balancing problem
Discussion in 'Wheels & Tires' started by taco man31, Mar 14, 2010.
  1. Mar 14, 2010 at 6:24 PM
    taco man31
    taco man31 [OP] Well-Known Member
    hey guys im having a little problem with balancing tires on my truck. I bought a set of fj wheels and have a set of bridgestones on them and seems like they keep getting out of balance. What could be causing this? Only once have i had them balanced with no problems untill they rotated the tires. Then it started to shake again at about high 60's/low 70's
  2. Mar 14, 2010 at 6:30 PM
    taco man31
    i dont know what road forced balanced is. I had them balanced at my local toyota dealer. My guess is they would know what to do with them being its a trd wheel. right?
  3. Mar 14, 2010 at 6:30 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Sounds like maybe a bent wheel. Swap the front for rears and see if it goes away. If it does, one of the wheels (likely on the rear) is bent.
  4. Mar 14, 2010 at 6:31 PM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
  5. Mar 14, 2010 at 6:53 PM
    Taco John
    Illinois
    4X4
    Interesting, I have never hear of this before, but it is now on my radar! Thanks!
  6. Mar 15, 2010 at 12:27 PM
    taco man31
    dealer road force balanced the front tires. Seems to have been the problem. I wish they would have done the rear as well so that when i rotate i dont have the same issues. THanks guys for your help
  7. Apr 25, 2010 at 9:31 AM
    shift96
    shift96 Well-Known Member
    Tacoma wheels are hub centric. If they were lug centric they would have tapered lug nuts.
  8. Apr 25, 2010 at 9:37 AM
    shift96
    The haweka adapter is not a lug centric adapter. The haweka does not center the wheel, it simply applies force to all lugs as if it were mounted on the truck. It uses a precision cone to center the wheel from the center.
  9. Apr 25, 2010 at 9:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There is a taper on the 1st gen lug nuts used on the stock alloy wheels.
  10. Apr 25, 2010 at 9:08 PM
    shift96
    No there are not. The part that sits against the wheel is flat. These are Shank style lug nuts. Not tapered. They do not center the wheel. I believe the steal wheels may have tapered lug nuts
  11. Apr 25, 2010 at 10:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm sure you are correct. I just looked at one and it has a very tiny taper on the end but a big 'shank' also. I've seen them referred to as a flanged type lug nut rather than a shank type. So your statement makes sense to me now.
    What doesn't make sense is that there are many, many places that state Toyota wheels are NOT hub centric and that the haweka adapter must be used to center the wheel because Toyota wheels are lug centric.
    Some of the confusion certainly comes from ordering aftermarket wheels. Aftermarket wheels to fit a 1st gen Tacoma must be "Lug Centric" or they wont fit.
  12. Apr 26, 2010 at 6:20 AM
    shift96
    I hear ya. It is very confusing. I beleive the Haweka is used BECAUSE the wheels are hub centric. I have a TSB stating that.
