Bakflip MX4 Prelim Review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by socal4x, Jul 17, 2016.
  1. Apr 19, 2019 at 2:04 PM
    #421
    magicroy
    magicroy Well-Known Member
    Marty
    2016 Toyota Tacoma
    None yet
    Mine is a short bed and I drill down through top of fenders instead of bed. See post #11 in this thread.
  2. May 27, 2019 at 4:30 PM
    #422
    yoshm0
    yoshm0 Member
    So Cal
    2019 Toyota Tacoma Double Cab TRD Sport 4x2
    Much thanks for taking the time to compile this info. Thank you all that took the time to post regarding your experiences and fixes!
    Bought a Mx4 and the damn thing leaks. When I registered the cover, I made them aware of the leaking cover. I’ll use these mods and hopefully it’ll be a lot more rain proof than it currently is.
    bcgill[QUOTED] likes this.
  3. May 27, 2019 at 5:25 PM
    #423
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Nick
    Let us know if we can help with any info and pricing on covers. We offer most brands and sell a ton of the BAKFlip covers!
  4. Jun 4, 2019 at 2:56 PM
    #424
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    I did the 1/4" wide by 1/8" on the sides. Did 2 rows on the front of the cover.
    Was going to just wedge foam in there, but wanted to use the higher quality dense foam.
    Got a sheet from Hobby Lobby for $1.77. I think it was 12" x 18". There were 2 thickness. Got the thicker one. Then got the double sided sticky tape. It was $2.22 or something.
    I cut out squares and put them on top of the squares that Bakflip included. Then I closed up the other opening on the end of the rails with a L shaped piece. This made it look clean and didn't look bad. The foam matches the Bakflip foam they sent out. All of it was the same type.
    Going to RTV under the folding seals on top and where the border aluminum meets the panels.
    tekoma likes this.
  5. Jul 19, 2019 at 10:57 AM
    #425
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Awesome looking cover. question, after silicone sealing it up are you still able to remove it from the truck? or does removal involve cleaning up silicone and re applying when you re install? also will occasionally carry dirtbikes in the back of my Tacoma with tailgate down, do you guys think I could do this with the cover folded up against the glass and have the bikes front tire up to the front of the bed or would I need to remove the cover all together? is removal a pain?
    FishnTx likes this.
  6. Jul 19, 2019 at 11:08 AM
    #426
    FishnTx
    South East Texas
    ‘17 OR
    I’ve been lookin at these for a while now, was in the market for a diamond back , dont really like the double wing design. Soon as I get a chance I’m ordering a mx4
  7. Jul 31, 2019 at 4:59 PM
    #427
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    Getting ready to install on Friday and ordering extra rubber seals, I’ve got the 1/4” x 1/8” seal and tailgate gasket but where can I find this 3/16” seal and the gasket underneath? Or should I just use the 1/4 x 1/8” pieces also in these locations at the front and for the underneath at bulkhead gaskets
  8. Aug 1, 2019 at 5:24 AM
    #428
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    I just had some laying around. You can pretty much use scraps of anything 3/16” or less. I was just filling a small void that didn’t have a great way to seal. You could also put a glob of RTV.
    The gray gaskets underneath probably don’t do much, I just jammed them in there because I could still see a smidge of daylight. RTV is probably better to fill any tiny gap remaining. I think you could even apply it such that it doesn’t touch the truck bed on only fills between the other gaskets and the corner of the rails.
  9. Nov 20, 2019 at 4:21 PM
    #429
    Adoan
    Adoan Well-Known Member
    We got some rain here in SoCal and definitely have some water leaking through. I’m a little confused on where the weather stripping goes. Do I need to remove the cover bracket and put them between the bracket and the frame?
    blitzkrieg3002 likes this.
  10. Dec 3, 2019 at 2:56 PM
    #430
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    Just installed a new MX4 (redesigned?) and noticed foam at all the corners. It’s preventing the cover from sitting flush.
    Is this foam for packaging or actually for sealing? Seems to make the seal worse.
  11. Dec 4, 2019 at 6:34 PM
    #431
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    I'm pretty sure you need to remove that. I seem to recall those are just packaging. Regardless they aren't on the rails on my installed MX4 any more.
  12. Dec 4, 2019 at 8:47 PM
    #432
    viperbsd
    viperbsd Well-Known Member
    Sacramento, Ca
    2020 MGM TRD Pro Auto
    IMG_0132 2.jpg I just installed my MX4 yesterday and I wondered about the foam at the front corners as well. It does not look right, but I wanted to make sure they were not there for a reason before I removed them...
  13. Dec 5, 2019 at 10:45 AM
    #433
    bcgill
    Ben
  14. Dec 5, 2019 at 10:51 AM
    #434
    Admiral_Akbar
    '17
    I wonder when they redesigned it. Yours does not have the new plastic corner piece that ours have.
  15. Dec 5, 2019 at 10:52 AM
    #435
    bcgill
    Ben
    Hmm, mine's less than a year old. I bought it back in February, so recently!
  16. Dec 5, 2019 at 10:55 AM
    #436
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Redesign, I have the older version on my last truck and didnt have these same with my Dad's raptor, my new one has these, I was like WTF is this. It definatley looks odd and doesnt seem to be packing its on there good and would be overkill just to protect the seal in shipping, not sure why they added it.
    bcgill likes this.
  17. Dec 5, 2019 at 1:56 PM
    #437
    viperbsd
    Sacramento, Ca
    Update: Just spoke to BakFlip and the foam at each front corner is part of the new redesigned "finishing Kit" on the MX4. I was told that the foam should not be removed.
    Looks like they just redesigned the MX4 a very short time ago..
    bcgill and Admiral_Akbar like this.
  18. Dec 8, 2019 at 11:12 AM
    #438
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    So I’ve done all the foam, silicone, tailgate weatherstripping, got inside and 0 daylight anywhere when closed and mine still leaks. It’s not too bad but deff more than I would expect. I think the water is just getting into the channel where it’s supposed to drain down the tube and just not draining right and over flowing over the edge into the bed. Kind of sucks for how expensive this thing is to have this much water getting in.
  19. Dec 8, 2019 at 12:48 PM
    #439
    tekoma
    tekoma Member
    Apex, NC
    yep you will still get some leaks but they will be relatively insignificant. Without the extra seals the rails leak horrifically.
  20. Dec 8, 2019 at 2:23 PM
    #440
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I just tore the rails back off and added a bead of silicone down along the bed rail and re mounted the rails. I also added a piece of foam to the tailgate end of the bed rail as there was nothing on this end to prevent water from spilling out the end. And some silicone in a few other spots.
    We shall see. Got it all re installed now. Bring on the rain.
