Ball Joint Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by scalfee90, Apr 3, 2012.
  1. May 22, 2012 at 11:25 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    When you apply grease to your ball joint, you need to wait till you install it on your Taco. After installation, you apply your grease gun to the Zerk fitting and pump your handle once. Take your finger and push on the rubber casing protecting the ball joint and see if you can apply pressure and push in on the casing. If you can push the casing in a little bit apply another pump of grease from your grease gun. Push in again against the casing, now if you can't push in against the casing it is time to stop applying grease. The casing is full and does not need any more grease. If you apply too much grease and the casing blows out the excessive grease, you now have a hole for dirt to enter the ball joint. You won't kill the joint quickly, but you will have limited the life span of the ball joint.
    The old days of applying grease till it squirts out was from a different time and a different design of ball joint. As long as you keep your ball joint casing whole and do not bust it by over greasing, dirt will not destroy the ball joint. Later on as time passes there will be a need to regrease the ball joint, just be careful. Good luck.
  2. May 22, 2012 at 11:29 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Moog ball joints have a "nipple" with a hole that the grease will come out when its full. Once excess grease is gone the nipple isnt under pressure and it closes itself so dirt doesnt go in
  3. May 22, 2012 at 11:46 AM
    Ga tacoguy
    Rudy
    Augusta Ga.
    :) Thank you for clarifying this for me. It used to be that all good suspension parts came with fitting and were made of good material by Americans, and you could trust the name on the box. Today, the Chinese have bought the good American names and brought in cheap junk to replace quality suspension pieces. I really do not who makes what anymore and who to trust when it comes to good suspension pieces.
  4. May 23, 2012 at 10:24 AM
    Hollywood0027
    Hollywood0027 Well-Known Member
    Brad
    Denver, CO
    '95.5 3RZ
    9/2/14 Edit: 4.3 Vortec installed, NP3500, custom NP233 transfer case, high pinion dana 44 SAS with ARB, 4.88 gears, bobbing the bed, 5" lift, boxed rear frame, custom s10 fuel tank mount, etc. 12/16/13 Edit: Currently tearing down a 2000 Blazer to transplant the 4.3 Vortec and 5spd manual transmission (NV3500 I believe) into the Taco. It'll pass CO emissions when done. Planning to post a thread once complete. E-Locker, budget CAI and exhaust, Warn Powerstation, Addicted Off Road bumper, ToyTec OME w/AAL lift, aftermarket stereo w/10 inch subwoofer (only cool when you realize how I fit it in a reg cab truck), dual lexus horns, roll bar, off road lights, CB radio, Powertrax Lock Right locker (front diff), ejecto seat, laser/phaser/ion ray gun, oil slick, heat seaking missles...
    Thanks for the help. In the past I bought my parts from PartsGeek.com but after poor customer support for an incorrect part (supposed to be a direct fit cat, nowhere near close) I have started sourcing parts elsewhere. I got a full set of the new zerk MOOG's from advanced auto for just over $200, and if they don't work I can return them in person :D
    I'm also installing the Energy Suspension poly control arm bushings, going to add zerks to my factory arms. I'll try it, if it works I'll write a how-to since I can't seem to find anyone who has done this before, only speculation that it is possible.
  5. May 25, 2012 at 5:22 AM
    Gage
    Gage Active Member
    This is sankei 555 part. Moog is having a lot of parts for our trucks manufactured by them including outer tie rod ends. 555 makes a ton of OEM parts on our trucks and the quality of these is pretty good. I got zerrks with a 45 degree to make greasing them while on the truck possible.
    You could probably save money and just buy Sankei 555 in the first place.
  6. May 25, 2012 at 7:09 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ^ I got these from Rockauto.com on the cheap
    Great site, TW discount and fast delivery
  7. May 25, 2012 at 9:40 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I got some MAS industries lower ball joints for like $25 ea. They're the same as Autozone or Advance has for $40 ea. Supposedly, there are not many ball joint manufacturers out there. Autozone does give a lifetime warranty though.
  8. May 25, 2012 at 10:03 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    sub ... think I may need sum ...just have to wait for sum $$$
  9. Jun 13, 2012 at 3:56 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    I actually found my Moog's to be 6mm for the zerks
  10. Jun 14, 2012 at 10:29 AM
    Bens99taco
    Bens99taco WV Tacoma man
    Ben
    Hurricane WV
    01 Tacoma SR5 ext. Cab 4x4
    Moog ball joints and tie rod ends work great had on my last Tacoma going to put them on the one I have now
  11. Jun 14, 2012 at 11:56 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    He was referring to greasing until it comes out of the boot, not the nipple/zerk. All zerks are self sealing, if working properly.
  12. Jun 14, 2012 at 11:58 AM
    Cr250jumper
    The moon
    50 shades of tan©
    I am talking about the boot too, I know what a zirk fitting is, thanks. The BOOT has a nipple on it as I described the 1st time. Look at the right side of the boot, do you see the nipple?
  13. Jun 14, 2012 at 11:59 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It's also a good idea to replace all of your ball joints at one time. At least replace them in pairs. ie. both lowers. Both ball joints have seen roughly the same wear...
  14. Jan 2, 2015 at 7:54 AM
    Nbrannon92
    Nbrannon92 Well-Known Member
    Nick
    Houston, TX
    97 Tacoma 4x4
    First gen Tacomas had a recall for the lower ball joints. It's something about a fail safe design. I think you can get this fixed at a dealership for free if your vehicle qualifies.
  15. Jan 3, 2015 at 4:24 AM
    #35
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  16. Jan 3, 2015 at 8:37 AM
    #36
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    OEM
    /thread
  17. Jan 3, 2015 at 9:06 AM
    #37
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    No experience here, but from what I've read on various forums, the recall applies just to 2001-04 Tacomas. However, the new replacement joint does not fix the fail-safe design issue of the the spindle/knuckle assembly.
  18. Jan 3, 2015 at 9:24 AM
    #38
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Once you find the OEM part number check this site out. I know for my 02 T4R they run $88 a piece.
    LINK
  19. Jan 5, 2015 at 2:18 PM
    #39
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just to clarify, do the Moog LBJs come with or without zerks? Has anyone ordered some recently to confirm?
  20. Jan 5, 2015 at 7:36 PM
    #40
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    I got some a couple months back, they didn't come with zerks
