Ball hitch in rear bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vincenzo4x4, Jan 25, 2012.
  1. Jan 25, 2012 at 2:40 PM
    vincenzo4x4
    vincenzo4x4 [OP] Active Member
    Vermont
    2022 trail
    Hi I purchased a 2012 base access cab and realized that there is no recovery point on the rear. I see that there is a spot on the bumper for a ball hitch. Anyone know what size I would need? Does anyone make a dring that would be big enough to fit back there?
    Thanks
  2. Jan 25, 2012 at 2:47 PM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    the size ball depends on what your wanting to tow..
  3. Jan 25, 2012 at 2:51 PM
    vincenzo4x4
    Vermont
    2022 trail
    Not wanting to tow anything just want a point to hook onto in case of getting stuck in mud or a ditch. Do they all have the same side base then?
  4. Jan 25, 2012 at 2:55 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    dont use the factory stock bumper with a d ring for a recovery point. i would not even pull a trailer with the stock bumper. id recommend buying a reciever style hitch and getting a shackle for that. theres a member on here who sells what you are looking for that works for a reciever style.
  5. Jan 25, 2012 at 2:58 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    ^^I agree. Get a hitch shackle and call it a day.
  6. Jan 25, 2012 at 3:01 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    x2. the bumper would bend and or rip off trying to pull the truck out of a ditch or mud hole.
    on 2nd note is it even rated to tow, what the truck even weighs?!?? not sure if is.
    edit: idk even know what the bumper is rated for(nor to i really care i have tow package) or what the truck weighs!
  7. Jan 25, 2012 at 3:06 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    Agreed. the rear bumper isnt exactly a strong point. I think its suppose to be rated for 5000 pounds but a hitch is both easy to install and fairly inexpensive. I also considered it to pull people out of snow drift but I dont want to tweak or twist my bumper.
  8. Jan 25, 2012 at 3:11 PM
    vincenzo4x4
    Vermont
    2022 trail
    How much does a tow set up run?
  9. Jan 25, 2012 at 3:11 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    An aftermarket bumper or class IV receiver hitch is better than destroying your stock bumper...and I have destroyed many.
  10. Jan 25, 2012 at 3:39 PM
    2000GTacoma
    Snow Hill NC
    a reciever style hitch im guessing would cost a couple hundred depending where you go. curt, reese, hidden hitch are just a couple places that make the hitches. toyota might have there own or use an outside company not sure. mine is a reese and i have hooked things to it that the truck should not have ever pulled and never had a minutes trouble with it.
  11. Jan 25, 2012 at 5:08 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    You can even find a factory hitch here in the 2nd gen Marketplace from time to time. People swap out the stock rear bumper and don't need the factory hitch anymore. I got one last year for about $150 and naturally, it dropped right in. Plus, it was a Class IV not a III like a lot of the less expensive aftermarket ones are.
  12. Jan 25, 2012 at 5:23 PM
    jw1983
    Alberta
    If you "choose" to do it by your bumper I would suggest for you to go on Youtube and see what happens when you tow with a bumper. Something plastic that is made to bend by something that is pulling it with some force isn't going to turn out to be good. Also if the bumper comes off anything attached to it could potentially become a projectile to anything around it, including the vehicle towing it.
  13. Jan 25, 2012 at 5:34 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    ive pulled trucks out and had my truck towed using a large dring in the rear bumper. Works fine
  14. Jan 25, 2012 at 5:38 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I believe they are rated 3500# There is a fairly heavy bar inside of the bumper and the factory hitch is bolted to the rear bumper along with the frame still if you are really stuck it's probably not one of the better places to be towed out from. Some one with 2 tons of truck and a running start can place a lot of force on your rear bumper watched a guy rip the rear spring shakke out of a Dodge truck one day doing just that.
  15. Jan 25, 2012 at 5:40 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    ...until it doesn't.
  16. Jan 25, 2012 at 5:52 PM
    jw1983
    Alberta
    and you fudge your bumper
  17. Jan 25, 2012 at 5:58 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Mmmm..... fudge..... :D
  18. Jan 25, 2012 at 5:58 PM
    Yoytoda
    Roland
    completely stock
    Im sure you guys wheel so damn hard :rolleyes:
    the bumper is rated for 3,500#s thats pretty good for mild wheeling. People are suggesting putting on a trailer hitch which is retarded advice for offroad recovery. why reduce departure angles
    Either use a dring in the rear or get an aftermarket bumper for recovery and add to the departure angle.
    the stock bumper is pretty tough in the middle. the sheet metal on the outside sucks but the center structure is tough and it uses the same mount points as the trailer hitch
  19. Jan 25, 2012 at 5:59 PM
    jw1983
    Alberta
    I guess if they bust their bumper they can cry into a bar of fudge.
  20. Jan 25, 2012 at 6:04 PM
    jw1983
    Alberta
    I just wouldn't want to come back here on the board and read a post from the OP saying that he fudge his bumper for taking the one person advice who is telling him to do it. Either way it's to the OP's discretion if they want to do it or not. I just wouldn't want to see pics of them and their truck and the damage that could possibly in sue.
    The reason why we are saying not to, not only save your truck but there is other ways to getting your truck out.
