baking headlights - is it safe??
Discussion in 'Lighting' started by cgs2k2, Nov 26, 2012.
  1. Nov 26, 2012 at 12:12 PM
    cgs2k2
    cgs2k2 [OP] old man
    is it safe to use your home oven to bake the headlights in?
    i know a lot of people do it for the BHLM so many people will say "yea, it's safe!"
    but is it? doesn't that release some kind of chemicals from the plastic that will linger in the over and be baked into your food?
    i know this is weird, and i'm not the paranoid type. but i'd rather not put my family at risk.
    like i know you're not supposed to use your home oven to cure painted parts.
    somebody set me straight.
  2. Nov 26, 2012 at 12:14 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    subbed...i also need to know cause my DRL Lenses are melted.does anybody know if you can buy just the lenses?
  3. Nov 26, 2012 at 12:19 PM
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    High heat and plastics releases dioxin. Dioxin are carcinogens and highly toxic to the cells of our bodies.
    I would recommend cleaning your oven after heating any headlights. The fumes along are very bad so try to minimize exposure to that as well.
  4. Nov 26, 2012 at 12:22 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    OP... i agree 100%. Putting anything plastic with sealent in the oven where you cook food can't be a good thing. It's pretty much common sense.
  5. Nov 26, 2012 at 12:25 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Personally, I would not put anything plastic in my oven. Especially not the one I cook my food in...
  6. Nov 26, 2012 at 12:27 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    great, just when I was about to do my BHLM you have to bring this shit up...thanks now I'm all paranoid about it too and now probably won't get to see pretty blacked out headlights on my truck...
  7. Nov 26, 2012 at 12:55 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Heat gun is your friend.
  8. Nov 26, 2012 at 1:10 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You aren't going to do a BHLM with a heat gun....lol.
    OP fwiw clean your oven out. You'll be fine. I'm no scientist but I'm still alive and healthy and I've done half a dozen already. Oven cleaner is far more harmful.
  9. Nov 26, 2012 at 1:11 PM
    Shauncho
    Shaun
    Parts Unknown...
    none
    :popcorn:
  10. Nov 26, 2012 at 1:13 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Use the heat gun to open up the headlights. It's not difficult but does take a bit longer. I still use my oven when I'm doing retrofits but only when the Mrs. isn't around... :cool:
  11. Nov 26, 2012 at 1:22 PM
    Hairy Taco
    North of Hell
    08 TRD
    aint that the truth of it....and just set the kids up downstairs with a movie:p
  12. Nov 26, 2012 at 1:37 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Now I am no chemist or doc but I did talk to a few in my family before I did this mod. Both said same thing. It’s not a good thing to do but if you are going to do it use the self-cleaner on the oven when finished. Because most ovens will get up to 800 to 900 degree F. And that is well enough to kill anything in the oven. Also said when that is done and cool. Reheat oven and bake something like cookies or something you are not going to eat and then throw it away.
    Also both had same comments... there have been plenty of stupid people out there that put Tupperware in the oven and duhhh it melts. OR they do the same thing in the microwave. Now do those people run out and buy new ovens or microwaves. No they don’t. They clean it up and use it again.
    I used mine and have been fine.
    Don't hold me to anything like I said I aint no Doc or Chemist.
  13. Nov 26, 2012 at 8:29 PM
    brian
    Elizabeth City, NC
    I can't imagine how long it must take you with a heat gun. Not to mention the uneven heating, risking melting them.
  14. Nov 26, 2012 at 8:30 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    The heatguns I have at work get pretty damn hot, I imagine it would be possible, but not nearly as easy as placing it within a hot oven.
  15. Nov 28, 2012 at 12:31 AM
    brian
    Elizabeth City, NC
    Its the uneven heating that I would be concerned about. Without the headlight being heated evenly and thoroughly you could be there all day if you don't burn it. Not saying its impossible I guess, just risky since its concentrated to one area.
  16. Nov 28, 2012 at 1:13 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I used the oven to take my housings apart. It was very easy. Putting them back together, however, I used a heat gun. On low it hits 500 degrees, high is 1000 degrees. I kept it at 500 and heated up the butyl tape until it looked like it was almost liquid, which did not take long at all. Then I clamped everything together. Everything sealed up just fine...I would not want to use it to take the housings apart though. I felt like it would melt the plastic before softening the glue because the gun was so hot.
  17. Nov 28, 2012 at 1:46 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Not worried about it. Can't be any worse than heating my food up in the microwave in a styrofoam or plastic container, or frozen dinners. meh
  18. Nov 28, 2012 at 1:58 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    burning plastics do indeed let off dangerous chemicals,some of them carcinogenic, but using this low heat shouldn't be hot enough to cause that kind of decomp
    MTopp likes this.
  19. Nov 28, 2012 at 2:40 AM
    eXtenzeHI
    eXtenzeHI Well-Known Member
    Honolulu
    2008 Speedway Blue X-runner
    TRD Boost | TRD 1st Gen CAI | 20X8.5/10.5 Staggered XXR 521 (Powdercoated White) Wrapped with 255/35/20; 275/35/20 Kumho Ecsta SPT | Full Vinyl Evo Mod | Black Billet Grille | Sticker Bomb'd Wink Mirror | WeatherTech Visors | Carbon Fiber Stubby Antenna | Pistachio Green X-brace | DJM UCA and LCA | DJM 3" Blocks No-Notch (for now) | Snugtop Tonneu | Morimoto FX-R with Gatling gun Shrouds and BHLM | Tinted Tails | Tinted "Hawaiian Islands" Third brake light | Fog light Mod | Tinted Tails | Nokya Hyper Yellow Fogs | SWB Painted Interior | Alpine Single Din | 10" Rockford Sub with box | Rockford Amps | Tweeters
    This should be correct. I think it takes a certain temp for plastic. I still cook my food in the oven and I'm fine.
  20. Nov 28, 2012 at 3:28 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Worried people can always just pay to not worry and purchase black'd out headlights then sell their oems. Just do it, there are shit ton of other ways you will die before stuff leftover from modding your headlights in the oven ever gets you. Hell, stuff in the food you are cooking is most likely just as bad as the plastic fumes are. Oh no, the black part of grilled stuff has carcinogens, how many people ever worry about that? Live, just live, nobody will ever see 125 anyway, lol.
