BakFlip Roll-X
Discussion in 'Product Reviews' started by Onion27, Jan 1, 2013.
  1. Nov 16, 2013 at 8:08 AM
    rbenner89
    rbenner89 Well-Known Member
    NY
    '10 man tran TRD SR5
    so far so good. very little water in the bed. I keep the truck in the garage mostly so its not out in the pouring rain all that much. so far very happy with the purchase.
  2. Nov 22, 2013 at 2:10 PM
    Rustysix
    Rustysix Member
    12 PreRunner SR5
    rbenner89,
    I know that you are supposed to remove the accessory rail on the back of the bed to install the Roll-X cover. The problem is that I have to keep that rail installed (I have bed lights rigged underneath it). In your opinion is there any way to leave the rail installed and still install the Roll-X? Maybe with some modifications to either the Roll-X rails or to the acc rail in the back of the bed? Also how far back from the window does it extend when it is rolled up? 10"-12"?
    Rustysix
  3. Nov 24, 2013 at 2:23 PM
    rbenner89
    NY
    Hey Rustysix-
    1- i would estimate that when rolled up it extends about 8-10 inches.
    2- i don't think u can install it with the posterior rail. I have bed lights in my truck also and i stuck my Led strip along the back just above the ridges of the bed liner and it works great. check out the pic when the rollx is down flat
    i also included a pic of it rolled up so you can estimate the roll depth.
    hope that helps
  4. Nov 24, 2013 at 2:32 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    I have one of these as well and couldn't be happier. Came in handy my last trip. :eek:
  5. Dec 12, 2013 at 2:54 PM
    boostbaron
    boostbaron Well-Known Member
    City of Wind
    '13 Tacoma TRD Offroad
    Has anyone else had any slight fitment issues with the roll-x? It seems like when you install the rails all the way back in the rail, the spring mounted latch gets stuck, and when you move them forward I cant close the tailgate all the way.
  6. Dec 22, 2013 at 10:22 PM
    eyesurf2611
    eyesurf2611 Well-Known Member
    714 & 808
    09 Tacoma 4X4 DCLB & 4th Gen T4R
    *Icon Extended Travel Coilovers w/ 700lb. Coil *TC UCA *Rear Icon 2.0 w/ Resi *Rear All Pro Standards *ArmorTech Shackle Flip *All Pro Flip Kit *F&R Wheelers Bumps *All Pro Front Bumper w/ 10,500 Winch *All Pro Front Skid Plate *All Pro Trans Skid Plate *All Pro Mid Exhaust Skid *All Pro Rear Bumper w/Hitch *Rocky Road Outfitters Rock Sliders *Method Rims *Custom Bead Locks *305-70-17 Nitto Terra Grapplers *Hanneman Fiberglass Front Fenders *EBC Stage 5 Brake Kit *Bed Mounted HiLift *FrontRunner Roof Rack *50" Dual Amber/White LED Light Bar w/ Roof Rail Brackets *Custom One Off Removable Bed Rack *Satoshi Grill w/ BAMF Bar and (2) 20" LED Light Bars *Leather and Heated Seats *Full Audio/Video System
    I have one now for 4 months. Yes the fitment issue is common, I had to adjust and move it forward and back countless times to get that perfect fit where it covered the tailgate and was still over the rear of the bed rail. Yes you can still run the rear bed rail, you might have to take it off first and install the cover then reinstall it afterwards. Customer service front them is pretty poor in my case. I called for two reasons, the fitment issue and I had one of the straps that hold the cover rolled open break the first time I used it. I emailed with no response then called and they said they never received it and there was nothing they can do, wow thanks BakFlip Roll-X. Other than that, with a little extra work it turned out nice and works well.
  7. Dec 23, 2013 at 11:50 AM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Just dont pull it too tight, I broke one off already.
    Before I lock the end in I "flap it like a blanket" to align the tracks and flatten them out.
  8. Dec 29, 2013 at 11:42 AM
    shotgunshooter3
    shotgunshooter3 Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    Has anyone else has trouble with the "teeth" on each side matching up like they are supposed to?
  9. Dec 29, 2013 at 1:18 PM
    g35man
    League City, TX
    2012 MGM DC 4x4 OR
    Nope
  10. Jan 12, 2014 at 10:48 AM
    Rustysix
    Rustysix Member
    12 PreRunner SR5
    Does anyone have any tie down solutions with their Roll-X? I know BAK sells a set of 4 for $50, any other solutions. I was thinking about getting the Dodge Cargo D-rings from from the "Installed D-Rings Mod" and bolting them in with the BAK side rail bolts. Anyone done anything like this?
  11. Feb 27, 2014 at 4:52 AM
    brian0128
    brian0128 Well-Known Member
    Brian
    Orchard Beach, MD
    2012 TRD OR DCSB
    Factory tow package, 15% Llumar tint
    Is the Roll-X easy to remove if I need the full bed space? The flip covers seem quick to remove but I haven't read anything about this one.
  12. Feb 27, 2014 at 7:32 AM
    Rustysix
    Rustysix Member
    12 PreRunner SR5
    It's not too hard to remove. There are 2 bolts on either side and the top comes right off. I wouldn't want to be taking it on and off all the time though, it takes a bit of time to reinstall (getting it realigned and adjusted so that it seals front and back). When rolled it has a diameter of about 9" for the 5' cover 6' is probably closer to 10" or so.
  13. Mar 2, 2014 at 5:05 PM
    swopeti
    swopeti Active Member
    If anyone is interest I am selling mine for the short bed. I am in Dallas I guess I could ship or meet up somewhere in a reasonable drive. I liked it but need to sell to buy my camper shell I have had it about 2 year $650
  14. May 28, 2014 at 2:03 AM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Could any of you guys pull a measurement of the storage height in the bed with the roll - x closed? I wonder if it is lower than the regular bakflip covers. I have several storage bins that fit under the regular style bakflip perfectly. Also, how is the vinyl cover on the roll -x holding up? That seems to be the weak part of the design to me.
    I agree with the lack of customer service. First, I had a star nut break and cause my backflip to disengage and fall into the bed and scrape the back window. Then some weeks ago the cover totally self-destructed on my way home from work. This did wonders for the paint as it was clinging to the rubber seal and smashing into the bed side as I was stopping. Bakflip was not even concerned as I have had the cover since 2009.
  15. May 28, 2014 at 1:51 PM
    #35
    Rustysix
    Rustysix Member
    12 PreRunner SR5
    At the lowest point (the handle) the clearance is 16", everywhere else measures 17". Both measurements taken with Toyota factory bed mat installed. As for the vinyl, I have had no trouble with it, but I have had my cover less than a year and I live in sunny California.
  16. May 28, 2014 at 5:54 PM
    #36
    ThreeMan
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Rusty, Thank you for the quick reply. I will pull a tape when I get off of work. I have to replace the cover before I leave this job site for home. Good to hear about the vinyl, the only substantial warranty from Bakflip is on the F1 cover.
  17. May 30, 2014 at 8:29 AM
    #37
    ThreeMan
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Looks like they will work. Thanks for taking the time. I see a roll x in the near future.
  18. Oct 14, 2014 at 8:15 PM
    #38
    djmixerx
    djmixerx Active Member
    Bay Area
    '11 V6 Prerunner
    Looking for some.
    Been acouple months now. How does everyone like there Roll-x?
  19. Jan 1, 2015 at 5:21 PM
    #39
    DJFRENZY
    DJFRENZY Well-Known Member
    Bay Area, CA
    I'm also interested to know. Still can't decide which cover to get, but the Roll-x is top of my list so far.
  20. Jan 1, 2015 at 5:34 PM
    #40
    V0X
    V0X Well-Known Member
    Eric
    Ooltewah, TN
    TRD Pro Grille, MB TKO Wheels, BFG TA KO 265 70R17, Pop and Lock (color matched), Undercover SE Tonneau.
    if anyone is concerned about water getting into their bed, the bakflips "will" leak. I had two (G2 and the rollbak). I wound up getting an undercover SE which looks great on the truck and for me, has been BONE dry. Just my .02
