov 18, 2015 at 10:01 AM
    #152
    ramonortiz55
    Ramon
    Texas
    stock
    let me know when payment has been made. thanks
  13. Nov 18, 2015 at 10:20 AM
    #153
    Hrynkowdm
    Hrynkowdm Member
    David
    Paoli, Pa.
    Yes I got the info thanks.
    Dave
  14. Nov 18, 2015 at 12:52 PM
    #154
    TRDRACER
    TRDRACER Well-Known Member
    Beaverton, Oregon
    '15 TRD SPORT DCLB
    Just made my purchase. Such an awesome guy to work with!!! Lots of brownie points with Roman.
  15. Nov 18, 2015 at 12:56 PM
    #155
    ramonortiz55
    Ramon
    Texas
    stock
    make sure to post a review of the product and vendor, along with pics!
    Thanks bud!
  16. Nov 18, 2015 at 5:53 PM
    #156
    Hrynkowdm
    Hrynkowdm Member
    David
    Paoli, Pa.
    Ramon,
    Just purchased the cover, can't wait to install it. Thanks again
    For your time & patience, much
    Appreciated.
    It's awesome to be a part of this
    Group buy.
    Thanks again,
    Dave ( USMC / AF)
  17. Nov 18, 2015 at 6:20 PM
    #157
    ramonortiz55
    Ramon
    Texas
    stock
    thank you for your service brother.
    please post pics when you get it
  18. Nov 20, 2015 at 8:04 AM
    #158
    ramonortiz55
    Ramon
    Texas
    stock
  19. Nov 26, 2015 at 9:12 AM
    #159
    DanDiggity
    DanDiggity Well-Known Member
    Chantilly, VA
    2015 MGM DCSB OR
    After receiving my package last week, I finally had the time to install my Bakflip. I opted to upgrade to the FiberMax. Installation went easy, I also installed the optional bakflip hooks to the rails. Looks super sweet!
    Thanks @ramonortiz55 for setting this up and to the vendor for fast shipping!
  20. Nov 26, 2015 at 9:14 AM
    #160
    TacoTaco15
    Jake
    VA
    Looks great man! Thanks for following up with pictures - congrats!
