Ball joint failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by tripps, Nov 21, 2017.
  1. Jan 16, 2018 at 5:47 AM
    #41
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    6 lug
  2. Jan 16, 2018 at 6:34 AM
    #42
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Looks rough. Glad you're okay. Lets get that Taco running!
    What I would do/replace:
    1) OEM Ball joints Lower and Upper both sides
    2) Inner and outer tie rods Pass side (I would check driver as well as the forces translate to the other side)
    3) Replace the front struts (you can keep the springs) I wouldn't replace just one. Always as a pair to keep things even.
    4) Strut mounts
    5) Lower and upper control arm pass side (may be tweaked)
    6) Sway bar links driver and pass
    7) Check the control arm mounting in the frame make sure its true
    8) Brake line Passenger.
    9) Alignment.
    Hopefully the knuckle didn't get all boogered up.
    Dalandser likes this.
  3. Jan 16, 2018 at 7:22 AM
    #43
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That was a bad run. They're not the same ones people purchase today.
