Balance Issues - General Grabber AT2
Discussion in 'Wheels & Tires' started by rollin904, Jul 26, 2017.
  1. Jul 26, 2017 at 4:46 AM
    rollin904
    rollin904 [OP] Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Wanting some feedback on potential balance issues with my Grabber tires. I've got 42k on them and still have some life left in them, but after having an alignment last week I'm still having issues with wobbles at highway speeds. Seems to fluctuate between only slightly annoying and the wobble of death. I'm running pro comp wheels and last had everything balanced in February.
    I do have a few other maintenance items I'll be performing in the near future, including the ECGS bushing and carrier bearing, but those seem unrelated to this issue.
    I guess I'm at the crossroad where I either buy new tires or potentially waste money with balancing on a set that I could have worn unevenly
  2. Jul 28, 2017 at 8:37 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    slight wobble and death wobble seem like drastic differences. Are you sure this is an alignment issue and not something else?
  3. Jul 28, 2017 at 8:51 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    I bet they over torqued your lugs. Did they use an impact wrench to put them on then "check" the torque with the wrench?
  4. Aug 1, 2017 at 5:12 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    We run the same tires on our Tundra and since hitting 25k miles with them, they won't balance properly again. This is after a regular balance job and also road force balancing which helped a little.
    We're probably going to ditch them soon for something else. We definitely cannot recommend these tires.
