Ball Joint flip with drop springs
Discussion in 'Street Trucks' started by e.deCastro, Apr 16, 2018.
  1. Apr 16, 2018 at 3:35 PM
    e.deCastro
    e.deCastro [OP] Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I have belltech 2" drop coils and I did the ball joint flip and I'm happy with the height. I also drilled out the taper hole for the tie rod ends and flip that as well. it's time to replace ball joints on my tuck (all still factory) should I put the tie rod ends back to the stock position? on top? when i did that flip it looked like an extreme angle for the tie rod since it was going in from the top. has anyone had any problems leaving it in the stock position? thanks.
  2. Apr 20, 2018 at 11:43 AM
    pinktaco808
    pinktaco808 Hot Steppa
    go lower, post the pics?
  3. Apr 20, 2018 at 11:47 AM
    e.deCastro
    Eric
    San Diego
    I'm not sure what you are asking. but I can take pictures tonight when I get home. I have decided to (since I need to replace the upper ball joints) is to replace all my ball joints and tie rod and tie rod ends and put the tie rod ends back in the stock position. it doesn't seem like anyone was having any problems with the extreme angle of the tie rod so I should be safe.
  4. May 2, 2018 at 12:12 PM
    pinktaco808
    huhhhhhh
