Balancing tires with TRD PRO wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by unavailableTaco, Oct 2, 2018.
  1. Oct 2, 2018 at 6:15 AM
    unavailableTaco
    unavailableTaco [OP] Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    I see that the PRO wheels don't have an area to put wheel weights from the outside. Does this not allow for the tires to be balanced the best that they can be since weights can only be put on one side?
  2. Oct 2, 2018 at 6:17 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Stickies?
  3. Oct 2, 2018 at 7:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They didn't have any issues balancing mine, it looks much better without wheel weights on the face on the wheel
    DavesTaco68 and Garyji like this.
  4. Oct 2, 2018 at 7:04 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Mine have "stick-ons". KO2's are famous for being difficult to balance, but DT gets it right every time.
    G.
  5. Oct 2, 2018 at 7:07 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    It's pretty rare anymore to have wheels with weights visible on the outside, isn't it? I can't think of the last wheel I had with that.
    shakerhood likes this.
  6. Oct 2, 2018 at 7:52 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    They only do it with steel wheels now, I’ve never seen an alloy wheel with clamp on weights. Not that it hasn’t been done though.
  7. Oct 2, 2018 at 8:05 AM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    Stick on weights in the inside only.. Had zero issues balancing mine..
  8. Oct 2, 2018 at 8:06 AM
    Tora
    Tora Well-Known Member
    Jamie
    Vancouver, BC
    2018 TRD Off-road
    I just got a set put on through the dealership where I bought the car and they were balanced using stickies on the inner part of the wheel. I have a feeling a strip may have felt off as one of my rears is feeling a bit out of true above 80km/hr (about 50MPH).
  9. Oct 2, 2018 at 8:07 AM
    jay_zed
    jay_zed Well-Known Member
    16 TRD Sport 6MT, 24 TRD Offroad 6MT
    You can put the stick-on weights either towards the outside or towards the inside and achieve the same result as the more traditional clamp-on weights on the outer lip. On my KO2's I ended up with a combination of weights both towards the inside and outside
  10. Oct 2, 2018 at 9:25 AM
    unavailableTaco
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
    This is my first truck to have stickons. My 2013 RD Sport had regular old style wheels. My ZL1 has the stickons. This PRO seems to at 90 mph, in Mexico, one in the back has a little shakey shakey.
  11. Oct 2, 2018 at 12:19 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Ideally for the best dynamic balance, you put weights on the outside, but wheel weights are ugly and leave marks so you see them less and less. Depending on the offset of the wheel, you can sometimes put weights on the inside of the rim. Balancers are calibrated for this set up and can get a pretty close dynamic balance. If you have negative offset or slightly positive wheels, it is impossible and you get a static balance, which in most cases is more than adequate to balance your wheels.
  12. Oct 2, 2018 at 12:25 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I've seen oem BMW mesh style wheels with a lip have the visible wheel weights. That looked terrible.
