Ball joint failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by tripps, Nov 21, 2017.
  1. Jan 12, 2018 at 7:53 AM
    tony2018
    tony2018 Well-Known Member
    Plenty have use something similar to ES, there's also whiteline.
  2. Jan 12, 2018 at 7:57 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you have 160k on a 2001, you might as well just do it. It will be another 15 years when you need to even begin to worry about it again.
    The amount of play for a ball joint to have to fail inspection is if there is any at all that you can see, you are already pushing way past it's allowed tolerances.
    wilcam47 and The Driver like this.
  3. Jan 12, 2018 at 8:08 AM
    vtframer
    vtframer Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    yep - I just made an appointment to have them replaced on Monday - dang - the parts alone will be $300!!
  4. Jan 12, 2018 at 8:13 AM
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    Whether it's pulled behind an RV or driven down the road it is still putting wear on the part. Pulling a vehicle behind an RV only reduces wear on items that are not being used.....like the motor or Trans.
  5. Jan 12, 2018 at 8:18 AM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    I'm about to start tearing into my front end today. All the parts finally came in from napa. Whiteline LCA bushings, 555 LBJ's, and a new rack. Should be a fun couple of days
  6. Jan 12, 2018 at 8:22 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It's easy to do yourself if you want to save some money. Also, you can get them from Gunny for probably less than $200
    Running Board Man likes this.
  7. Jan 12, 2018 at 8:23 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Fixed.
  8. Jan 12, 2018 at 8:34 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I would be terrified driving around with a 22 year old 270k mile LBJ.
    The Driver likes this.
  9. Jan 12, 2018 at 4:22 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Seriously. I had mine replaced @ 125K miles, against my mechanics will. Turns out the driver side was leaking. I'm no fan of false savings.
  10. Jan 15, 2018 at 6:38 AM
    vtframer
    Vermont
    So I dropped my truck off to have the LBJs replaced this morning and had a chat with my mechanic - he said that typically after a LBJ shows signs of trouble (fails inspection) you have about 10k miles until they go. As of a couple months ago a toyota tech said they were ok, but one could use replacement in the spring - I know I made a right decision this morning having them fixed, its just weird because up until now I've only replaced parts when they've actually been bad or failure was imminent.
  11. Jan 15, 2018 at 6:41 AM
    tony2018
    Heard similar talks, don't replace it if it ain't broke. But that saying doesn't always apply to everything. I still go by my gut and how long since the last time I replace a part though, just like the timing belt job.
  12. Jan 15, 2018 at 6:47 AM
    vtframer
    Vermont
    yeah - agreed - I bought the truck with 146k and has 160k now, not sure if the LBJs were ever replaced.
  13. Jan 15, 2018 at 7:20 AM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    If you search my recent threads iv had this happen twice one both sides of my 01.
    Mevotech ball joints. Broke lower and uppers brake lines and c.v axles
  14. Jan 15, 2018 at 7:21 AM
    vtframer
    Vermont
    mevotech? assume that is aftermarket? I got Toyota LBJs...
  15. Jan 15, 2018 at 7:22 AM
    #35
    tony2018
    Well I guess that ended up on the 'do not buy from' list...
  16. Jan 15, 2018 at 7:36 AM
    #36
    specialized7
    ,Saskatoon, Canada
    05 v6 4x4
    Yes Mevotech are aftermarket. If had both pop out
  17. Jan 15, 2018 at 7:39 AM
    #37
    specialized7
    ,Saskatoon, Canada
    05 v6 4x4
  18. Jan 15, 2018 at 9:33 AM
    #38
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    It were me, I would:
    First, jack up the left front wheel and use a long pry bar to check the condition of the ball joint. Any noticeable movement is grounds for immediate replacement. Then I would repeat for the right front wheel.
    Finally, I would chalk my efforts up to fun and experience, and replace both regardless of their perceived condition. And I would use Genuine Toyota Parts. Only then would I have confidence in the LBJs for the next 50-60k miles.
  19. Jan 15, 2018 at 5:46 PM
    #39
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I’ve got a 04 that had the balljoints replaced at 25k under recall. I’ve got 140k on the truck now. Should probably check out the condition of the balljoints. My 4runner had 260k on it without them ever being replaced.
  20. Jan 15, 2018 at 6:57 PM
    #40
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Yeah that’s the part that’s confusing to me. Mine is an ‘03 and the VIN # is not part of the recall.
