Ball joint failure advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by PBNCLB, Sep 30, 2019.
  1. Oct 2, 2019 at 7:17 PM
    #41
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Your strut looks like a boiler part from the Titanic.
    jammer and PBNCLB[OP] like this.
  2. Oct 2, 2019 at 7:21 PM
    #42
    PBNCLB
    PBNCLB [OP] Well-Known Member
    Landon
    1999 Black Tacoma Xtra Cab
    Aftermarket Radio Bilstein 5100s
    Whenever I save up some more money I’m gonna throw them back in the ocean don’t worry :D:rofl:
  3. Oct 2, 2019 at 9:50 PM
    #43
    cr4zin
    cr4zin New Member
    02 Tacoma Prerunner
    none
    I'm a lurker, but I just replaced both LBJ and outer Ties about a month ago and it wasn't too bad(not a mechanic at all, first time doing anything other than oil changes). The only real hassle were 4 bolts that connect the joint to the knuckle, for whatever reason I couldn't get my torque wrench to click on any of them... I over tightened one and it broke off. Blue loctite and tighten as best you can.
    PBNCLB[OP] likes this.
  4. Oct 2, 2019 at 10:16 PM
    #44
    PBNCLB
    Landon
    Heard that man
    I was having alot of trouble at first because I didn't have the correct tools for the job lol
    A breaker bar and a puller worked wonders
  5. Oct 2, 2019 at 10:42 PM
    #45
    eon_blue
    Azusa, CA
    I have to use an extension on my torque wrench in order to get it to sit on those bolt heads properly. They don't take a whole lot, just 60 ft/lbs...I snapped one of those bolts once too and it got stuck inside the spindle. That was fun
  6. Oct 3, 2019 at 9:50 AM
    #46
    tony2018
    tony2018 Well-Known Member
    Saw that too, looks like it could snap in day now. So much caked on 'stuff'....
  7. Oct 3, 2019 at 9:54 AM
    #47
    PBNCLB
    Landon
    The idiot who owned it before me decided to cover up the rust with rubberized undercoat instead of remove the rust then undercoat. So they just sprayed EVERYTHING like idiots and now I’m left to clean up the mess lol
  8. Oct 3, 2019 at 9:54 AM
    #48
    tony2018
    oh boy...winter is coming....
  9. Oct 3, 2019 at 9:55 AM
    #49
    PBNCLB
    Landon
    Game plan is to just replace things as money allows and remove as much rust as possible and repaint then oil
    Might help a little bit
  10. Oct 3, 2019 at 11:03 AM
    #50
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  11. Oct 3, 2019 at 11:16 AM
    #51
    tony2018
    saw that, crazy. Worst way to take care of your frame.
