BAKFlip Toyota Tacoma Rail Relocation Brackets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011 Dbl LB, Aug 5, 2021.
  1. Aug 5, 2021 at 9:38 PM
    2011 Dbl LB
    2011 Dbl LB [OP] Member
    2011 Tacoma Prerunner TRD Dbl Cab Longbed
    I found relocation brackets / rails for the Tundra on the BAK Industries website. Couldn’t find them fir the Tacoma long bed? Ideas? Thank you, Mike
  2. Aug 6, 2021 at 7:35 AM
    74cam
    74cam Automotive Engineer
    Michigan
    2010 Tacoma TRD Sport 6spd
    TRD Supercharged, 3 inch lift, TRD beadlock wheels
    So I looked into this as well but never actually pulled the trigger. BAK customer service said I could use the Tacoma MX4 hardware kit since it comes with the relocation brackets (for reference I have the Bakflip G2)
    You can order the kit here, but it doesn't actually show the relocation brackets in the picture so I'm not 100% sure that it comes with it, but BAK customer service said it did...
    https://bakindustries.com/bakflip-hardware-kit/2009/toyota/tacoma
    If you end up purchasing the kit let me know, I've been wanting to move my rails so I can actually use them!
