ball joint f-up
Discussion in 'Suspension' started by tacotruck 2.7, Dec 24, 2012.
  1. Dec 24, 2012 at 12:49 AM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    09 4cyl 2wd taco ::::::::::: i tore my upper ball joint boot yester putin in a 2.75" lift. the ball joint is in good shape and i have no wish of replacing it if i dont have to. Q. is ther a boot replacement for this even a universal kit ? Q. and if i must replace the balljoint does it have to be pressed in ? its got da 5 lug wheels. your input is appreciated.
  2. Dec 24, 2012 at 1:00 AM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Id replace it because if the boot is torn your going to get all kind of dirt in there especially since your going off road! Just buy some moogs(brand naME) from i believe rockauto.com AND JUST FROM MY EXPERIENCE WITH THE STOCK BALL JOINTS AND PRESSING THEM INTO THE UPPER CONTROL ARMS. ITS A BITCH ID HAVE THEM PRESSED ON A REAL SHOP PRESS RATHER THEN THAT BALL JOINT DO IT YOURSELF TOOL. LOWER CONTROL ARM BALL JOINTS ARE EVEN HARDER. SAVE YOURSELF THE SWEAT AND TEARS AND HAVE THEM PRESSED ON A HYDRAULIC PRESS LOL. I SAY REPLACE IT NOW AND SAVE YOURSELF THE JOB LATER THEN YOU DONT HAVE TO WORRY. OH AND SORRY FOR THE CAPS JUST NOTICED IT, GOT FAT FINGERS FROM PRESSING IN STUBBORN BALL JOINTS HA HA HA
  3. Dec 24, 2012 at 1:15 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Get an old accordion boot off of a 5100 billy (or even some innertube & wrap it like a band aid which in essence it is).. use some thin tie wire or a split zip tie to hold together, carry on..
    I did a couple short videos on ball joint R&R, anyway you can do it without a press, not advised but you can beat them in & out, always better with a press, make sure to take out "C" clips high/low
  4. Dec 24, 2012 at 8:59 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Rent a ball joint press from autozone and do it right. Replace them in pairs, always. It will take quite a bit of force for the joint to come loose, and it will come apart quite forcefully.
    The coil over will have to be removed to make room for the press, and the sway bar needs to be disconnected to remove the coil over.
    You're looking at 2.5 hours total, depending on your skills.
  5. Dec 25, 2012 at 7:33 PM
    tacotruck 2.7
    Katy TX
    thanks for your help guys. much appreciated. however if i havent driven the truck since i tore it as to allow dirt /trash in it whats so bad about replacing jus the boot given i can probably get another 30-40 k miles out of the balljoint . its a road driven truck and the lift was jus for looks as i could not afford a sr5 or prerunner but i liked their profile.
  6. Dec 25, 2012 at 7:37 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I have a set of stock balljoints with 30,000 miles on them. Just replaced the UCAs and balljoints with aftermarket. Interested in buying mine?
  7. Dec 31, 2012 at 4:22 PM
    ProForce
    ProForce IG @proforce1
    Anthony
    SoCal-Ontario
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Just found out I might have a bad ball joint. Getting it checked on now. If so, I might be interested if OP doesn't want them first
  8. Dec 31, 2012 at 6:04 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    He hasnt contacted me. PM if your interested
